It wont spin just 1yr and 1 wk old. motor still making noise does everything else but spin. Was out of town for 10 days worked when left didn't work when returned.
  • 712 Answers
If you are inside the warranty period, don't do anything by yourself nor break any seals. Instead report the same to your dealer.
Posted on Aug 20, 2010
When i put my machine on to spin the clothes are coming out very wet, I have cleaned out everything, everything seems to be working properly, The pump is fine, Can you tell me what is wrong I use onl
Depends how old your machine is Sounds like your motor maybe wearing out. Does it make any noises. Make sure your not putting in to many clothes weighting it down. Try spinning a very little load see if they come out ok. If not MOTOR.
Jan 21, 2015 | Washing Machines
Rover 75 forum
the car as a wire connected to the chassis and he is descharging the battery. you have to go to a car electrician and look wall the cables to see where he is not isolated.
Mar 11, 2014 | Cars & Trucks
I have a Maytag MAV6300AWQ top load washer that is making a LOUD noise during ALL cycles. We lifted it up in front and looked underneath; the belts look okay; the large one had some slack in it; maybe...
If the belts are old they will allow the motor too much outward room, so that the motor shaft can rub against the bottom of the machine. Also make sure the motor rollers are not cracked, which they have a tendency to do.
May 08, 2011 | Maytag Washing Machines
I have a m51 chair it has less than one hours use on it it is a couple years old though mom was afraid of it we keeep the batteries charged and would move it around the room just to make sure everything is...
Nick Might first thought is that you have a brake problem well not so much that its not working as that the brake pad is stuck because of little use. Over time moisture can get the brake pads sticking to the motor case and it will cause the motor to get hot trying to turn. If Medicare paid for Mom's chair then they will pay for most of the repair. You can contact her provider(where she got the chair) or one of the 2 repair services that I list in other posts Hope this helps you
Mar 16, 2011 | Invacare Pronto M51 Power Wheelchair
NuTone LS100 fan is squiling when it runs. Spinning the fan blade by hand when it isn't running doesn't make any noise. Am I correct in thinking that the motor needs to be replaced?
Sounds like it may actually be the bushing pack inside if the motor. Spinning the blade by hand is not going to spin it fast enough to hear the problem. If the unit is new, I would recommend returning it for exchange of a new unit. If it more than 1yr old, it's out of warranty and will be cheaper to just replace it rather than repairing it.
For less than $100 you can buy a newer, more efficient model. Depending on the size of the room is how should judge what unit to buy. An under sized unit will not pretty much nothing, except make noise and remove some of the steam. Remember to buy a fan with the lowest SONE rating as it will have the highest quality motor housing and best air removal.
Keith
Feb 28, 2011 | Broan-NuTone N-LS100 Exhaust Fan Exhaust...
I have a numark cdn 88 just change the transport assemble but the cd wont spin and give me no disc on the display
Chances are that you didn't reassemble the unit correctly or damaged a ribbon cable or limit sensor. Re check your work. Pay attention to small circuit board attached to the spin motor RF310T-11400. De-solder the small circuit board on the 2 motors..and apply 12v to the spin motor. See if it spins with no dead spots on start up. when asseembled, motor will only operate and spin up to the proper RPM only if loading is successful and tray is fully closed ..etc. Hope this Helps. I have a CDN-88 in my shop for skipping issues on both CD players. so I saw your problem here while doing research. Good Luck,
Thanks, Dillon, Trace Electronics, Barrie, ON, Canada.
Jan 20, 2010 | Nu Mark Audio Players & Recorders
Hoover AM1100 Washing machine, wont final spin.
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Nov 09, 2009 | Washing Machines
All for windows, wont go up or down, sometimes if you push the down buttom it will go down jus a little then stop, all four windows makes motor noises when trying to work, but just wont work, how can you...
Cars getting old but if your handy getting the door panels off and removing the motor the motor has clutch Plastic bumpers that die of old age. Auto parts stores sell these in a pak of three made as a Help product- Motormite- Dorman/ This is a common old ford with electric windows problem
Aug 13, 2009 | 1992 Lincoln Town Car
Everything works-no spin-motor sounds like it won't engage
Sounds like the clutch is malfunctioning. Not an easy DIY job -- probably need a service call.
May 31, 2009 | Roper RAX4232KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
