Question about Mitsubishi WS-65807 65" Rear Projection Television
I have a mitubishi 42 1080i tv projection. i turn it on & 2 seconds later it turns off help
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Provide correct model number but TRY:
when it shuts off, on the front of the set push both the menu and input buttons at the same time and hold them for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks a pause and repeat it 4 more times.
Let me know error code and I will assist you.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 20, 2010
Set turns on then turns off a few seconds later
Set have the tv projection lamp problems.Tv have a "LAMP"LED light indication on the tv front screen panel are flashing are staying on lite?Yes,than the tv projection lamp life are ending.Tv have been on and used like 4 or 5 hours a day and the tv projection lamp been on the tv like a 1 1/2 or 2 years?If it is a new tv projection lamp,than ur tv might have a problem with a board call a Ballast board.This Ballast board job are to help to ignite the tv projection lamp.
Dec 06, 2010 | JVC HD-61FH96 61" Rear Projection HDTV
Tv wont turn on
hold the menu and input/device buttons for 5 seconds and it will blink you a 2 digit code
1-2 normal operation
2-3 i believe is short circuit protection = probably a convergence failure
here is a link to my tutorial
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Jun 20, 2010 | Mitsubishi WS-55809 55" Rear Projection...
My tv won't turn on it clicks on then a second or
When it shuts down do any lights on the front light up red? If so its in prtective shutdown and you can get a two digit blink code by pressing in the menu and device buttons on the front panel. then counting the number of blink. It should blink a series of blinks and pause for the first digit then blink another series and pause for the second digit . then the process repeats. If a code blinks let me know what they were.
Nov 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
When i turn my TV on green light comes on timer turns off
Hi my name is Roety,
I can help you with your issue ,
Most likey you need the convergence ICs replaced.
A repairman would charge about $350 to replace them
Voltage checks and a visual would be needed to determine exactly what is bad in your TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 20, 2009 | Mitsubishi WS-65413 65" Rear Projection...
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Turn it on and turns off again
sounds like your powersupply is bad. usually reasonable repair. 150-250 parts and labor
Jun 05, 2009 | Mitsubishi WS-65907 65" Rear Projection...
I turn on the TV and after about a second it turns back off
22 error is the code for short protect which could be the two STK392-110 Convergence ICs as thats the number one component to short out . It could also be leaking coolant check the boards for any sign of a sticky residulr that would indicate that the CRTs are leaaking coolant on the boards.
Apr 27, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi 72" projection TV I turn on and then turns off
If this this a LCD projection It may be a faulty lamp. It is a great idea to call the support center. they can walk you through it and advise you too.
Apr 26, 2009 | Mitsubishi WD-62327 62" Rear Projection...
NO picture
If you go to the following link. we have the service manual for your tv for 10.99 and we provide unlimited chat support to help diagnose and repair your TV. Just click on mitubishi and you will see your manual. then click on the contact us link and provide your email address we will email your manual and instructions on how to enter into the chat sessions. Hope this helps.
http://servicemanuals.vstore.ca/
Jan 12, 2008 | Mitsubishi VS-45603 45" Rear Projection...
65'' mitubishi hd tv
Does the light blink continuously or is there a two digit sequence to it?
Jan 03, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
