Question about Pioneer AVHP3200BT Car Video Player
There is no signal on the video out line on any source.
  • 57 Answers
You must set your background options to the source you want to use. aux1 aux2 ect
Kieran
Posted on Aug 25, 2010
How do i get rid of the wavy lines on my tivo signal
Waves are cycles or signals that remotely attach themselves to the receiver antennae, line cord, or other external sources. They tend to infiltrate, passing through the circuit board to the transmission output such as the Audio or Video circuit. Improper connections, wire insulation, grounding, and related incidents can cause excessive wavelength distrubrnces.
May 10, 2014 | Televison & Video
Lcd tv goes blue screen
Blue Screen usually means you have no video source, but also it can be a bad cable, bad signal, or week signal. I will try to hook it up to a dvd and test it on another source. However the screen should be all blue aand not blue lines, if you can email me a photo of the screen I will be able to properly address it.
Tony Mitri
goldtekfl@hotmail.com
Feb 15, 2014 | APEX Digital Inc. Apex Digital 32" 720p...
My AVR-E400 sub woffer not working through the Denton system
AVR-E400 has an RCA subwoofer output. This is a line level signal that must be connected to an ACTIVE subwoffer (has its own power amplifier) Also the source must contain subwoffer signal (5.1, 7.1, 9.1 surround sound etc) You will not get subwoffer signal from a stereo source such as audio CD, non-dolby type TV etc. Cheers, Don.
Dec 05, 2013 | Denon Audio Players & Recorders
Video source not detected by dvd recorder
If the recorder accepts RGB see that your source puts out RGB or video. If the recorder is set to S-video the source must send an S-video signal. Match the signals.
Aug 14, 2013 | Televison & Video
Connect Airport Express to Yamaha RX- V659
Since you're using a standard mini jack to double RCA cable, it's safe to assume you'll be sending line level signal into your reciever, so i think any of these audio inputs will do: AUX, CD, DVD, MD, TV.
Also try the inputs on the front of the unit (i guess they are meant to be used with a video camera or similar but they are designed for line level signals so it should be ok if you decide to use them).
Anyway, keep the source signal at a moderate
level when you test any of the inputs and raise it to a suitable level after you're sure it is coming thru well.
Normally, the AUX input is suitable for any AUXilliary signal source that puts out a line level signal, but if it is already being used, you may use other free inputs.
If you use TAPE or PHONO inputs, you should keep the signal level from the source a bit lower since these inputs will amplify the signal a bit more (especially the phono input which works with signals that are lower in level than the line signal).
I hope this helps.
Regards
3rq8 (Triarcuate)
Sep 06, 2009 | Yamaha RX-V659 Receiver
I have a 48" LCD television. There are vertical lines across the screen making it impossible to view the picture. However the picture for video camera hook up is fine.
Sounds like the resolution is not syncing or a setting is wrong, depends on the signal source you are using: if using a cable box use the yellow video out cable to the camera input that works and the adjust the resolution lower within the cable box, also check the TVs input settings, the component cables (red,Blue and Green) setting must be set to YbPbr not RGB to work. Due to the signal conversion done inside the TV there are settings to help things syncronize properly.
post more info about the signal sources to get more help.
E
Aug 05, 2009 | LG Televison & Video
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
Component input- no audio/video signal
what aiudio cable uusing with couplunt cables red white on same input ?
Oct 07, 2008 | RCA P61310 TV
Projector signal goes bad after 25 minutes
It appears the projector was over heating. Why it affected the DVD signal and not the computer signal, I do not know. The other confusing thing was the projector was hanging off the ceiling and should have had plenty of circulation. When I climbed up to check for excessive dust, I found that the lens cap had been placed over the intake vent. I blew off the dust and removed the cap. After running the projector for an hour, it appears that the problem has been solved.
Sep 22, 2008 | Dell 4100MP Multimedia Projector
Panasonic CT-32hX41 vertical picture problem (hourglass)
this product has a pincushion problem and requires servicing but unfortunatley it is what we call in the business NECO
Dec 05, 2006 | Panasonic CT-27HL14 27" TV
Pioneer AVHP3200BT Car Video Player Logo
52 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
