Question about ASUS Eee PC Netbook
My Eee pc netbook is having display problems. The display is all grainy and in weird colors. I can hardly read the words. At first it would do this a little bit, but now it is all the time, even when I reboot. Help! Marsha
  • 244 Answers
Your video adapter or your LCD screen is defective.
If you are under warranty, take it immediately for a replacement.
Good luck.
Don't forget to rate this answer if it helps.
Posted on Aug 20, 2010
When i turn on my eee pc i get the message "Press
Please pull out your hard disk and put it back after 10 seconds. Your laptop will be start as normally.
Thanks
Jun 27, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Tip
Review Asus Eee PC 1101 HA
asus-eee-pc-1101ha.jpg The Eee PC 1101HA netbook with a 11.6-inch display. For this and its characteristics could be defined almost a notebook. Obviously, a larger than normal netbook weighs more, but the Asus Eee PC 1101HA is a netbook with mobile calling. Asus Eee PC 1101HA promises up to eleven hours of PA3420U-1BRS battery life, thanks to the Intel Atom Z520 chip.
Homes and Design
The Eee PC 1101HA has the same form "shell" 1008HA Asus Eee PC. The case is polished and its shape makes it particularly elegant netbook. We noted that despite the gloss paint handprints not remain imprinted on the case easily. This Asus Eee PC 1000H is available in white pearl, black and pink crystal.
The hinges Eee PC 1101 HA self-locking (no mechanical locking) but well hoods that limits the opening angle to a maximum of 130 degrees, this makes little netbook fittings for use legs. The screen however is quite stable.
Autonomy
Asus EeePC 1101 declares that HA is able to provide even eleven hours of VGP-BPS2C battery life. Indeed, the netbook can reach eleven hours, but with the six-cell DV1000 Battery and without Wi-Fi active since our test Eee PC 1101 HA has worked from time to time reaching autonomy of 10, 48 hours. The test was performed with a non-intensive use and without wireless enabled. With wireless enabled netbook's Inspiron XPS M1710 battery life decreases by about three hours.
Weight and Dimensions
The amp 11.6-inch display makes the netbook a bit 'pesantino (1.38 kg) obviously increases the overall dimensions: height 21.80 cm, width 28 cm, depth 19.60 cm.
Judgement
Cast a netbook for mobility, thanks to long HP dv4 Battery life, good performance that does not disdain. We can define Eee PC 1101HA netbook complete. In fact, the hardware equipment enables to easily perform common office work in comfort. With excellent value for money (currently about 360 million) this netbook is among the best in its class.
on Apr 21, 2010 | Computers & Internet
Tried to power up my eee PC but only grey screen with logo comes. All keys freeze. Tried with and without battery, Tried plugged with power cord and without. Nothing worked.
Please remove the RAM, Hard disk and battery. press the power on button for 1 -2 minites. then insert only one RAM on another slot. Start laptop with AC power. Whether is it displaying the NO BOOT DEVICE or not. If display no boot device, please insert the Hard disk. then try..
Hope this helps to you.
If your problem not solved, please let me know...
Jun 18, 2011 | ASUS Eee PC 1001P Netbook
I do have a problem on my Eee pc 900 HA screen.. The half screen displays a weird different colors while the other half is okey.. what should i do with this? please help me
have you reinstalled the video driver? if you've done that and it still does it, the screen on the laptop may be going bad or the lcd panel display cable inside the laptop is pinched or bad. if the laptop is under warranty you have to contact asus tech support. if you're out of warranty, I recommend taking the laptop to a local computer shop for diagnostics/service.
May 03, 2011 | ASUS Eee PC 900 Notebook
The screen on my ASUS EEE PC 1005HA-MU17-BK just became blank. I used to connect it to a LCD, but the screen is also blank now. Please help me to fix it, or get the data from the hard desk at least. ...
if the both screen inputs are dead im pretty sure you have no way to recover form the netbook yourself.
dont lose hope though there is a way to recover your data.either remove your harddrive and obtain n external harddrive enclosure for your internal sata netbook hard drive.follow the instructions ad put the netbook drive into it and connect it to another machine. these enclosures can be around 80 bucks so if you go to a electronics store make sure you compare what models you find with that whats online.you could get a great deal. if thats too technical,the geek squad do offer a data transfer service for a fee onto anther external hard drive. its a more expensive option but it requires less hands on
Mar 08, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I just boughtthe.. Asus - Eee PC Netbook / Intel® Atom? Processor / 10.1" Display / 1GB Memory / 160GB Hard Drive - Black and i was wondering how i would sownload software into it ?
Hi, 1)Go to the below link http://support.asus.com/download/download.aspx?SLanguage=en-us 2)Under select Product,select Eee Family 3)Under select series, select Eee PC 4)Then select your model and click search. 5)All drivers for your netbook will be shown. 6)Was this useful to you ....good luck.
Nov 28, 2010 | ASUS Computers & Internet
LCD screen with weird colors and out of focus
I dont have much info for you but I hope this helps, If your LCD screen has gons through an "accident" or if it is just in it's usual old age moment, It's time to replace the screen. You can do this yourself, or you can hire someone to do it, howeven it is not that hard, Go online to find some replacement LCD screens for that model Laptop and then the rest pretty much self explanatory
May 06, 2010 | Computers & Internet
I keep getting a pop up window every 10 sec or so saying ''eee pc tray utility has encountered a problem and needs to close'' ...i have clicked Dont send, and also send error report, and still it keeps...
Click Start, Run... or press Windows Button and Alphabet R button together. On the run dialog that comes up type the word msconfig This brings up a dialog where you can use the services tab and startup tabs to remove the tick marks from the items like eee pc tray utility to prevent it from starting up again in the next restart. You can also press the end task in the services tab if you want to stop it right now. Removing unwanted items from services and startup tab will give you a faster bootup. Read more at www.fixpcfreeze.com
May 05, 2010 | ASUS Eee PC 1000HA Netbook
The screen on my son's Asus EEE PC is damaged and displays nothing but weird colors and lines. Can I connect an external monitor to the Asus without having to enter any commands (since I can't see what is...
maybe..connect the external monitor and reboot to see if the system will find it and use it. Let us know what happens.
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | ASUS Eee PC 900 Notebook
ASUS Eee PC Netbook Logo
249 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
