Question about Jenn-Air JDS9860A Dual Fuel (Electric and Gas) Kitchen Range
My oven door will not open - Jenn-Air JDS9860A Dual Fuel (Electric and Gas) Kitchen Range
    Genius:
  • 1,417 Answers
please follow this instruction to solve the door problem
Generally you will see a plastic lever that is touching both the door open button and the area of the door switches.
That lever is what breaks most often, and if you will push up on the door hooks (latch heads) , the door will open.
Pushing on the door open button repeatedly while looking inside will help you figure it out, too.
Good luck with this and thanks for using fixya.
Posted on Aug 20, 2010
When I open the Panasonic microwave oven door by pushing in the door opening button, the oven starts immediately
There is evidently a fault with the door interlock switches. Don't use it as the oven may avtually be emitting microwaves with the door open.
Get a service tech to quote you for repair as it may be more economical to buy a new one, when you will have a warranty.
Do not try to repair it yourself unless you have detailed knowledge as there are components inside which can deliver a lethal shock even when the oven is not plugged in.
Sep 30, 2016 | Panasonic Microwave Ovens
Oven has f90 error code and door stays locked cannot get oven top door
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Aug 27, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
Have a maytag super capacity plus oven i tried cleaning the oven now the door will not open and it shows f9 on the front
Had the same problem. How I fixed it, was by using a very thin, and I mean really thin, flat tip screw driver and a flash light. Unplug the stove. Use the flash light to look at the very top of the oven door. You should see in the air vent slats a silver hook. Use the screw driver to go through the vent slats and push the lock open. Now, you should be able to open your door. But we arent done yet. With the door open, plug the stove back in. Close the door and wait for the F9 to flash. Now open your door, and on the right side you should see a tiny peg sticking out on the open oven. Its for the light to come on when the oven door is open and also to let the oven know the door is ajar. Push it in and wait. The door latch circuit should reset like normal, and you will see the latch move back into its normal open position. Which resets the F9 error and allows you once again to use your oven like normal.
Dec 20, 2009 | Maytag Ovens
Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Oct 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door stuck
To open the door, raise the oven top and use a a flat head screwdriver to open the lock manually.
The door will still lock itself when you close it, so this is only usefull to get your food out.
Oct 19, 2008 | Amana AEW3530DD Electric Single Oven
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Open Questions:
Jenn-Air JDS9860A Dual Fuel (Electric and Gas) Kitchen Range Logo
82 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
