Question about Sony VPL CS2 Multimedia Projector
I have sony vpl-cs2 ,and the problem is it display only blue colour and yellow in the middle ,so i need to know what is the solution now
I connect new LG Blu -Ray On my Sony Cineza Projector.but only blue colour on the screen ,what is the problem here?
You might have to change the input or start playing blu-ray disc and then change input via the remote to your projector. Make sure it's HDMI out on blu-ray if choice is given and HDMI in on projector.
Jul 10, 2012 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Blue dots
http://www.nodevice.com/user_manual/sony/projectors1/vpl-ds100.html
Use this link to download your manual troubleshoting tips, to see if problem referred on.
Aug 09, 2008 | Sony VPL-DS100 Multimedia Projector
Sony projector vpl ex5 yellow display problem
try replacing the bul/lamp.
warning! $200 part http://www.amazon.com/Projector-LMP-E190-VPL-ES5-VPL-EX5-VPL-EX50/dp/B003ISW2KM
May 21, 2011 | Sony VPL-EX5 Projector
Sony VPL-HS50, any viewing (TV, DVD) a spread of blue appears on various parts of the screen, generally contained to the sides but from top to botom. Just recently a large yellow blotch appeared in the...
If this projector is an LCD (liquid crystal display), your LCD probably gone.This usually happens after a period of time with an LCD projector.Try cleaning the LCD or take it to your Sony dealer. yours faithfully Zkhan
Jan 30, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
My projector sony vpl cs6 projects yellow
reset the settings to factory default and change your cable. if that doesn't help, the polarizer filter on the blue lcd panel is fried due to excessive dust and heat. the optical engine will need to be replaced.
Dec 07, 2009 | Sony VPL CS6 Multimedia Projector
I have a yellow box in the middle of the screen [sony proj sc50
the light filter on the blue lcd panel is fried due to excessive dust and heat. you may need to replace the entire optical engine if you cannot find the individual piece.
Nov 12, 2009 | Sony VPL SC50 projector lamp Projector...
Focus
Hi mwwill
Try using a different cable from your source.
If this doesn't solve the problem I would advise you to rather take it to a repairer as this could be either the lens that is damaged or the Mainboard where all the processing is done.
May 13, 2008 | Sony VPL CS2 Multimedia Projector
Projector SONY VPLCS!
I had the same problem with a Sony VPL CS1. It's not the mainboard, but the blue filter - cost to repair runs around $500 US.
Hope that helps.
Mar 21, 2008 | Sony VPL CS1 Multimedia Projector
Sony VPL CS2 Multimedia Projector Logo
44 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
