Question about Canon FAXPHONE L170 Plain Paper Laser
CANON L170 - WHEN PRINTING THE TONER GETS ON THE EDGE OF THE PAPER INCLUDING LOOSE PIECES OF TONER (ONLY ONE SIDE OF PAPER) -WHAT IS THE CAUSE?
  • admin494 Aug 20, 2010
    YES - IT HAS TO BE THE FUSER - I ALREADY TRIED TWO DIFFERENT CARTRIDGES
    Genius:
  • 1,478 Answers
There are a few possible reasons that can cause this problem. First, the fuser assembly may be damaged or at the end of its life. The solution is to replace the fuser assembly. Repairing a fuser assembly is generally not recommended because the fuser is considered a consumable printer part and not worth the time or effort to fix. Second, the toner cartridge may be defective and letting too much toner out at one time, the solution is to replace the toner cartridge.
Take care.
Posted on Aug 20, 2010
Black verticle line,left side
problem will either be in the toner or fuser.
If you have a spare toner, try that first.
Feb 12, 2014 | Canon Faxphone L170 Monochrome Laser Fax...
There is a smudged side on the fax when it comes across. I have changed the toner and shaken the toner up the smudge still comes back in the same place on the fax
If this smudge is showing up on the faxes you are RECEIVING and you have changed the toner then the next most likely cause is a fuser problem. This is especially true if the smudged area feels gritty or the toner rubs off the page in the smudged area. If this is the case then you need to replace the fusing unit or have a local repair place replace the fuser "film" on your fuser unit.
Good Luck and Thank You for using Fixya.
May 11, 2011 | Canon FAXPHONE L170 Plain Paper Laser
A paper has struck in printer so its not printing how to remove the paper
1) Open the top cover
2) Remove the toner cartridge
3) Remove any paper from the multipurpose tray
4) If you can see the LEADING EDGE of the jammed paper slowly pull it out.
This may be easiest from either the multipurpose tray side or from under the toner cartridge
5) If you can see the TRAIL EDGE of the jammed paper slowly push it through the printer until it comes out
Dec 17, 2010 | Canon LASER SHOT LBP-2900 Printer
Canon Faxphone L170 prints A vertical smudge streak down whole page when printing?
It might be the fuser film thats busted,i recon the u have changed the cart?Does it make a noise when u print?
Jan 31, 2010 | Canon FAXPHONE L170 Plain Paper Laser
Strange whistling like noise coming from the toner area when printing. Prints are fine, worried about noise.
Could be a noisy toner cartridge.
Open the door, remove the toner cartridge, and close the door again. If the machine does a few seconds of motor running with no noise, then that is the cause.
Not usually a major problem, just nuisance value.
Nov 19, 2009 | Canon FAXPHONE L170 Plain Paper Laser
The Canon L170 will not grab the paper.
Yes,remove the 2 screws at the bottom of the docfeeder,then the lower side of the dockfeeder will come apart.Remove the tention spring of the separation and lift the separation upwarts,then you can install the new separation.
Jul 13, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Tonor along edge of paper on my Xerox WorkCentre XL2140df
I would think you just have another bad cartridge. have you simply tried shaking it side to side? May just be built up on one side, but those cartridges are notorious for going bad. You need to vacuum the machine out well also. That toner and developer get in all those little plastic supports and can cause toner to dump.I would say the chance of a bad cartridge again is about 95 percent.
The printing problem. Have you tried downloading the driver from the Xerox.com site? Or simply reloading the driver. Sounds like its corrupted somehow. And when you change the tray, you are clicking apply?
Dec 17, 2008 | Xerox WorkCentre XL2140df Laser Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Canon FAXPHONE L170 Plain Paper Laser Logo
353 people viewed this question
old marine
old marine
