Question about Refrigerators
Amana Refrigerator BR22VE -- freezer works, but fridge doesn't.
  • Diane May 29, 2008
    We have the exact same problem. Amana Bottom Freezer Refrigerator model BR22VE. The freezer works fine. The fridge won't get colder than about 55 degrees F. Coils are clean, the thing is humming away. Help!
  • zeek654 Aug 16, 2008
    Holy cow! I also have an Amana BR22VE with the same problem. The air return duct behind the freezer panel on the left freezes up solid blocking any circulation of air to chill the refrigerator. Worst during a string of humid days when moisture gets into the refrig. Have to remove the freezer panel and melt the ice. It's good for a few days, but inevitably returns to poor performance. It's also noisy as can be. Any remedies?
    Thanks, zeek654
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
Techsim
  • 59 Answers
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Fridge is not cold freezer works fine.
Try changing the damper settings in fresh food compartment. Your refrigerator has a control board and it is possible the board is no longer working correctly. If your board is bad I can help you locate one. If the fridge is still under warranty I would have the technician come out. He would possibly just change out the board without testing to original board. Other things that could cause problems are thermistor and defrost thermostat located inside the freezer and attached to the evaporator coil. If you continue to have problems, let me know, Thanks, Sea Breeze
Posted on Mar 24, 2009
  • 52 Answers
SOURCE: Side by side Amana freezer/fridge. When you close
Possibly need the hinges adjusted.
Posted on Jul 15, 2009
  • 35 Answers
SOURCE: Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
Posted on Jul 17, 2009
The freezer is working but the fridge part isn't
this is usually do to a blockage in the air duct from the freezer to the fridge. put food in a cooler with ice and unplug and open all doors for 12 hours. If doesn't work, need a repair man due to fan probably broken
Nov 03, 2011 | Amana AFD2535FE Bottom Freezer French Door...
Amana refrigerator A4TXNWFWWO1 >top freezer, bottom fridge it's only 10 months old refrigerator won't get colder than 55 degrees freezer is working
There is something plugging the drain line in the freezer which carries water from the defrost cycle to your evap drain tray in the bottom of your fridge. The water has built up and froze plugging the flow of air from freezer to fridge.... find the line and unplug it and let fridge sit and thaw overnight and then some more.
Jul 19, 2011 | Amana A4TXNWFWW Top Freezer Refrigerator
I own a amana fridge fridge on top freezer on bottom . all of a sudden my fridge stopped cooling the freezer still works fine I hear fans running but no cool air at all. please help me
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Amana Refrigerators
Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
Feb 20, 2010 | Televison & Video
Jul 07, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
My amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Nov 04, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
204 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
