Question about Gateway FPD2275W LCD Monitor
I have a Gateway FPD1975W 19in LCD monitor and now it won't turn on. I have checked the cables and tried unplugging and plugging it back in. The power light will come on for a second, the Gateway logo will show, and then it just goes dead. No issues with the monitor until yesterday.
  • 244 Answers
First of all check if the monitor works in another computer.
Pay attention at your computer beeps when you start it up.
If there are a series of repeated short beeps it means that there is a problem with your video card.
If there is a long beep that repeats, then its a bad memory module.
Fix one of the three, and you'll have your image back. Good luck.
Don't forget to rate this answer if it helps.
Posted on Aug 20, 2010
Gateway FPD1975W Monitor Vertical lines in the right side of the screen
Open the unit back up and check the cable that goes from the control board to the LCD panel and make sure it is plugged in securely. If this cable is not connected all the way it can cause lines on the display. Also while you are inside the unit check the capacitors on the power supply board. The tops should be flat, if you have any with bulging tops then you need to replace all of the ones on the power supply board. This can also cause display issues if the power supply is not putting out the correct voltages because of bad capacitors.
Jul 17, 2012 | Gateway FPD1975W 19" LCD Monitor
My gateway fpd1975w monitor will no longer turn on. The first couple of times, I unplugged the power supply to the monitor and then plugged it back in after 1-2 minutes and the monitor worked fine. Now...
The power supply may have finally died, I would inspect it for bad DC filter caps with leaking/bulging top/bottm seals first, then check for cold solder joints, burnt parts.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Sep 11, 2010 | Gateway FPD1975W 19" LCD Monitor
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
Same issue with no words
This is usually caused by the cable between the monitor and computer being disconnected (or partially disconnected) or damaged. Video card failure on the computer can also cause this as well. If you have access to a laptop, or friends laptop, try plugging in the monitor to the laptop. If starts working correctly, then cable was unplugged or video card has failed in computer. Also check cable connection on back of monitor.
Aug 25, 2009 | Gateway FPD1975W 19" LCD Monitor
My monitor turns on for about 2 seconds each time i turn it on and then goes black..it makes noises so i think it could be the lamp..all the connections are good and i tried that power drain thing...
Check the Inverter card (Connector between LCD Panel / Inverter card) If ok then Check the signal cable between AD board to Panel.. If ok then replace the inverter Card..
Jul 09, 2009 | Gateway FPD1975W 19" LCD Monitor
The screen on my Gateway monitor suddenly went light blue. Has anyone else had this problem or know the solution to get it back to white?
Does the screen remain the same color when you turn it off and back on, unplug it and back in, or disconnect it from the pc and reconnect it?
Jun 15, 2009 | Gateway FPD1975W 19" LCD Monitor
Computer has red tint!HELP!!!!!!!!!!
If it is under warranty, take it back. Elsewise caveat emptor.
Mar 06, 2009 | Gateway FPD1975W 19" LCD Monitor
No signal on monitor
You probably have 2 monitor connections. you have a standard one, and one that is through a graphics card at the bottom of your tower. Check for that second connection and switch the plug.. that should solve it.
Jan 02, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
174 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
