Question about Relic watch
How do I take the back off of my Relic watch to replace the battery
  • 831 Answers
Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see.
  • 2Pull out the stem, which releases the back on some watches.
  • 3Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
  • 4Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  • 5Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  • 6When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
  • Posted on Aug 20, 2010
    What size battery goes in a Relic wet ZR15373. Help please
    If you don't want to remove the back of the watch yourself, take it to a jewellers shop and ask them to help. They will remove the back, replace the battery and they should give you the number of the battery so you know for next time.
    Apr 13, 2015 | Relic Watches
    Where to find batteries for relic watches?
    Relic watches use common internal movements and common batteries. They can be found at most drugstores, radioshack and jewelry stores. The trick is getting the back off without damage. Best bet, jewelry store.
    May 26, 2014 | Relic Wet ZR11672 Wrist Watch for Women
    What is battery number for relic watch zr11811
    Just replaced the battery in my colleague's Relic ZR11811. The battery is a 371. Equivalents include AG6 and SR920.
    Apr 09, 2013 | Relic Watches
    BATTERY REPLACEMENT FOR RELIC WET WATCH ZR11657????
    If you can, pop the back of the watch off, the battery will have 3 digits, and some letters, for example 375R, 325LRW, etc. the 3 digit number is the type of battery you need. If you cannot read the number, then typically, if you take out the battery, and you measure the width, and height of the battery, then find another battery with the same measurements, it will work, trust me.
    i hope i helped!
    Jul 17, 2011 | Relic Wet ZR11657 Watch for Men
    What battery is the replacement? Relic ZR11622
    Thank you FixYa.
    Look on the back of the watch, or in the manual. If it doesnt say the battery size you will need to take to jeweler to have them measure the compartment to see what battery is needed. Sorry but no other way to know the battery needed.
    Best regards. Jewel
    Sep 19, 2010 | Relic Wet ZR11657 Watch for Men
    Does not run. does this watch have a battery in it?
    There are two types power sources for watches. Automatic and battery.
    Automatic needs to be either wound by the crown (winder on the side) or wound by the movement of the wrist while it is worn.
    The battery powered is self explanatory.
    Since you didn't include the model it's difficult to say for sure because Relic makes both automatics and battery powered watches. Although I can tell you is most automatics will clearly labeled. If your watch say automatic somewhere on the face or back you need to contact Relic for service because your watch has a 12 year warranty.
    To prevent violating your warranty a jeweler should be the one who replaces the battery if it is battery power.
    I included the link to Relic watches below for info on the warranty and instructions.
    Hope this helps.
    http://relicbrand.com/
    Nov 13, 2009 | Relic Multifunction Watch
    Mens Relic watch stopped working after battry change
    I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
    Do as folloes:
    Take out the batttery,
    Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
    Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
    Refit the battery back.
    Now your watch should work again.
    If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
    Do not forget to rate, please.
    Feb 09, 2009 | Relic 0504648FA
    Relic Watch Battery
    http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
    Apr 22, 2008 | Watches
    Relic watch Logo
    4,495 people viewed this question
    Top Relic Watches Experts
    Ansel Alberto
    Ansel Alberto
    Jim Parker
    Jim Parker
    Are you a Relic Watch Expert? Answer questions, earn points and help others
