Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
I have a Whirlpool ED20TK which came with my apt. It's the perfect size for the space but I can't find a modern refrigerator the same size. Is there a new version of this style with the same dimensions? Thank you!
Why do I have ice build up in my freezer
Ice build on the freezer box floor or White frost build up on the freezer box back wall (inside). Ice layer on floor means your drain line blocked. White frost layer means your machine is not going into defrost cycle.
Oct 07, 2014 | Whirlpool Refrigerators
Overheating of Partition in a side-by-side
pull off the bottom front kick panel and check the condenser coil to see if it's filled with dust,also pull out the machine and remove the back bottom panel and make sure the condenser fan motor is running and clean out any dust back there,if the coil is clogged with dust or the condenser fan motor isn't working is what could make that strip hot.
Aug 30, 2012 | Whirlpool Refrigerators
My whirlpool fridge is not cold enough, there is water leaking from the top. I leave a plastic bowl under to catch the water. This has to bee emptied every several days. Here is the model ET18PKXGW01. I...
We had the same problem, but the bottom of the fridge was freezing over. Took apart and blew air through the line from under fridge. Goop came out. Put back together and ran perfect!
Jul 31, 2011 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Which brand of whirlpool refrigerator should purchase
I think you want to know what model of Whirlpool refrigerator you should purchase since Whirlpool is a brand already. There are too many variables to answer this question. First off there are 100's of models to choose from. Secondly, where are you?? (dont say - the world wants to know where you are) What are your refrigeration requirements size wise? Do you need a big freezer?? Have a large or small family?? A Side by side? How big is your pocket book?? How big is the space in your kitchen for this device??
These are some considerations for you to think about as you go to the store and comparison shop.
Thank you for your questing @ FixYa.com
Mar 02, 2011 | Whirlpool Microwave Ovens
CAn you give me size specifications for the Kenmore side/side refrigerator model # 106.9512811? It was purchased in 1993 and I have the books and parts list but see no size spec. I am wanting to replace...
You would be better off measuring not the refrigerator you are wanting to replace, but the space within which it must go. If you go to the store with current refrigerator measurements, instead of the space available, you wont know what size you can get.
Aug 13, 2010 | Kenmore 54662 / 54664 / 54669 Side by Side...
I just moved into this apt and it seems the refrigerator runs all the time with a hum. It is a 2006 Whirlpool.
It is vibration of compressor. Try adjusting the balance wheels at the bottom to eliminate the sound. But some humming will still ontinues.
Apr 28, 2010 | Haier HSB03 Compact Refrigerator
I have a side by side model number ED20TK and
start over on ice. if it over fills change valve
Feb 07, 2010 | Refrigerators
Cant locate walter filter on whirlpool model ed20tk and eckmf94.
does not have one. you have to install a filter called an in line filter behing the refrigerator
Jun 21, 2009 | Refrigerators
Refrigerator runs too loud and too often
At least make sure the operating hardware and radiator is dust free, and the spacing around any radiator is not heated/has good air circulation.
Mar 06, 2009 | Hotpoint HTM17BBSSA Top Freezer...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
357 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
