Dell Pocket DJ does not charge using USB Cord
If you find none of this has worked you need to try some other decvie
in the same usb port. If it is plugged in and operates correctly, you
have narrowed it down to the dj unit. Since the chord has tested good,
we should go to the unit itself. Four tiny screws located on the
outside of the case need to be removed in order to open it. Carefully
remove the hard drive, then the battery.
Now with the cable hooked up to the usb port you will use a meter to
check some voltages. Perhaps you have a friend who can help. The
batteries should read 3.6 VDC. Measured like that its not a true
indication of the state of the batteries, but tell us that the charging
circuit is probably working okay.
Put it back together carefully, making sure every connection is
properly seated and there is no damage. Try it again, making sure you
hold down the button for 3-4 seconds. If you have done all of this, the
problem is electronic and at a component level. Suggest you take it or
send it to the repair shop dell has.
Ted
I just broke my ac adapter on my dell pocket DJ does Best Buy have one.
Thanks
