Question about Frymaster Dean GF14 Deep Fryer
Thermostat problem on gas frymaster g.f 145d no control no rise in temp is it the thermostat
Deep fryer pilot is blown out when burners go out after reaching temp
Hi there. Hi limit may be tripping off due to high oil temperature (power supplying the gas valve is connected in series with the hi limit). Verify if the thermostat is not shorted, also please check the thermostat calibration if it is good.
Regards.
Sep 16, 2013 | Frymaster Dean Kitchen Appliances - Others
With thermostat off still lets gas thru
Either the thermostat or the gas valve has failed. Locate and disconnect one of the wires going to the thermostat, if unit continues to heat the gas valve has failed, if not, the thermostat is likely stuck closed (on).
Oct 10, 2012 | Frymaster Dean SR42G Deep Fryer
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
Pilot light stays lit when I turn the gas valve to on. But nothing happens when I Turn the thermostat on. Help
The thermostat control is bad, you will need to replace the thermostat switch and everything will work just fine. Basically the thermostat switch is not sending a signal to the gas valve telling to to turn on
May 25, 2010 | Frymaster Dean SR42G Deep Fryer
Frymaster will not re-light after reaching temp on initial start
You have a lazy thermostat that needs replacing. Not uncommon.
Tom
May 21, 2010 | Frymaster Dean FM345EETC Deep Fryer
Rheem Gas Hot water Heater; Model 21130DV: temperature control dial is set to the lowest setting; water temperature still rises to a dangerous 150 degrees farenheit. Can I replace the temperature control...
yes, sounds like the temp control is bad, you should be able to google model# and thermostat to find replacement. should be fairly easy to swap out
Aug 15, 2009 | Water Heaters
Fryer not starting
I'm suspecting one of the following causes:
1. The thermo couple/thermo pile
2. Gas valve sticking, intermittant operation, doesn't snap open when required all the time. THIS CAN ONLY BE PROVED WITH A MANOMETER and specialized meter that can measure thermocouple or thermoppile current, and volt meter.
I've worked on many a McDonalds Frymaster beeping fryers that intermittantly go into ignition failure that TURNS OUT TO BE THE ACTUAL GAS VALVE FAILING TO SNAP OPEN, and hang only once in a while. Gas valves are only good for so many operations, once that has been reached start failing. The indicator you gave, IT WAS USED BEFORE YOU GOT IT makes me believe it is your gas valve!
ps: manual for your unit
http://www.frymaster.com/docs/uploaded/fry/products/OperationalManuals/819-5887.pdf
Jan 23, 2009 | Frymaster Dean GF14 Deep Fryer
Frymaster gf 14 won't come on
Ok sounds like your problem maybe that the gas valve is set to low. If you have access to a manometer you can put it on the outflow port of the gas valve and see what the reading is. It should be at 4" water column for this fryer. You possibly might even have a faulty gas valve, these will go out sometimes and still let the pilot bypass maintain regular operation. Please comment me back if you need more assistance with this.
Thanks
Jul 14, 2008 | Frymaster Dean FM345EETC Deep Fryer
Kitchen Appliances - Others Logo
56 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
