FixYa.com
Tags:
Epson Stylus CX4800 All-In-One InkJet Printer
Bluetooth dongle
posted by milly22 on May 03, 2008
I cant get a belkin BT dongle to work on a rX Epson printer - do I have to have an epson dongle. The computer and printer seem to 'pair' up but nevertheless no printing occurs
Thanks
Comment by milly22, posted on May 03, 2008
Printer is actually a epson rx585
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
Basti
Rank:Wiz Wiz
Rating: 81%, 103 votes
Not really, what operating system are you using? on the printer itself set it to bluetooth settings and dont put n a code set but set it to discoverable, then when printing dont do a file print, instead right click on the file and then on your send to option if your computer is detecting the dongle one option will say stylus rx585- then it will print it. one thing that you can check is as belkin manufacturer if their bt dongle is compatible with epson, and FYI bluetooth printng is for photo printng only. doesnt look as good if you are going to print a document or text docs..
hope this helps, and if you have inquiries email me back
if it solved your issue pls rate as fixya, thanks!!!
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Printers problems?
EPSON quit printing
My printer will not print even... Answer This...
epsonrx 425
general error i cant start it... Answer This...
Foreign object
General Error shows up with... Answer This...
Error Light does not turn off!
I recently had a paper jam, the... Answer This...
epson all in one
when i try to photocopy it does... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
