Question about Whirlpool Duet GHW9150P Front Load Washer
Mine has F21 blinking. What is wrong? - Whirlpool Duet GHW9150P Front Load Washer
    President:
  • 1,382 Answers
When F21 error code appears press PAUSE/CANCEL two times to clear the display.
Also check for the following issues
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Thank you !!
Posted on Aug 20, 2010
2001 KIA sportage down shifting by itself and the hold light keeps blinking what could be wrong
a blinking hold light means the transmission control sensor is telling the engine cntrol sensor that something is wrong. Usually it is nothing too serious, mine has been doing it on and off for years, go to a transmission shop that offers free or cheap diagnosis, get several opinios before spending a lot of money
Dec 31, 2014 | 2001 Kia Sportage
Have a code F21--What is wrong and how do I fix it?
This site has a good solution, assuming this is your brand name of machine... but the solution might apply to you otherwise:
http://www.managemylife.com/mmh/questions/230239-front-loader-washing-machine-whirlpool-duet-broken-says-f21
Oct 18, 2013 | Washing Machines
What does F21 mean?
The "F21" error code indicates it takes too long for water to pump out of the tub. This can be caused by using too much High Efficiency detergent or using too much of the wrong kind of detergent. This error code can also be caused by debris clogging the drain pump. Is the error continues after you clean the filter, then you will need to replace the drain pump with this new one.
Oct 20, 2012 | Kenmore Elite HE5t Washer
My 53 Inch Pansonic TV does not switch on. What would be the cause ?
Does the power light blink? If so let me know the number of blinks snd I can help you determine whats wrong.
Jun 02, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Power light blinking 10x
It's not necessarily the power board. 10 blinks is the Miscellaneous error code. Your TV knows something is wrong, but isn't sure what it is. It can be any number of things, including bad boards. Mine, personally, was multiple bad boards.
Dec 22, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
WASHER HAS F1 ERROR CODE
the f1 code turned into a f21 code. if you take off the front panel of the washer the manuel is in there it tells you how to reset it by pushing 4secs, releasing 4 secs for three times. To fix the F21 code unscrew the white drain after taking the front panel off and clean the drain. it will be cloged with lint, coins, bobby pins and whatever else can fit in there. LOL 10 minutes and it will be fixed like mine was, hopefully.
Nov 26, 2008 | Kenmore HE2 Plus Front Load Washer
I am getting error code F21
hi there,
the F21 error means the communication between the touchpad and the control board behind it.
here is what you do:
unplug the washer
check the wiring harness betweeen the control board and the touchpad
make sure there is no corrosion on any connectors on the control board
check for any obvious burns or kinks on the control board & harness
if all of the above checks out okay, i would start by replacing the keypad first
let me know how it turns out.
Sep 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch classixx6 1200 express
my classixx6 1200 express is flashing f21? what is wrong with it?
May 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
79 people viewed this question
Dan Webster
Dan Webster
Sal De
