Question about Respironics Health & Beauty
Hello, My Respironics remstar pro is way out of warranty. I get an alsrm and a message that says System error 14 motor current. Serial number is 1594709 I packed it and drove out od town and when I plugged it in this happened but it quit and worked fine for 3 nights and now it is doing it again and will not stop. I did the troubleshooting and it did not help. I can not afford a new maching, I have no insurance and no warranty. I hope you can help meget it repaired. Thank you, Doris Godfrey 817/713-9098 dorisgodfrey@sbcglobal.net
  • 1314 Answers
SOURCE: warranty registration
try here http://www.registration.whirlpoolcorp.com/register/default.asp whirlpool owns maytag now
Posted on Jan 25, 2008
  • 62 Answers
SOURCE: I get
did you try this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02180&cc=us&lc=en&dlc=en&product=441125#Clean_Cart
Posted on Apr 15, 2009
  • 73 Answers
SOURCE: sony kv30hs420 turns on and off again after 3 seconds
replace ic8001 and ic8002.generic part#mcz3001d
Posted on Jul 14, 2009
Davethesnake
  • 689 Answers
SOURCE: Dell Inspiron mini - received
reinstall your OS from disc this should cure this problem
Posted on Sep 09, 2010
  • 1796 Answers
SOURCE: I would like to obtain
Unfortunately, the company do not have manuals available to non owners, in order to get one, you need to register and provide the machine Model and Serial no., etc. they claim all the information you need is found on the following site http://www.cpap.com/cpap-faq/Machines.html . I checked the site and under the machine's picture there are some tabs you should browse. They also have videos on how to use and maintain the CPAP machine.
If after checking the site, you still feel you need a manual, click on the CONTACT US tab on the top right of the screen to request one.
Good Day!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 17, 2010
Harley trouble codes
There are two types of diagnostic trouble codes (DTCs), current and historic. The Check Engine Lamp will not indicate the existence of historic trouble codes.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
Aug 11, 2014 | 2000 Harley Davidson FLHRCI Road King...
I have a code E-35
Just so you know there is a recall on this and may end up with a new one... read below
Respironics, the manufacturer of the Respironics REMstar Heated Humidifier, has received complaints of failures of the AC inlet connector on the REMstar Heated Humidifiers manufactured between December 2001 and April 2003. A small number of these failures have resulted in thermal damage to the humidifier enclosure, and there is a remote possibility that a thermal failure could result in the ignition of materials external to the device. For this reason, Respironics is asking that you remove the humidifier from its power source. You may continue using your CPAP device.
Respironics has decided to take voluntary action to mitigate the risk of failure. This action includes only the model 1005792, U1005792, R1005792, SC1005792, AC1005792, and 1007861.
This voluntary action is classified as a medical device recall, and is being conducted with the knowledge of the United States Food and Drug Administration (FDA).
WHAT TO DO:
Call Stericycle, Inc at 877-574-5038 or 317-275-7667.
Jul 02, 2014 | Respironics Remstar heater humidifier -...
2003 harley softail will not start
Did you pull any error codes (Diagnostic Trouble Codes)?
1. Remove right side saddlebag and side cover if so equipped. Remove protective plug from data link connector. Other models will be under the seat.
2. To activate the diagnostic feature,follow these steps.
a. Create diagnostic test wire or use a female spade clip which will bridge the two terminals perfectly.
b. Install diagnostic test wire/clip across Terminals 1 and 2 on the data link connector, they are marked.
c. Turn Ignition/Light Key Switch to IGNITION and wait approximately 10 seconds (4 seconds lamp ON, 6 seconds lamp OFF) for check engine lamp to start flashing.
3. All trouble codes are sent out as a series of flashes. To retrieve the first digit of the trouble code simply observe the number of times the lamp flashes.
a. The lamp will then flash one or more times to indicate the first digit of the trouble code.
b. The length of time the lamp is illuminated and the length of time in which it is off are each about 0.5 second in duration.
4. The second digit follows:
a. Following the transmission of the first digit, there is a 1.2 second pause in which the lamp is off.
b. The lamp will then flash one or more times to indicate the second digit of the trouble code. Count the number of times the lamp flashes to retrieve the second digit.
5. If more than one trouble code is sent:
a. Following transmission of the second digit of the first code, there is a 3 second pause in which the lamp is off.
b. Once all codes have been sent, the data string is repeated. When you have recorded the same trouble code twice, it is an indication that the transmission has been restarted and that all trouble codes have been retrieved.
IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A "trip" consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diagnostics manual you're not going to know what they mean.
21 Current 12 MAP sensoropen/low
22 Current 12 MAP sensorhigh
25 Current 15 IAT sensorvoltage low
26 Current 15 IAT sensoropen/high
27 Current 24 Front ignition coilopen/low
29 Current 24 Front ignition coilhigh/shorted
30 Current 25 Rear ignition coilhigh/shorted
56 Current 41 Ignition switchopen/low
74 Historic 12 MAP sensorhigh
77 Historic 15 IAT sensorvoltage low
78 Historic 15 IAT sensoropen/high
79 Historic 24 Front ignition coilopen/low
80 Historic 25 Rear ignition coilopen/low
81 Historic 24 Front ignition coilhigh/shorted
82 Historic 25 Rear ignition coilhigh/shorted
Dec 28, 2013 | 2003 Harley Davidson FXST Softail Standard
Retrieve codes for 2003 road king
2. To activate the diagnostic feature, proceed as follows:
a. Create diagnostic test wire or use a female spade clip.
b. Install diagnostic test wire across Terminals 1 and 2 on the data link connector.
IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A "trip" consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diognostics manual you're peeing into the wind.
10 43 Loss of power train security status
Apr 11, 2013 | 2003 Harley Davidson FLHRCI Road King...
Machine turns off
There are thermal overloads which protect devices. When it shuts down it cools down and will start up again. Check your inlet filter if you have lost your manual here is the on line version http://respironicsremstars.respironics.com/PDF/REMstarPlusUserManual.pdf
Feb 05, 2013 | Respironics Remstar Plus
Torn yellow ribbon - Model 950 Respironics Oximeter
I sounds like the wire that connects on of the sensors is severed. If your still under warranty, I would contact respironics for a replacement or repair. The wires are normally soldered to the sensors so if your have the equipment and ability, you can try to install new wires. Look for a red light if you don't see it where the finger goes, your suspicions are probably confirmed. Most the time we find it easier to replace the oximeter. Here is a site that allegedly has all the finger oximeters available
Aug 09, 2009 | Respironics Finger Pulse Oximeter 1 year...
Xerox 8560 printer error message
That is a fault in the process drive motor area.
It is the assembly that operates the maintenance kit movement.
You may simply have to reseat the maintenance kit.
The motor drive train may also be mistimed. If you have purchased that machine in the last year, there is a one year onsite warranty on that product. If so have your serial number ready and call 1-800-835-6100.
Aug 11, 2008 | Xerox Phaser 8560DN Laser Printer
Health & Beauty Logo
263 people viewed this question
Top Respironics Health & Beauty Experts
David Payne
David Payne
 Bob S
Bob S
Level 1 Expert
Are you a Respironics Health and Beauty Expert? Answer questions, earn points and help others
