Question about HP Pavilion 110-1030NR Notebook
I have a HP mini 110. It has no CD drive. A virus has hit it and I cant do anything with it. How can I wipe out the computer and restore it back to factory default setting little it was when I first got it?
  • 244 Answers
The HP minis, have a hidden parttion where they store the RESTORE tools.
Try to start it in SAFE MODE and see if you can run the tool from there.
Also, see if at start up (black screen with white letters) there is a message to press a special Function key (F1, or F10, or another) to start the RESTORE process.
When you finally get it done, look into www.labellpcsolutions.com
You wont have to deal with this problems ever.
Don't forget to rate this answer if it helps.
Posted on Aug 20, 2010
2 Suggested Answers
SOURCE: I have a HP mini 110. It has no CD drive. A virus
how can i get a virus off my hp mini notebook if my mcafee is infected?
Posted on Jun 14, 2010
My hp mini 110 will not load and gives me an error \system32\hal.dll is missing or corrupt
Give this a try you probably have a virus..
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
Sep 07, 2012 | HP Mini 1000 Netbook
Hp 110 mini start up repair not working
the battery does not come out easy on mini.
so you cant test it on line power pack only
if had this problem. (i have a mini that i hate, and parked since new)
id pull the battery and test it now.
the HP.com has the full set of manuals,
read that and shows how to remove the battery
old batteries short, and keep the LT dead.
case 2
battery is ok,
so on the same hp page
see how to make your only recovery media, cd /or stick
do so and reload OS
with no restore point set (you failed to do so, say one time every 6months) then they are not there.
so is a waste of time.
use HP offical recover media method stated on YOUR LAPTOP
many PCs are full of virus or a bad HDD.
even the recovery partition cab be bad, so
out comes RECOVERY MEDIA, there is no other way.
unless using a clean MS install l.... and then tons of hp drivers.
Mar 06, 2017 | HP Mini 110-1037NR Netbook
My mini netbook has virus and it is not letting me to open anything. i have macafee on it, but still unable to do perform anything. How i can remove the virus from netbook? OR how can i restore it to...
Be sure your firewall is activated. You can chose to use the windows firewall pre-installed on your Netbook or you can activate the firewall in you anti-virus package.
Run a cleaning software designed for detecting spyware on a regular basis to maintain Netbook processing speed and to remove items picked up by your Netbook while surfing the web. CCleaner is a solid free version of spyware cleaner.
If you suspect malware on your computer because it is running slowly, has strange pop ups or the anti-virus software detects it, then download software designed to find spyware and eliminate spyware. Malwarebytes Anti-Malware, A-squared Free and SuperAntiSpywate Free are free versions of adware removal tool to consider. These tools get rid of spyware when used individually or in tandem. Continue to run the software until all spyware, viruses and malware are removed.
How To Use the Restore Factory Settings CD
1. Make sure to transfer all of the files you want to keep to a USB memory stick or burn to a CD.
2. Put the Restore Factory Settings CD into the CD drive. This CD was packaged with your computer.
3. Confirm you want to restore the factory settings. The computer will begin restoring all settings. Don't disturb your computer, as this process can take several hours. .
4. Reboot the computer to complete the process.
Jan 30, 2011 | HP Mini 1000 Netbook
How do I restore an HP Mini 110 Computer
To restore the original operating system and programs using the System Restore utility that is installedon the device, follow these steps:1. Turn on or restart the device, and then press the esc key repeatedly while the "F10 = BIOS SetupOptions" message is displayed in the lower-left corner of the screen.The "System Restore" page opens.2. Use the arrow keys to select System Restore, and then press enter.3. Follow the on-screen instructions to restore the system.
Doing this will wipe the hard drive.
Use the following link to download the service guide manual if needed.
http://h10032.www1.hp.com/ctg/Manual/c01895806.pdf
Dec 06, 2010 | HP Mini 110-1037NR Netbook
I have a HP mini 110. It has no CD drive. A virus has hit it and I cant do anything with it. How can I wipe out the computer and restore it back to factory default setting little it was when I fisrt got...
Does it not have a recovery partition? If not only way is to install an operating system on a USB flash drive and make it bootable but you will need a CD to start with to copy the files to the flash drive. Instructions for doing this are all over the internet. Just google "boot from a flash drive" Cheers from Scott
Apr 19, 2010 | HP Pavilion 110-1030NR Notebook
How to wipe out HP mini hard drive
To restore your hard drive using Disaster Recovery, follow the steps below.
1. Shut down and power off your HP Mini if it is not already powered off.
2. Connect an external USB optical drive to the HP Mini.
3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc.
4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer.
5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.
Mar 28, 2010 | HP Mini 1000 Netbook
I need to restore my HP mini 210 to factory settings
try pressing f11 on boot up to see if you have a recovery manager insalled
Feb 20, 2010 | Computers & Internet
How to Reset HP Mini 1000 Laptop BIOS?
http://laptoppassword.blogspot.com/2011/06/hp-mini-password-service-compaq-mini.html
Clear Bios Password for HP Mini - Compaq Mini:
HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a similar [System Halted] message with 10 chars Error Code. (e.g CNUXXXXXXX, 2MCXXXXXXX....)
Jul 16, 2009 | HP Mini 1000 Netbook
How do i wipe my computer so it goes back to factory settings
When you purchased your computer the provided you with Either a Restore CD or A partition where you could restore your computer back to the way you got it from the store.
A. The Restore CD all you would have to do is put it in your CD Drive and boot to the cdrom. Once it boots up to the cdrom it will guide you through the restore process. Understand though anything you had before you started using the computer will be gone, so if you want to save anything you will need to save it before you run the Restore CD. Don't be intimidated by using the restore cd... it is made to be pretty simple. Basically you put the cdrom in answer a couple of easy questions and let it run. It will save you some money if you do it yourself.
B. If you have a restore partition you will have to look as you are booting up your PC to see if it tells you to hit a certian key to restore PC. Once you hit that certain key follow the above steps above.
If for some reason you don't have a restore cd or a restore Partition, call the manufacturer and they will send it to you for a nominal fee. I just ordered on for my cousin from Dell and it cost $19.00, and ofcourse if you ever have to wipe your drive clean again you can use the same cd.
I hope this works for you, don't be intimidated!!
Sincerely,
cdixon18
The Man Inside The Machine
May 16, 2009 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
HP Pavilion 110-1030NR Notebook Logo
779 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
