Just purchased R780 but the advertised backlit keypad feature is not working. the 4 lights on the touchpad work and the on/off button is illuminated but I understood there was more backlighting which I wanted to use in low light situations. thanks
  • 2,841 Answers
Sorry you are mistaken as the keypad is not backlit. The lights you see at all 4 corners of the touchpad are all there is. If you are not happy with the laptop and were under the impression it had a backlit keypad, return it for a refund.
Posted on Aug 20, 2010
Is there a way to lock keyboard while entering data
The Hidden Numeric Keypad on Your Laptop - For Dummies
www.dummies.com/.../the-hidden-numeric-keypad-on-your-laptop.html
The key to finding a laptop's numeric keypad is to use the Num Lock key. ... It's great for entering numbers or working a spreadsheet, but rather frustrating at other ...
windows 7 - Touchpad does not respond when I am holding ...
superuser.com/.../touchpad-does-not-respond-when-i-am-holding-key-o...
Mar 11, 2012 - Is there any way I could check what is wrong with my laptop? ... holding Space works fine for a normal click for entering the number in non-pencil mode. ... The mouse may work while pressing these keys. .... tour help blog chat data legal privacy policy work here advertising info mobile contact us feedback ...
Oct 27, 2015 | Computers & Internet
My touchpad scroll bar on my Gateway NV57H73u Laptop is not working. The touchpad itself is working though. Can anyone help?
Some laptops/notebooks [weight is the difference between the two], sometimes if you've tapped on the touchpad, it can activate or deactivate features. However, if you're running windows 8, be careful with window updates since they have been known to screw up your PC.....
Feb 05, 2014 | Gateway NV57H73u Laptop Computer With...
What button on my rca universal remote (rcrn04gr) to set the time recordings after info put in for time recording on my emerson dvd/vcr (ewd2203). The original remote you push t-set button before and...
Most of these universal remotes don't always have the same features as the original remote. I usually just keep the old remote for just that purpose---to set the T-Set. Otherwise, sorry.
Oct 05, 2013 | RCA RCRN04GR 4-device universal remote...
Toshiba touchpad frozen!
Check for a switch for the touch pad.
Jun 15, 2017 | Toshiba Satellite(R) L655-S5115 Laptop...
The keyless entry pad on my 2007 Lincoln MKX just quite working all of a sudden. All but one of the buttons illuminates when pressed. The auto unlock button on my key works fine. Any ideas? Thanks!
This should still be covered on your 4/50 warranty. It osunds like a bad keypad. Dealer can pull fault codes with scanner. Do you have ESP cintract also for more years and miles coverage?
  • The keyless entry keypad illumination is inoperative
  • Circuitry
  • Keyless entry keypad
  • SJB
Aug 03, 2011 | 2007 Lincoln MKZ
Want to know if cs6319-4 VTech cordless phone has bluetooth capabilities?
No........
CS6319-4 Features:
  • New DECT 6.0 Technology
    - Interference Free Communication
    - Increased Clarity / Enhanced Security
    - Wider Range / Network Friendly
  • 1.9GHz Cordless Phone
    - Dedicated for Cordless Phones by the FCC
    - 30% Battery Life Increase Over 5.8GHz
  • Caller ID / Call Waiting
  • Expandable Up To 5 Handsets
  • Wall Mountable
  • Handset Speakerphone
  • Backlit LCD Display
  • Backlit Keypad
  • Name / Number Caller ID Memory
  • 100 Station Phone Directory / Dialer
  • Conferencing
  • Selectable Ringtones
  • Handset Volume Control
  • Handset to Handset Intercom
  • Call Transfer
  • Last Number Redial
Jun 03, 2011 | Vtech Lands Phones
Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
Aug 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Key Pad Entry does not work
does the key pad light when you press a button at night? If yes, the fuse is ok.
Do you have the plastic card with the permanent code in your owner manual packet? If yes, tryit.
report back.
Keyless Entry The keyless entry keypad is hardwired to the GEM. The GEM interprets the inputs from the keyless entry keypad and then controls the associated operation. The keyless entry keypad will be illuminated for five seconds when any button is pressed. Additionally, it will request the illuminated entry feature to turn the courtesy lamps on. If a lock all doors code is entered, the illumination will turn off, as well as request the illuminated entry feature to turn off the courtesy lamps. When pressed, the keyless entry keypad supplies the ground signal to the GEM or the GEM receives a signal from the keyless entry remote transmitter. Then the GEM outputs a ground signal to the appropriate lock or unlock relay which supplies the power to the actuator to lock or unlocks all doors, including the luggage compartment. The keyless entry remote transmitter also unlocks the liftgate or activates the panic alarm by sending a signal to the GEM.
--------------------------------------------------------------- Visual Inspection Chart Mechanical Electrical
  • Keyless entry remote transmitter
  • Central junction box (CJB) Fuse F222 (20A)
  • Circuitry
  • Generic electronic module (GEM)
  • No communication with generic electronic module (GEM)
  • Generic electronic module.
  • Circuitry.
  • REFER to Section 419-10 .
Mar 08, 2009 | 2003 Ford Taurus
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
