Question about Maytag Washing Machines
I got a front loader washer 3000 series.If I wash big loads or comforters, ( king) it will not spin at all.
  • j_berkvens Aug 20, 2010
    why does my washer not spin heavy loads
  • 6,784 Answers
HI. The Maytag 3000 series is a middle capacity front load unit and not a super capacity unit. The motor and motor controller are not designed to handle large "king size" comforters. This stress, along with the added water weight, will overheat the motor,thus, tripping the thermal load protector mounted on the motor. This signal will shutdown your motor during a high stress spin. If you continue to wash that comforter in your current unit, you will risk burning out not only your motor, but the actual controller, as well. Remember; You should always take in to consideration that the water added to the comforter will double the wight of the object. You must calculate the capacity with this in mind. Motor replacement procedures can be very expensive, so watch your capacity level and pay close attention to how you operate your unit.
There is nothing mechanical or electrical in the unit that is damaged or broken. You are simply overloading it passed its capacity level.
Posted on Aug 20, 2010
  • 10,865 Answers
Definitely return this machine as it simply does not meet your needs. j.
Wash down
Since down comforters are very light in weight, they confuse energy efficient front loader washing machines in how much water to add. Therefore, very little water is used, which results in a semi-damp comforter at the end of a wash. Pre-soaking the comforter beforehand would help, however, now the comforter weighs a ton, and the machine will vibrate like crazy during a spin cycle. It may be better to have the comforter dry cleaned.
Apr 28, 2014 | LG WM1812C Front Load Washer
Troubleshooting kenmore washer front loader 417 390 12890
basket rubbing to the door gasket ..could be bad bearing or broken spider
Mar 01, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My front loader washer gets stuck on its last spin and wont drain properly. I am trying to wash a comforter and blanket. This is the 1st time its happened. Thank you
You may to mention the brand and model of machine. Mine is an Lg, I just shut off machine. Turn it back on and then press the no spin and start, this drains the washer. You may have too much clothes in the machine.
Mar 06, 2011 | LG WM-2277HW Front Load Washer
Kenmore series 80 top loader washing machine 11029852991. When turned on spin cycle, makes a loud grinding kind of noise. I believe unit may have been overloaded with three kingsized bedsheets &...
unless some thing inside the washer is broken i would say the drum bearings have started to wear out badly,,,my washer will easly take 3 king size bed sheets and covers,,,that not a lot realy,,,how old is your unit? and how many washes has it done,,,years old and 1000's of washes?
Jul 16, 2010 | Kenmore Washing Machines
Kenmore front loader not draining.
Hi, UNPLUG the washer and shut off the water. Remove the lower front panel and you can access the water pump. You will need a wet/dry vaccuum to **** up the water as you open the sump cap on the pump. Spmetimes you can lower the drain hose into a bucket and get water out. Once the water is removed, open the cap and see if the filter is plugged as well as the pump inlet/outlet ports. This is common. If there are no obstructions, check voltage to the pump. it should get 120V.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer that's noisy when it spins
on most kenmore front loader after some time the bearing start to wear and the washer will get louder and louder,it is a big repair job!-mike
Mar 23, 2009 | Kenmore HE2 Plus Front Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
I washed some comforters and the machine will not spin . The mach
sounds like the heavy load broke the coupler. It is what connects the motor and transmission. it should still pump the water out because the bump is attached directly to the other side of the motor.
Dec 08, 2008 | Kenmore 23822 Top Load Washer
Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Aug 31, 2008 | Maytag MAH2400A Front Load Washer
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
95 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
