Question about MTX Thunder 1501D Car Audio Amplifier
Hi dears. My MTX power amp blow the fuses and 4 mosfets D522AN... Why tihs is hapened? Regards.
5 Suggested Answers
  • 113 Answers
SOURCE: MTX Thunder 8302 Car Audio Amplifier
could be bad mosfets or outputs, needs replace
Posted on Aug 08, 2007
  • 3 Answers
SOURCE: fuses
check you spkr wiring in put if they are cross
Posted on May 26, 2008
  • 35 Answers
SOURCE: help!
You probably need to run 4 gauge wire if not already done so, and check the fuses on the amp, add the fuses together then buy the right fuse rating for the fuse connected under the hood
Posted on Sep 16, 2008
Ganx
  • 113 Answers
SOURCE: Unit blows the fuse on power up. This happened
Hiya try
http://www.icpowerx.com for the Mosfets, you will probably need to replace driver transistors also (not always but sometimes they go). Also check the resistors to output, they will be the big white ones.
Go here to read on testing FETs
http://www.4qdtec.com/mostest.html
Just to be sure. If one is blown, replace all
Posted on Jul 15, 2009
Ihave a keenwood kac 7252 amp that is running two mtx thunder 4500 12`s but amp fuse keeps blowing at higher volume why?
1.-check proper heat sink, or dissipation.
2.- check speaker impedance. Must match between amp and speakers.
3.-low power line on the house may cause low efficience work on the amp, overheat, and finally fuse protection.
4.- finally, check speaker wires. Thin cable overheat amp too.
Nov 23, 2014 | Kenwood Kac-7252 2-channel 1000watt Power...
Fuse apx200m
HI,
If the fuse is blowing of then there is problem with the inverter stage of amplifier. There is an inverter stage in the amplifier to boost the 12V to + or - 30 to 40V normally. Its a switching circuit normally uses Mosfets and ferrite core transformer and a driving IC. If the mosfet is shot then the fuse will blow off immediately after power is connected.
Check on thing remove the REM connection and then connect the power. If the fuse blows the there is fault with the Mosfet Its short.
If the fuse blows only when you connect the REM then the amplifier stage is faulty.
Also check by disconnecting the speakers. if any of the speaker is faulty then there is a chance for fuse blow off.
Ajin
Apr 27, 2012 | Clarion APX280M 2-Channel Car Amp
Can I use 8 gauge wire for my mtx rfl600
  • No, this is far to powerful of an amp to use 8 gauge. Use 4 gauge copper stranded wire. Using stranded copper wire is best for performance. I recommend a 100amp fuse being ran inline no more than 6 inches off the positive battery terminal as well.
  • You can use a 6 gauge copper stranded wire one one condition and that is if you use only a 4 Ohm speaker. Anything above that you need to go up to 4 gauge.
Regards, Tony
May 23, 2011 | MTX RFL600D Car Amp
Keeps blowing the fuses
More likely to have shorted out MOSFET ( for the DC to boosted DC power supplies) and Output transistors (for the audio outputs) which are mounted on the heatsinks, you should see a bunch of 3-leg devices attached to the heatsink, very time comsuming to repair.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 25, 2010 | MTX X Thunder 300XD Car Amp
I have an mtx thunder 81000 d the inline fuse keeps popping
When installing an amplifier of this size and current draw - the fuse is NOT ON THE AMPLIFIER.
This particular amplifier has a built in thermal shutdown protection only.
If the INLINE fuse is failing... only 2 things that would cause it....
1. Fuse rating too low - The current draw + wire resistance is greater than the fuse allows.
2. There is an immediate ground situation. There may be a screw though the power wire - the wire may be worn where it enters the firewall - or there may be a strand or 2 of wire jumpering from the Power terminal of the amplifier to the chassis (of the amplifier)
The recommended external fuse rating is 150A for this amplifier. Please be sure you are using the proper fuse for the amount of current draw this amplifier requires.
If there is an additional amplifier drawing from this feed - add the fuse rating of that amplifier to the INLINE fuse.
ALSO - be sure your wiring is of the proper gauge. I/0 wire is necessary in this instance - (or 2 runs of 4GA) as it has less resistance to the current. Utilizing an insufficient power wire will also lead to the INLINE fuse blowing.
If you have additional questions or concerns - feel free to ask.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 15, 2010 | MTX Thunder 81000D Car Audio Amplifier
Kenwood KAC-729S keeps blowing fuses. Checked all cables, re-ran power, remote, and ground. All good, still blows them at power-up.
Hello opey_69a,
Here are the troubleshooting steps for fuses blowing.
1) Remove all wiring except ground, power and remote and see if the amp powers up without blowing the fuses. If it does, the problem is in the input cables or speaker wiring.
2) The use of loudspeaker impedances below the recommended minimums will cause the amp to draw excessive current - check.
3) A shorted or grounded RCA cable may cause the fuses to blow - check.
4) If an amplifier fuse blows continually, with only +12 volt, ground and remote leads connected, the amplifier is probably defective, most likely shorted output MOSFET's. In this case the amp needs professional repair or replacement.
Hope this helps.
Sep 19, 2009 | Kenwood KAC-729S Car Audio Amplifier
Amp shutoff while playin
It may be a mosfet in the power supply section that is blown. These parts are usually available from electronics part suppliers. Or it may be one of the amplifer transistors that is blown and it will also usually be available from parts suppliers. This fault is usually caused by battery voltage dropping to low so the amplifers output starts to clip and put D.C on the mosfets causing them to blow.
Sep 19, 2009 | MTX MXA8001 Car Audio Amplifier
I got an amp and as soon as i put the fuse in it blows even with the deck of all wiring is correct and i hear a thump from the subs when i put the fuse in, the subs work good on a diff amp
Sounds like the amp is blown. Is it the fuse at the amp that blows? or the one at your battery? disconnect the ground and power wires from the amp and check for continuity between the ground and power on the amp terminals. you should have no continuity, and if you do i would check for a shorted power supply mosfet. try disconnecting all speaker wires, rca's, and remote power and see if it still blows. If it does its a problem in the amp, probably blown mosfets.
Jun 30, 2009 | Car Audio & Video
Aug 05, 2007 | MTX Thunder 8302 Car Audio Amplifier
My 7801 doesnt turn on
check pwm circuit amps turn on with 3-4 volts on mosfet gates ic 494, 5252or 555 controll these.hit me up for more
Apr 03, 2007 | MTX THUNDER7801 SUPER AMPLIFIER CLASS D...
MTX Thunder 1501D Car Audio Amplifier Logo
42 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
