Question about Woods 2C 24 Hour Indoor Mechanical Timer (59200)
Is the on position for the little levers up or down? Thanks
  • 12,061 Answers
Hi, well when the lever is DOWN, that is set to NOT trip the contact. So you depress ALL of them for the time period required, leaving them UP for the period wanted, then will then Turn ON & OFF when it rotates round to end/beginning of these, levers
Posted on Aug 20, 2010
Feed dog is in down position and cannot be raised.
lower it again and when raising it jiggle the hand wheel a little. That should get it engaged for you.
Mar 14, 2013 | Sewing Machines
I don't understand the way the lever works when you place the pump on the tire valve to inflate more air. Is it supposed to stay in the down position or the straight up position to lock it on the valve...
Before putting the pump on the valve turn the attachment so you can observe inside it. Move the lever back and forth. Observe at what position the lever causes the fitting to constrict and hold on to the valve. That is the position it should be in when you attach to the valve. I'm not certain but I think you will find that the fitting is able to be used for both presta and schrader valves without adjustment. Just put it on and fasten with the lever. The seal is then established.
Oct 03, 2010 | Blackburn Air Tower Floor Pump
Tefal avanti hi speed 4 slice toaster one side not working, Not staying down Left side right side ok
When the push down lever hits the bottom it pushes another little lever which makes contact with the positive and negative terminals. over time, these terminals get ever so slightly bent, especially if you start pushing the lever down hard. what you have to do is take the toaster apart, get to the positive and negative terminals and pinch back into shape with some pliers. you should understand once you look at it. Then put back together. if it doesn't work then it's likely a component has gone so, unless you have a multi-meter and a soldering iron I wouldn't suggest doing this.
Oh yeah, unplug it before you do anything.
Jun 03, 2010 | Tefal Avante Deluxe 4 Slice Toaster
My 2001 Dodge Caravan's transmission is stuck in reverse.
Things haven't changed much...look on top of the transmission in the engine compartment and look at the shifting linkage. Look for anything that could be interfering with the shifting. One linkage is the cable to the Shift Lever and Rod that goes down into the transmission. Remove the cable adjustment screw.
Move the shift lever rod towards the front of the Van into the Park Indent Position. Place the Driver's Position (Dash) Shift Lever into Park and then reconnect the Cable to the Shift Lever and tighten down the cable adjustment screw to 70 in-lbs.
Check operation's
Let me know if this helped, or if you have any additional information, questions of problems, Feel free to contact me at FixYa.com!
Jan 25, 2010 | 2001 Dodge Caravan
Rear seat jammed in the up position
Try the lever on the side of the seat next to the door.
May 03, 2009 | 2002 Mitsubishi Montero
Every sd card that i put in the camera it is saying the card is lock. i have tried and even buy a new caed but still saying that the card is lock how can i fix this problem thanks
Hi:
Make sure that the little lever or slide switch on the side of the card is in the right position.
As you look at the card with the contacts facing down, the switch should be set to the lowest position.
The SD card can be set to write-protect by moving the switch or lever up.
If that is not working, then there is some problem with the camera.
Jun 22, 2008 | Pentax Cameras
Icemaker only dispenses crushed ice, not cubes
There is an opening next to the auger that dispenses the ice.  In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed.  Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Viola! Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
check it out!  Thanks to Jake!
Apr 03, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Lexmark X83 "Unlock Scanner" error
I had the same problem and the solution is this: There is a red lever switch by the power chord on the scanner/printer. Above this red lever switch is the drawing of a lock in the "locked" position and at the bottom this red lever switch is the drawing of a lock in the "opened (unlock)" position. The lever on the red switch should point to the "opened" lock symbol (unlock). It the switch lever is pointing to the "locked" position of the lock symbol, flip it to the "opened" position and recycle power on the scanner by removing the power chord for a 30 seconds. If the lever is pointing to the "unlock" lock symbol, flip it to the "locked" position and then back to the "unlocked" position and recycle power. Good luck!
Oct 13, 2007 | Lexmark X83 All-In-One InkJet Printer
Woods 2C 24 Hour Indoor Mechanical Timer (59200) Logo
48 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
