Question about Toshiba Satellite A105 Notebook
No sound at all. all drivers are good, all volumes are good but no sound.no even system sounds.please help
    Novelist:
  • 137 Answers
Bad News boy, Since you already checked the drivers and teh volume option. which makes it eaasy for us to identify the root cause of the problem.
So try these steps.
1. Check in sound and audio device properties in control pannel, if you have the correct audio device listed. also check if nothing is on mute in volume control.
2. if its not the correct one. i suggest remove the existing driver from add and remove program and then try reinstalling it.
3. If thats the correct one, then Check if the external speakers / head phones produce sound.
4. if yes, then everything is fine in the computer, Don not do anything as all the software is fine.
5. If no, then the internal speakers have gone bad, which is ver rare, but it may happen.
Consider replacing the internal speakers,
I am sure this will help you.
Best of Luck!
Please rate this solution, if you find it helpful. :)
Thanks.
Posted on Aug 20, 2010
  • Toshiba Expert
  • 560 Answers
Are you forget to install sound driver during installing operating system on your laptop? So first check that drivers are properly install or not. If it is not install, install it. If already installed, try to update it.
Still you are not getting any sound on your dell laptop so it also possible that the sound card is possibly dead. If the computer uses on-board sound (meaning there is no separate card with sound jacks on it), that is more problematic. That part on the board cannot be replaced without replacing the whole motherboard, normally. In either case, install a new sound card and use its jacks for audio.
Posted on Sep 25, 2012
  • 63 Answers
Please check wheather driver install properly by check your device manager otherwise there may be a problem in your audio output device.
My system volume has just been working until a few minutes ago when i tried plugging a headset only to note there was no sound even after removing them. all the volume settings are OK including the...
just try reinstalling the sound card drivers. you will face no problem after that.if this does not help. check the advanced sound settings and also make sure that some other driver is not selected instead.If this does not help please let me know.If this helps please rate my answer below.Thank you.
Jul 20, 2011 | Computers & Internet
I cannot get sound on yahoo messenger pool game ive tried everything i reinstalled messenger 10 i cleared my cookies ive got the latest java and ive even tried to change profiles Ive checked my volume...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 25, 2011 | Computers & Internet
I have a used dell desk top.I bought Logitech comp. speakers and ive enjoyed listen to some music on utube,until the other night. The sound went totally out! Thinking it was the speakers, I unplugged...
Hi
Check the following,
  • Speakers, connecting cables and Sound Card are working fine by connecting to another computer.
  • OR
  • If the connection ok increase your volume and open the cable from the pc.
    Now you will touch the stereo jack, can you can listen a sound when touch the jack. If you will not get any sound, think there is the problem in your amplifier or audio system has not any voltage. To confirm the voltage check by multi miter or can go any local Technician .If the voltage is ok, think your sound system defected and should go to Technician.
  • If your sound system is ok
  • Speaker Cable connect to an audio port (Audio/Video port in system box).
  • Ensure Volume is not in MUTE / Low (in Volume Controller).
  • Audio drivers have installed.
  • To confirm follow next step or ROLL BACK THE DRIVER
http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspx For another check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If there needto install the drivers). So please go there website>supports>download For download Suppose, you need driver for, ASUSK8V-VM
http://support.asus.com/download/download.aspx?SLanguage=en-us Product =Mother Board So Series = (Socket NO.eg. 754etc.) So Model = (Model no will beK8v-vm) And please select the O.S (XP/ VISTA / WINDOWS 7) version of the drivers that matches yourP.C and search. Now you can download easilyone after one. Hope it will help you.
Feb 23, 2011 | Dell Dimension 3000 PC Desktop
The mike of my headphones is not working.Even the inbuilt sound recorder of windows XP can't record any sound from the mike..The mike is working fine in other Laptops.I have installed all the...
make sure that your mic input is not muted. look under control panel/sound and audio devices, then under your microphone, select "volume" and make sure the input is selected (with a chack mark in the box under the mic volume control) and not muted.
Oct 12, 2010 | Compaq Presario 700 470024-192 Notebook
Sound problem
If the sound is on board and the drivers are not available, then go get a cost effective yet very good sound card that is Operating Systems based ok. Find out from the vendor whether the audio card could be driven by your operating system, may Windows 2000, XP, or Vista. The other way round is not worth the stress ok. Good luck
Jun 03, 2009 | EliteGroup P4VXAD Motherboard
Volume cannot be changed.Full Volume even if reduced or muted
You need to first find out what chipset your on-board card uses my friend. Check all the documentation to find out. You will need the exact set. Now search the net for an updated set of drivers that matches your operating system (XP SP1/2 etc). Now go to device manager and delete anything which has sound connections (MIDI Interfaces, MICs etc..). Now click the 'scan for changes' icon in device manager. Use the new drivers you downloaded.
Jan 25, 2009 | HP Pavilion dv6000z Notebook
New loud beep when volume control is adjusted
START- right click mouse on MY COMPUTER - PROPERTIES- HARDWARE - DEVICE MANAGER - SOUND VIDEO & GAME CONTROLERS -Right click(mine is realtek HD audio ) -PROPERTIES - ROLL BACK DRIVER.
Good Luck. Tom Smithbrother.
Dec 26, 2008 | Microsoft Windows XP Home Edition
I am not hearing any sound at all though i have increased every volume buttom
You check your system information if sound driver was installed, type dxdiag in your run command. Wait till a tool bar about your system info will appear then check your sound driver if installed. If it was not installed. you have to install a sound driver. Look at your sound card installed and download from internet any necessary sound card driver compatible to your sound card hardware and mother board. Just try this,. I have solved many computers by following this procedure.
Oct 19, 2008 | Compaq Creative Sound Blaster PCI 128...
I have a Dell Latitude D500 and there is no sound comming through.I have installed the right drivers as i have 2 machine and it workes fineon one and the other just wont give a sound even on startup.I...
just tell the volume icon in the system is shown or not if not then you sound drivers are not installed if it is showing then your onboard sound slot is having problem
Apr 29, 2008 | Computers & Internet
When installed INTEX 3D MULTIMEDIA PCI SOUND CARD it is giving sound but immediately it is disappearing
Dear Nath,
I met same problem with my client before. Hope this helps; Uninstall any music or sound application(s) that has remote control feature or disable it (uninstallation is preferred). Now, at Safe Mode(with built-in sound card disabled), in Control panel soundcard device properties uninstall all sound card drivers. Restart in normal mode and reinstall back the sound card drivers. By transferring the secondary sound on another PCI slots may help solve the problem, the reason is the IRQ number conflicts. One of the worst case we met to solve this kind of problem is by reformatting the system but do it only when there is a great need, extra time, file backed-up. Have a great day.
Best regards,
Rosener Guyano
Jan 12, 2008 | Computers & Internet
Toshiba Satellite A105 Notebook Logo
168 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
