Question about Thermador Refrigerators
I just replaced my thermador refrigerator water filter and can't reset the "change filter" display. I have model T36 and have held down the freezer super button and the ice button for 3 seconds per the instructions that came with the filter.
  • Cindy Bartin Jul 01, 2013
    Have exact problem, let me know if you get answer. Thermador customer service of no help.
  • Will Henderson Aug 06, 2013
    I had to hold the ICE and COOL buttons and that reset the filter message. On my model (T36IB800SP) it's not obvious which button SUPER refers to (what the filter documentation says to press), as that label sits below two buttons: COOL and FREEZER.
tborn6
  • 700 Answers
SOURCE: Change water filter for a maytag plus refrigerator
press the light switch button inside of the refrigerator five times.
Posted on Apr 03, 2009
  • 7 Answers
SOURCE: ALl of the buttons on the outside are jammed...
press and hold both the water and ice button together to reset
Posted on Nov 06, 2007
SOURCE: Water filter indicator light
On my samsung I needed to press the ice timer and ice mode together for 3 seconds.
Posted on Mar 29, 2008
  • 958 Answers
SOURCE: Icemaker in Admiral side by side refrigerator/freezer stopped working
see if you can bleed the air trapped in the water line to the ice maker. if air is trapped, water would not be flowing and it would take only a few seconds for the solenoid to be open to let water flow.
see if you can hot wire the solenoid to let water and air out of the tube long enough to bleed the air and hopefully, the ice maker would work continuously.
tnx 4 using fixya,
drcool
Posted on Oct 08, 2008
aborcass
  • 2651 Answers
SOURCE: Ice and Water dispenser
no manulal reset or fuse, buth tere is ususlly a "child lockout" feature prevent ing the dispensor from operating. check to see if the control has been placed, on, or perhaps the door is not closing fully, another reasom for the dispensor to stop
Posted on Jan 20, 2009
Replaced h20 filter and it still says "replace" even after following reset procedure
I appreciate your inquiry, Wayne!
From my understanding you have recently replaced your water filter inside of your Frigidaire refrigerator and the display continues to show you "replace". I see that you have held down the "set" button and it did not change. I would recommend performing a reset on your refrigerator and you can do that by flipping the household circuit breaker off for at least ten minutes. I hope this information is helpful for you. -Matt
Apr 29, 2015 | Frigidaire Refrigerators
Maytag refrigerator MFI2568AES. "Change Filter" light will not turn off. Held down filter reset for 3 seconds - did not work. Held down the light and lock buttons for 3 seconds - did not work. Wha
Hello Don;
My name is Peter. I am a retired field service refrigeration technician.
Your filter reset is just a independent timer set for six months. It is not tied into your water filter. You should change your water filter when your water dispenser flow is slow and/or you start to get small ice cubes. Depending on the usage, your water filter can last 18-24 months or more.
Unplug your unit for about 10 minutes to let the unit power down, then plug it back in.
Dec 31, 2014 | Maytag Refrigerators
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
I have a thermador bottom freezer (model KBULT3655E) and the freezer stay cold and remains at the appropriate temperature, however the refrigerator component does not cool. While the freezer has air...
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 16, 2011 | Thermador KBULT3655E (20.3 cu. ft.)...
"change water filter" continues to flash when dispensing water
I believe your new Jen-Air has an old model number placed above your post. If you had a newer model nuber I could see if changes were made to the solution. The ods are no changes. I it possible you may have missed removal of te flilter plug? It also is your first time and to press the 2 buttons at same time for 8 to 10 seconds may be a little confusing. I bet after this time you will have this down to an art! here is what I could find without the vorrect model number if that is what happened or not.Jenn-Air
Press and hold the light and lock buttons until the change filter light flashes.
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the filter light flashes (usually 5-10 seconds).
Mar 05, 2010 | Jenn-Air JCB2059G Bottom Freezer...
How do I reset the lg water filter indicator light on the control panel of my lg lfx21971st bottom freezer french door refrigerator?
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Oct 14, 2009 | LG LFX21971ST Stainless Steel Bottom...
Changed water filter red light stays on
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Open Questions:
Refrigerators Logo
5,691 people viewed this question
Top Thermador Refrigerators Experts
John Tripp
John Tripp
christian nielsen
ray gallant
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
