Question about Star Logic Monitor
Displaying "out of range" when plugged in - Star Logic Monitor
  • 979 Answers
Hello white tiger, hi, the out of range error is usually caused by a very high resolution setup on your computer display card that windows installed (generic driver), the monitor simply cannot produce the resolution, set your resolution to a safe level like 1024 by 768, most monitors can display this resolution. The root of this error message is incorrect display driver, you need CD to install the display driver. Once installed your resolution will now be controlled to a safe settings were the monitor can display properly.
Posted on Aug 20, 2010
No display?? Easy fix?
please see the diagram attached. see if plug or connector is loose, or bad contacts. clean it. Otherwise you must replace the complete display.
Jul 18, 2013 | KitchenAid KGRA806PSS Gas Kitchen Range
Maytag MER7775W Electric Range display range do not work
Press and hold cancel for a few seconds, unplug the unit for 5mins then plug it in and press cancel.
Apr 12, 2013 | Maytag MER7775W Electric Range
Kitchenaid Ykers807ss00 error display f2e0
this is the procedure for this code,
F2
Keypad
E0
E1
STUCK KEY (shorted key)
KEYPAD DISCONNECT or KEYPAD DISCONNECTED
PROCEDURE: Before proceeding, perform steps 1 through 3 above chart to enter the
Diagnostics mode.
A. Unplug range or disconnect power.
B. Check that the keypad is firmly connected.
C. Plug in range or reconnect power.
D. Observe for longer than 1 minute.
E. If error remains then go to step F.
F. Unplug range or disconnect power.
G. Replace keypad.
H. Plug in range or reconnect power.
I. Observe for longer than 1 minute.
J. If error remains then go to step K.
K. Unplug range or disconnect power.
L. Replace display board.
M. Plug in range or reconnect power.
Here is the board to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 10, 2013 | Kitchen Ranges
ISL93.IKSS range hood display flashes "A" and little/no suction
Check to see if your filter is plugged that will slow the air flow.
Oct 02, 2009 | Kitchen Ranges
Display not working
The display needs to be replace. Check all the wiring also to make sure nothing over heated
Feb 14, 2009 | GE Profile 30" Self-Cleaning Freestanding...
Error message FSEO appear on display of whirlpool stove
Door and switches
do not agree
1. Unplug range or disconnect power.
2. Check wires and connectors from control to door switch, then from door switch to control.
3. If no damage to wires or connectors, replace door switch.
4. Replace all parts and panels before operating.
5. Plug in range or reconnect power.
6. Press Cancel/OFF key. Program and start the CLEAN mode, and observe for 1 minute to ensure that
operation is normal.
7. Go to step 1 and complete checks.
Jan 11, 2009 | Whirlpool RF364 Electric Kitchen Range
GE XL44 Gas Range Clock Display frozen with only an "8"
This happened to me.  I just unplugged it and plugged it back in.  It worked!
Dec 03, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JBP64 Radiant Range - won't work
This is a very strange one, and you don't say how old this unit is or how long you have had problems with it, but most likely you have a poor electrical connection. Turn the breaker off and unplug the range. Remove the cover over the receptacle you just pulled the plug from and check all the electrical connections. If all OK, check the electrical connections where the cord attaches to the range. If still OK, inspect additional range and household wiring to range, including the connections right on the circuit breaker.
Aug 31, 2008 | GE Spectra JBP78 Electric Kitchen Range
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Oven Temp Display
if the oven doesnt work and the display is blank then you would have to get a control board for the unit.
Jan 22, 2007 | Samsung RGSF5330DT Gas Kitchen Range
Star Logic  Monitor Logo
234 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
scj103
Jerry Umali
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
