Question about Maytag MDG2706A Gas Dryer
Black Marks on Cloths
Getting black marks on white cloths from dryer. What can I do?
Either the roller are degrading or the belt the black is caused by the grinding of the dryer as it spins and has no cushion left replace the rollers
Posted on Mar 14, 2009
    Novelist:
  • 177 Answers
Are you sure its coming from the Dryer? It maybe from the washer?
look inside the dryer for some fall out, ink? gum?
also look inside the washer for grease? or ?
Posted on May 03, 2008
Black marks clothes
black marks on cloths usually occurs on older dryer when the felt liner that supports the drum, wears out or is torn, leaving a gap for cloths to get pulled into and between the drum-and drum support.
The replacement part (is not felt anylonger) but made of teflon and has self-sticking backing that goes on the front support after removing the old felt and glue. While you at it, order a new belt, that is most likely been slipping when the closes get jamed between the drum and support. Look up your model number on selectapart.com They aslo have tutorials so you can see how to install these items
Sep 09, 2014 | GE Dryers
Model de08-us1
-The seal is shrink so every gap is over size.
-The only thing will eliminate this problem, replace new seal.
Good Luck
Mai
Dec 19, 2013 | Fisher and Paykel DEGX1 Electric Dryer
Clothes, fabrics are coming out of dryer with burn marks
If those marks are little brown marks/they do look like burn marks but your cloths are being pinched by the front and rear felts on the drum//to test that take a white rag reach in to dryer at the edge of the drum front and rear rub the rag// you may have to push it between the drum and the dryer housing you will get brown marks that is rust///If you replace front and rear drum glides (seals) that will cure the problem I would price parts first as sometimes replacement is a lot cheaper.......Hope this helped....If I did please vote If you need more help please ask...Good luck
Feb 05, 2011 | Kenmore Dryers
I have a 2006 Whirlpool Duet Electric Dryer that leaves brown marks on my cloths. I have cleaned the inside of the dryer per the manual's diretions, but it still leaves the marks. They almost look like...
Usually, if you are getting brown streaks or marks on clothing, one or both of the drum seals are going bad. Clothing will drag between the bulkhead and the drum, leaving brown marks. If you want to do the repair yourself, I can provide instructions, otherwise call for service.
Dec 30, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer is leaving black marks on cloths.
was a pen or crayon placed in the machine by mistake ? You will need to
remove the residue, use rubbing alcohol on a rag for marker or pen ink , crayon use a razor scraper and then clenser and scrunge pad.
Oct 26, 2009 | Fisher and Paykel DE06 Electric Dryer
The dryer is squealing and leaving burn marks on the clothes
Squeak is caused by a worn out roller rolling metal to metal - Most dryers have rollers, felts and drum slides to balance drum rotation:
When rollers wear off, black powder leaks to rear felts and black marks are left on clothes.
Same thing happens when drum slides wear off (black marks are left on clothes)
Aug 15, 2009 | Frigidaire Dryers
Black streaks on my laundry
Marks on clothing in a washer are usually caused by a reaction between detergents and fabric softeners, especially cheaper bargain brands.
If you are sure that the black streaks are getting on the clothing in the washer versus the dryer, it could also be oil from the transmission getting into the washer tub. See if the spots will come out using a petroleum distillate of some kind. (paint thinner, etc). If a petroleum distillate will remove the marks, it is most likely something petroleum based that is making the marks.
This is a rare occurrence, and most marks on laundry are caused by the dryer. Typically, the drum rollers wear out and rubber and metal filings can get into the dryer and mark/streak clothing. Hope this helped and sorry for the problem you are having. Best wishes.
Jul 24, 2009 | Frigidaire ATF6000ES Front Load Washer
I'm getting burn marks on clothes. Think it's the seal on the back of dryer? Must hang to dry all white clothes, so what's the point o fhaving a dryer?
The gasket between the drum and the back panel may be worn or missing.  I had a similar problem with a 34 year old dryer when the felt gasket wore out and allowed metal-to-metal contact between the drum and the back panel.  The clothes would get pinched between them and make a black "kiss" mark.
May 18, 2009 | Dryers
Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
May 31, 2008 | Frigidaire FDE336RE Dryer
Maytag MDG2706A Gas Dryer Logo
282 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
