Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
42H83 auto touch focus ERROR and hyper board bad?
Hello i have a toshiba 42H83 42" my hyper board i think from what i have researched is going out...it it all jumpy squiggly on top 1/3 of screen and now virtical lines for a few seconds upon startup...it takes about 4 mins now to completely clear out to normal...then everything is great can some one confirm my problem.....how hard is it to replace capacitors and where do i get them and for how much $???i found a guy to send it to for 80$ and he will fix and send back is it worth it?
and my touch focus button on the front just brings up an error when pressed what is th cause of that?
i appreciate the help from anyone....!!!!!!
the guy i bought it off just had the bulb replaced......this problem accured after moving tv to my house...
  • Anonymous May 25, 2008
    Same problem
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Repleace cap for $ 80 , thats good , the error is do to comvergenge aligment
Posted on May 03, 2008
Touch focus error blue
The tv HYPER board it is dead aslo known as a tv convergence board.Tv have a convergence problems,it is dead.Tv Magic Focus button no longer response give error messages.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?Yes,than the tv HYPER board it is dead also known as a tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of resistors too.To fixed the tv HYPER also known as a tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 12, 2011 | Toshiba 42H82 42" Rear Projection...
Convergence issues with Toshiba 42H83 - Red lines will not align
Absolutely! if the consumer control has failed to rectify the problem you need expert help. There are two control boards near the power supply 1 or both are involved and more than 90% of the time both of the boards have to be replace otherwise the problem will occur again in a short time.
It is not a DIY project for the unskilled as it has to be tuned correctly when it is installed.
Better to leave it to the professional
Please rate the help to keep the FREE service online ++++
Aug 31, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 model projection HD tv has a bad wavy picture.
yes it can be fixed call a repairman and have them come out and repair it.it shouldnt cost more than a couple of hundred dollars to fix
Feb 01, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 Touch Focus Problem
I just got finished repairing the same model . The convergence modules are bad cost of repair is 250.00 for a service center to fix. My advice would be call your local service center tell them what i told you bad convergence ic and ask them how much they charge,
thanks doctor video good luck since 1987
Jun 14, 2008 | Toshiba 42H83 42" Rear Projection...
Double outline "red" around images
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
thanks doctor video 1987
Jun 01, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
May 12, 2008 | Toshiba 42H83 42" Rear Projection...
Please help
Its located behind the video input board. it runs parallel with it and has a plastic bracket over it. Upi wont be able to see it unless you remove the plastic bracket
Jan 13, 2008 | Toshiba 42H83 42" Rear Projection...
Will not 'Touch Focus' - Toshiba 42H83
1)I have yet to learn any advantage to replacing -110's with -150's
I think there is a misconception that increasing numbers =
better,more durable results....Actually, using OEM or better
quality should be most important.Generics from any source
tend to be seconds,thirds, junk ! Name brand are first quality
2)Check B+ feed resistors next to convergence IC's = burnt ?
3)Solder wire jumpers on signal board = 008,010,017,600,etc.
prevent maitenance
Dec 20, 2007 | Televison & Video
Toshiba 42H83 42 in unstable video
Probable PIP sister board.Moderate skill & some tools needed.Advise==get a senior tech near you.
Sep 10, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
180 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
