Question about Dryers
Bosch Maxx Sensitive dryer keeps stopping and the container light flashing but the container is empty.
SOURCE: I have a bosch WTE86304GB/03 tumble dryer red
Hi the problems is not a sensor its the codenser unit. Above the water collector should be a panel on the front of your machine, open the panel and you will see the condeser.covered in fluff, simply remove the condeser and clean it under an outside tap after removing as much fluff as possible by hand. Push back into place when clean and hey presto back to new again.
Posted on Aug 11, 2010
IFIXALL
  • 868 Answers
SOURCE: Bosch Maxx 6 doesn't dry anymore?
Yes,it is the first thing to check ,If you can somehow see if its glowing when you start the dryer.It may also be a thermal fuse.
Posted on May 23, 2008
SOURCE: Bosch Condenser Dryer Classixx
I found this on justanswer.com, I am going to try it this weekend and I will post an update.
"Ok if you remove the left hand side panel then located at the back is the drain pump
remove the hose on it which goes up to the bottle and blow up it to make sure its clear.
If thats fine then remove the pump and clear any fluff thats in there and make sure the impeller is ok and turning fine.
Then refit and try again hopefully this should sort it out.
let me know if you need anymore info."
Posted on Jan 02, 2010
SOURCE: Bosch dryer warning sounder for container full will not stop
Hi
You need to remove the left side panel, this is the side where the drain container is, once removed you will see the drain pump with two pipes coming from it, remove the pipes and top cover, disconnect the wiring, remove the pump unit with the clip, clean the float unit and pump, also remove the congealed mess in the water trouth as this is what holds the float up and makes the machine think the drain container is full.
I bet you will find this will cure the problems you are having, it did with mine.
Posted on Apr 01, 2010
SOURCE: Bosch classixx tumble dryer container full light
This is happening me too. Have you had any suggestions how to solve this problem???
Posted on Oct 11, 2010
My bosch maxx 7 sensitive dryer is not working - no lights are lit up, door is closed, filter is clean, container is empty, just beeps twice when i pusch start
Well I would recheck the water reservoir is fully inserted ....the door has no debris inside the lock....the bottom filter is cleaned not just the door filter.if this still not fixes then try a reset by switching off at socket then whilst holding start button without releasing for at least five seconds turn on power and listen for a click.sometimes a sensor is stuck and not relaying proper status.
Feb 22, 2015 | Bosch Dryers
Bosch sensitive maxx dryer flooding
probaly your pump is faulty
Jan 28, 2014 | Dryers
I have a Bosch Maxx Sensitive WTE84100AU dryer which stops a few minutes after the dryer starts. The dryness lights all turn off. The clothes don't dry.
There is a thermal overload switch behind the back cover. It has overloaded because the big lumps of lint in a) lint basket, b) small vents either side of the vent basket (use a chopstick), c) in the big pull out condenser unit at the front bottom left, and d) reach right to the slot for the condenser unit and scrape all the lint out of the back.
Now you can do the reset - unplug your dryer first. You will need a Torx T15 screwdriver to undo the all screws around the fan & drum cover, then use a thin blade to pop off the back cover. If you don't have a Torx screwdriver, you will have to buy or borrow one - there are just too many screws to use anything else.
I was thinking of drilling a 6mm hole in about the right spot so I can poke a chopstick through to press the reset button. 6607f76a-b20b-43ef-8059-a4858d51d2dd.jpg
Jan 08, 2013 | Bosch Dryers
My dryer Bosch maxx 7 doesn't work
That is a bad motor. It is overheating and the overload is shutting it down. Check to see if there is lint buildup on the motor. If not, you will need a new motor.
Nov 04, 2012 | Dryers
Tumble dryer stops container light flashing however container is empty
see this possible causes:
Belt
belt break, the drum stop, replace belt
Motor
motor burn, howoeve take out the belt, and try to turn by hand if the motor is easy to turn the motor is o.k and the contrary. replace
Door switch test the swtich, see the diagram
Jun 14, 2012 | Bosch Dryers
Hi! We have a Bosch Axxis gas dryer that runs for aprox 40 seconds than stops and "Beeps" and the "Drying" & Wrinkle Block/End" lights flash. I have tried running it empty...
your sensor is either dirty, most likely or bad. it is located under the lint trap. if you look down you will see it it has tow screws, be careful when cleaning it as it may break.
Feb 18, 2011 | Bosch Axxis WTA 3510 Electric Dryer
I've got a 2 yr old Bosch Exxcel dryer but its in my garage and we've recently had unprecidented cold weather with night temps of -12C The dryer seems to work fine but it keeps stopping after one cycle...
Sorry to read about your problem, I hope this helps you out.
yes and it has to be around 35 to 40 to defrost...may take 3 days at that temp
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Bosch Dryers
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
May 22, 2008 | Dryers
Dryers Logo
649 people viewed this question
Top Dryers Experts
