Question about Amana NDG2335AW Gas Dryer
Dryer comes on,cycles according to timer,but not heating,sometimeshad gas smell
  • Amana Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 20, 2010
Dryer will not shut off and not heat only way to keep is to leave door open
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
Apr 25, 2016 | Dryers
My maytag atlantis gas dryer will not turn off at the end of the cycle
Mar 23, 2016 | Maytag Dryers
Timer won't stop after cycle finished.
May 20, 2015 | Dryers
Why is my gas dryer making a fluttering noise
you better be careful if you are smelling gas then you have a gas leak somewhere.
May 31, 2014 | GE Adora Dryer. Gas Dryer. 7 cu. ft. in...
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
Dec 02, 2013 | Admiral Dryers
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Aug 04, 2013 | GE Dryers
Hello my 70 series kenemore is not getting warm and the timer is not completing the cycle to turn the dryer off it just keeps running for hours
I would need a model number to better narrow the problem down for you.
If this is a gas dryer
Remove the lower panel. With the lower toe panel removed, start the dryer & watch the igniter. If the igniter glows & cuts off without lighting the gas this would usually indicate the gas valve coils are weak & will need to be replaced. For this type of repair be sure to disconnect the electrical power & turn off the gas to the dryer. If the timer is set in the auto dry cycle, it will not advance if the dryer is not heating. Once you repair the dryer, the timer should start advancing. It is possible that your old timer is good. If you need further assistance please resubmit your question.
If this is a electric dryer
The timer not advancing from 50 minutes in time dryer & the unit not heating are not related unless 1 leg of the 240 volt supply is lost. Diagnosing a problem like this will require using a volt/ohm meter. With the timer set to time dry you should be getting 240volts to the timer motor & 240volts to the heating element. In the wiring diagram provided L1 comes from the timer on R & goes through the thermal cutoff, oper thermostat & the hi-limit to provide 120volts to 1 leg of the heating element. The L2 leg goes through the motor switch to the other side of the heating element. This is how the element gets 240volts. The timer motor gets its voltage on BK from L1 & OR from L2; this is what advances the timer.
Jan 12, 2011 | Kenmore 700 7973 Dryer
Hotpoint nvl333gyoww gas dryer's timer stopped working and ran for an extended length of time (about a day). After looking over the dryer, i noticed that during the no heat cycle the timer would work. So...
the timer : if you use time dry the timer should always move and complete the cycle. if you use auto dry the timer uses a sensor to tell the timer to move. If your not getting any heat your sensor might not tell the timer to move.
So lets start with the no heat problem. First make sure your Vent is clear or just disconnect the vent and put a pair of womans stocking over the end to keep the dust down, This will ensure you do not have a blocked vent. ((( If you have a blocked vent on a gas dryer the safty sensor will shut off the gas valve and you will only get a little bit of heat))) Now try the dryer for small load, ((( if this solved your problem then you have a cloged vent )))
If this did not solve your problem then the coils on your gas valve in the dryer are probably bad.
Sep 02, 2010 | Hotpoint NVL333GY Gas Dryer
Oven won't stay heated, clicking noise like its trying to ignite, and gas smell.
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
Problem -
No flame, no igniter glowing at all,
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Ovens
Heats up and then no heat again
You need a coil kit for the gas valve they will waeken over time and not open when they are energized
Jun 18, 2008 | Amana ALG331RAW Gas Dryer
Amana NDG2335AW Gas Dryer Logo
73 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
