Question about Microsoft Xbox 360 Console
My xbox doesnt start the power light turns red
    Genius:
  • 1,234 Answers
Hello Sir
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Fix-shad0w
Posted on Aug 27, 2010
My xbox had the three rings, i fixed it. it came back to three rings again, so i tried t fix it the same way. now when i try to turn the xbox on the power brick light turns red and the xbox doesnt turn on.
sounds like a bad power brick try a friends out if it doesnt work use the bolt method not xclamps if that doesnt work send it in to our shop in sunny Florida we have a 2-3 day turn around for all service work email me at price1150@bellsouth.net
Nov 21, 2009 | Microsoft Xbox 360 Console
Xbox 360 is flashing 3 red lights and doesnt play
Hello there.
Please click http://support.microsoft.com/kb/907534 to see about this problem.
As per the page:
If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue: 1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Xbox 360: The power supply light is red 906102 (http://support.microsoft.com/kb/906102/) Xbox 360: The power supply light is orange 906103 (http://support.microsoft.com/kb/906103/) Xbox 360: The power supply light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again.If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support), and then click Console Repair? in the upper-right section of the Web page.
Hope this helps.
May 26, 2008 | Video Game Consoles & Games
I finished fixing the red rings and my 360 was working fine but it doesnt turnm on now. WHY?
Is your power supply getting power (ie. is the light yellow). When you hit the switch on the (XBOX), does the power supply turn light turn green? If not, the XBOX is not recognizing the switch or the power supply is bad.. If it is, then you may want to recheck your red rings fix. The parts you've installed may have come loose and shorted something out.
If your trying to turn the XBOX on with a joystick, you may have to resync them. Try using the XBOX switch on. If it turns on with the XBOX switch and not the joysticks, it could be the wireless component in the XBOX or the joystick batteries.
**NOTE: I am saying XBOX but I mean the 360.
Nov 02, 2009 | Microsoft Xbox 360 Console
Xbox360 power cycles by itself
do any lights flash etc, if so check below;
Two red indicator lights flash on the Ring of Light, or no lights flash on the Ring of Light. uparrow.gifBack to the top CAUSEThis may happen in the following situations: The auto-off setting is turned on,... loadTOCNode(1, 'cause'); This may happen in the following situations:
  • The auto-off setting is turned on, and the console has been inactive for six hours.
  • The console is too hot.
  • There is a problem with the power supply.
uparrow.gifBack to the top THINGS TO TRYTo identify and fix the problem, follow these steps:To begin troubleshooting thi... loadTOCNode(1, 'whattotry'); To identify and fix the problem, follow these steps:
  1. To begin troubleshooting this problem, check if the auto-off feature is turned on. To check if the auto-off feature is turned on, follow these steps:
    1. Start the Xbox 360 console without a disc in the disc tray.
    2. In the System section of the Xbox 360 Dashboard, select Console Settings.
    3. In the Console Settings area, select Auto-Off.
    4. Examine the option to see if it set for auto-off. If it is set for auto-off, change your selection.
  2. If the auto-off feature is not turned on and this is the first time the Xbox 360 console has turned off unexpectedly, let's do a simple test before we continue troubleshooting.
    To do this test, turn the Xbox 360 off for about 10 minutes. Then turn the console on and see if the problem occurs again. If the Xbox 360 console turns off unexpectedly again, make a note of how long the Xbox 360 console is on before the console turns off automatically.
  3. If the auto-off feature is turned off but the problem happens again, check the appearance of the Ring of Light to determine what to do next.
    • The two lights in the left quadrant of the Ring of Light flash red: The internal temperature of the Xbox 360 console may be too high. In this case, turn off the Xbox 360 console, and let it cool down. It may take several hours for the console to cool enough.
      Also, make sure that the ventilation openings on the console are not blocked. (For example, the ventilation openings may be blocked if you place the Xbox 360 console on a soft surface, like a bed or a sofa.) Also make sure that the console is not located in a poorly-ventilated place, such as an enclosed bookcase or stereo cabinet. For more information about what to do if the two red lights in the left quadrant on the Ring of Light flash red, click the following article number to view the article in the Microsoft Knowledge Base: 907533 (http://support.microsoft.com/kb/907533/ ) Two of the lights on the Ring of Light on the front of your Xbox 360 console flash red
    • No lights are flashing on the Ring of Light: In this case, we should check the lights on the Xbox 360 power supply for hints on how to fix the problem. A green light indicates that the power supply is correctly functioning.
      For more information about the power supply light, click the following article numbers to view the articles in the Microsoft Knowledge Base: 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red
Jul 31, 2009 | Microsoft Xbox 360 Console
I get a red light on my powerpack
i think that means that the connection between the power brick and the xbox isnt working, either your xbox needs repair or you need a new power brick, ask a friend with a 360 if you can borrow theirs and also their wires for the powerbrick and if it works then YOU need a new powerbrick and if it doesnt then your xbox is broken
Jun 14, 2009 | Microsoft Xbox 360 Console
3 red lights, but nothing turns on
sorry to say that is the Red ring of death your gonna have to send it to microsoft and they will repair it for free
Xbox screw up!
are u getting red lights round the power button??
if so send it back( the red ring ov death)
May 04, 2009 | Video Game Consoles & Games
Original xbox red ring of death
you have to take the xbox apart open the dvd/cd rome and clean the eye and the disk spinner then put it back together and it should work fine
Dec 28, 2008 | Microsoft Xbox Console
Xbox 3 red lights problem help please
3 red lights normally means there is a general hardware failure.
Are the lights flashing?
Turn off the xbox and...
Try unplugging everything from your xbox, plug it back in and turn it on.
if that doesnt work, when your xbox is turned off, take the hard drive out and restart your xbox. If it works with the hard drive, try restarting it again after putting the hard drive back in.
Apr 10, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
16 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
