Question about NetGear SPH200D IP Wireless Phone
Unable to register my phone
Whenever I try to register the phone a message appears that the registration failed. Is there any way to clear the phone so I can start over???
  • 48 Answers
You can reset it by doing this
1. Press Menu>Settings>Advanced>Reset Device.
2. Scroll and select either Reset All or Keep Network.
hope these helps
Posted on May 09, 2008
  • postscript
    postscript May 09, 2008
    additional info
    Reset All - will Reset all the settings including the network settings.
    Keep Network - will Reset all the settings except the network settings.
My Phone has the message; USE Hold key TO SEND PIN. What does that mean?
In system options you will see a registration code enter that code and then the ext number of the phone then hit hold. This will register you phone. You will need to have a ext programmed in users and devices.
Sep 17, 2013 | Mitel 5330 IP Phone
My Skype phone is giving "Unregistered" message
Try by pressing & holding the "Page" button on the basestation while the handset is attempting the registration process.
Mar 17, 2011 | Philips (VOIP8410B37) Skype IP Phone
When any calls my phone it gos to vioce mail and its not on do not disturb.
possibilities could include sounds like the phone is not registered with the server correctly, your server is not setup to use the proper audio coedec's to pass the call through, so it fails sending the caller direct to voicemail. check the registration port on both ends as well. If everything above appears correct, check to see that the phone is not set to DND at the phone server end, this can be set independent from the phones settings which may appear normal. i hope that helps you.
Aug 24, 2010 | Polycom SoundPoint IP 601 IP Phone
How do I cahnge the ip address on the linksys spa941 when it failed to registered: it is not picking up ip address from the switch.it was working before change the switch
Confirmed modelLinksys IP Phone SPA941 and SPA962 with SPA932
Linksys IP PhoneThis document explains how to use Brekeke SIP Server with the Linksys IP Phone SPA hard phone .
The Standard features include two active line appearances, call forwarding, redialing, speed dialing, transferring calls, conference calling and accessing voice mail. For more information regarding this product please go to www.linksys.com
Configure Linksys PhoneSet up your Linksys phone with a fixed IP address (e.g. 192.168.0.15) and subnet mask (e.g. 255.255.255.0).
Once the IP address is configured you can access phone webpage by its IP from web browser (e.g. http://192.168.0.15). Network SetupClick on "Admin Login", then select “System" tab. Sign Static IP, Gateway and NetMask.
Use the following data as an example
  • Static IP: Linksys phone IP (e.g. 192.168.0.17)
  • Netmask: 255.255.255.0
  • Gateway: not needed if SIP Server is in the same LAN as Linksys phone
  • Click on [Submit all changes] button now to reboot you phone,
    or after whole setup is finished
Phone ConfigurationSelect tab Ext1 or Ext2 and enter SIP server information and sign extension number
Use the following as an example to complete the phone configuration.
  • Proxy and Registration:
    • Proxy: Brekeke SIP Server’s IP address (e.g. 192.168.0.69)
    • Register: Yes
  • Subscriber Information:
    • Display Name: extension number or Name (e.g. 400 or Alice)
    • User ID: extension number (e.g. 400)
    • If user authentication is set on at Brekeke SIP Server,
      type in the same information at Auth ID and Password as what you set at SIP Server side
      and Use Auth ID: Yes
  • click [Submit All Changes] button to restart the phone
phoneconfig.gif Brekeke SIP Server’s Registration PageClick the [Registered Clients] tab at Brekeke SIP Server admintool.
The Linksys IP Phone SPA941 Phone is registered with Brekeke SIP Server.
Jun 09, 2010 | Linksys SPA941 IP Phone
CIT310 - registration problems with the base
use the pager button, keep it pressed for about 15 seconds, and then use the register option from the phone, handset will pick up the signal. You may have to do this multiple times.
May 27, 2009 | Linksys CIT310 IP Wireless Phone
Unregistered, registering a new base, faillure....
IF YOUR HANDSET WAS WORKING AND THEN STOPPED WITH "UNREGISTERED":
If lowercase unregistered is in main display and a reg. appears under the left soft key:
Press the left soft key below REG. and then press and HOLD the button on the top of the base station until the two indicator lights on top of the base station turn off. Wait until handset signals with beeps and registered. You are done
THIS IS FOR FRESH OUT OF THE BOX REGISTRATION OF UNREGISTERED HANDSET
Press REG Register shall be highlighted.
Scroll to Register. Press Select.
Enter the system PIN (Default: 0000). Use
CLEAR to correct typing errors.
Press ENTER to confirm.
• Your handset starts searching for the base.
Press and HOLD the round button on top of the base unit until the two
indications turn off.
• If registration is successful, the signal icon
Jun 22, 2008 | Philips VOIP8411B/37 IP Phone
Philips VOIP
Had the same problem, de-registered, disconected the base (physically from energy), reconnected, and re-registered and that worked.
Regards!
Feb 10, 2008 | Philips VOIP8411 IP Phone
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Jan 08, 2008 | Polycom SoundPoint IP 501 IP Phone
Message LED keeps flashing even if there are no more messages.
Is the phone in a ACD? I'm guessing it also has a broken dial tone? We had this problem and found that the phone was part of an ACD but wasn't logged in, causing a call forward to kick in. We had to dial *81 on the phone to clear the phone settings (it will be different for you no doubt so check the Feature Access Code Assignment.
Failing this, I would suggest you take the persons telephone line out of the system entirely, clear voicemail, clear the extension number and clear its IP registration etc and then start afresh; this has worked for us in the past too.
Best of luck!
Nov 30, 2007 | Mitel 5220 IP Phone
VOIP321 is unregistered
I had a similar problem. I unregistered the main handset & then when I attempted to re-register it, I had the same issue (handset attempts the registration process & eventually fails). I tried everything including pressing the "Reset" button on the back of the basestation & downloading firmware version 1.0.4.80 (started with 1.0.4.50). Turns out I had to press & hold the "Page" button on the basestation while the handset is attempting the registration process.
This info is in the manual. I know, I should have read the manual first. But at least I'm not alone; the guy at Philips told me to return the product because it must be defective.
It appears that the registration process is a security process/exchange between the basestation & handset. I'm not certain how standard this process is (i.e., whether differing manufactures utilize the same security protocols). If not, it is likely that other manufacturers' handsets cannot talk to the basestation. I mention this because you said you registered the main handset multiple times, so it sounds like you are familiar with the registration process.
Nevertheless, this might help others who decide to spend their weekend pressing the "reg" button a bzillion times, watching it fail as many times, & looking for answers on
Nov 08, 2007 | Philips VOIP3212 IP Wireless Phone
NetGear SPH200D IP Wireless Phone Logo
344 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
