Question about Garden
My sister-in-law has a mcculloch 31cc MT725 EZ pull EZ start. Her husband moved out and for the life of me I can't get the head apart so I can restring it. I have lined the two arrows up but can't get anyfurther. Do I have to loosen the black knob on the bottom first and then line arrows up. Ofcourse she doesn't have the manual. Thank You Sam
  • 4088 Answers
SOURCE: need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Posted on Jul 04, 2009
dontbother10
  • 2220 Answers
SOURCE: my McCulloch chainsaw 3200 internal fuel line in
Try your friendly neighborhood chainsaw seller/mechanic. Take a piece of the old hose with you.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
Posted on Oct 13, 2009
SOURCE: Have a Ryobi weed wacker 725r 31cc click link
i also have a ryobi weed wacker. if it is the same. you don"t have to remove the button. line up the 2 arrows one on wheel with bumpy edges and one by the button. you should see 2 holes feed a 2-3 foot piece of line into the hole the line comes out of for cutting and it should come out of a curved holw on the bottom by the button .tuck the end into a small round hole . pull line tight (tug on the section that you cut with). wind the string by turn the ring around the button. til desired length. if this doesn't work. google you model # and look for a manual (manual for ryobi weed wacker model # ------------.)
Posted on Jul 09, 2010
  • 4088 Answers
SOURCE: how do i take apart an eager ****** mcculloch
Drain the fuel tank, then remove a screw at the back end of the trigger handle, two screws at the rear of the case and possibly one or two under the rear case half. Keep track of which screws went where. The rear case should just pull off (watch the wire oil-pump lever which will come loose). The fuel tank pulls off rearward as well. This exposes the engine and main fuel line. Hope this helps!
Posted on Oct 24, 2010
HansPP
  • 2510 Answers
SOURCE: how do u restring a
Take a length of about 6 foot of line, kink it in the middle and pass this through the hole in the spool. Wind the two lengths of line around the spool in their own divisions and in the same direction. The direction of wind is embossed in the reel and the line should be wound tightly and held all the while. When you have about 6-8 inches left in your hand, bring the cover up to the spool and carefully pass the two ends of the line through the holes, push the cover all the way over while pulling on the two pieces of line and ensuring that the lines stay on their own side of the division on the spool. Fit and tighten the bump nut and trim the lines to just about the cut-off blade.
The lines should trail out of the holes in the direction of the machine's rotation. Try cut with the tip of the line as much as possible. Cutting nearer the drum flexes the line and will lead to early breaking of the lines. Run the motor at a constant speed and rather move the cutting head in and out of the weeds to affect a deeper cut
Posted on Jul 16, 2011
My troy bilt trimmer tb20sc rope is hard to pull. It all of a sudden stopped working. Took it all apart. Pull on rope off of trimmer,it still works fine. Took off spark plug, piston is moving up and down....
Jard you need to check that the bottom head is clean and there are no obstructions. Then check that the coil is in tight and the nuts are not loose. Finally have you been using the correct fuel mix? Clean the fly wheel with some lubricant spray and sand paper and re assemble.
Aug 31, 2013 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
My new McCulloch MAC842 will not start, the on/off and choke switches do not move, any answers please.
It should work that as you pull the choke pull out it also swithes the ignition on, you should see the red switch lift up as the choke is pulled out, once the engine fires you then just push the choke in, it will not run with the cheoke out , only fire once.
Mar 04, 2012 | McCulloch Garden
I have a McCulloch 14" Mini P52 which belongs to
If this machine has a saftey chainbrake it may well have activated, to de activate grab the front hand guard and pull it fimly back to the top handle of the saw, this will de activate the brake, now try again.
Aug 28, 2011 | McCulloch Garden
My sister(Sherry Burns) past away and her husband(William Burns) is now trying to use her cell phone. The problem is the password for getting messages. Sherry(sister) did not record her passwork for...
Hi. When it comes to your problem, it is better to bring the phone to the cellphone repair shop. They have gadgets to recover all the password to your phone or any kinds of phone. I hope it will help.
May 19, 2011 | Nokia 5130 Cellular Phone
His brother in law tried to rape me and i don't know if i have to tell it to my friend, who is insisting to know the truth
Please share this details only with your family(friends can leak the news leading to bad reputation for you) , but you can warn your brother in law in advance to correct him in his ways as your sister's life is your hands.
So if there is no damage done , talk to him and tell him to have a good life and behave humanly becoming morally responsible, not to cheat on his wife.
Jan 17, 2011 | Microwave Ovens
I have a yard machines 31cc y28 17'' how do I fix the pull string it is pulled out fully
Take the top cover off, You should then see 4 bolts around the engine cover, take these out and the cord head will come of,Depending on where the cord broke is the question of using the same cord, But if you're getting a new cord you will need to thread the cord into the eye for the cord, Tie a knot to prevent it pulling apart. then tie your handle on. After this you will wind the cord up tight on the pulley and a screw driver holding the pulley from moving while you put the cord and cap back on the engine, You can then start back installing the bolts and the other cover..
Aug 28, 2010 | Yard Machines 21A240M000 Garden Tiller
I have a Troy-Bilt 31cc 2-Cycle Gas Powered that doesn't start
Coil bad or wire to coil bad. I tell everyone what Ill tell you,when it comes to small engines,troy bilt,poulan,weedeater brand all JUNK,JUNK JUNK! Theyre made cheap,not built to last,theyre throwaways. Carbs are made in china. If youre ever in walmart next time go back to the garden section and pick up a weedeater or poulan brand chainsaw or trimmer. Look at the package good and look at the factory life expactancy. Its not in months,not even days,but in hours. If I was you I would tell myself NO MORE! I would buy a dolmar or stihl,pay the extray,cause you wont be aggrevated in the long run. P.S. Dolmar offers a 100% coverage for ONE YEAR on all equipement.
Aug 10, 2009 | Troy-Bilt Garden
Saxonshardco motherboard issue
Get your sister in law to AA, that may prevent future problems happening.
Dec 16, 2008 | Computers & Internet
Garden Logo
183 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
