Samsung TV about 4 years old, the tv turned off by itself last night and for whatever reason will not turn back on. When we use the remote the middle green light comes on in the middle as well when we use the power button on the TV. No sound will come on or no picute. We have pulled the bulb out and its still intact. Model # is HLN467W. Any Answers would be great.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Have u repleace the lamp yet , if not repleace, 4 years old would be a lot of hours the lamp may look intact but after severals hours tv start to go off
Posted on May 03, 2008
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Watching tv last night, the tv turn off by itself with out touching remote control, after that i keep trying to turn it on and the on/off red tv light startted flashing for a few minutes until it when off...
It can Have one of 2 Troubles, The Inverter Board is Defective or the Power Supply has bad Capacitors. I found 3 Capacitors known to go bad in that set. Replace the 10 Volt Capacitors with 16 Volt Caps and they will last forever.
Oct 07, 2010 | Samsung LN40A450 LCD TV
Sony Trinitron turns on in the middle of the night for no reason
maybe the people next door have a powerful remote, and when they turn their tv off a night it turns yours on?
Dec 11, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
No Action from a HLN467W
I would wait to see if it happens again.
Feb 26, 2008 | Samsung HLN467W 46" Rear Projection HDTV
RCA 32V420T (32 inch)
I think that vertical deplection IC of you tv set is shorted. Please check also the YOKE of the unit, its maybe grounded.
Sep 10, 2007 | RCA 32V420T 32" TV
Sony Wega KV-27FS100 RANDOMLY Turns itself ON
You said around 4pm TV is switched on everyday. Check in menu options any on-timer and off-timer is changed. If it is not there is a problem in microprocessor section. EEPROM ic malfunction also shows these type of symptoms. But it can be done by Technical persons only. This is not a major problem. This is due to surge current and lightening like that.
Sep 06, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
TV comes on and goes off by itself
In order to determine whether it is the TV itself or something in the room that is causing the problem, place an object in front of the infrared eye on the TV. This is usually a transparent red plastic window on the front of the TV somewhere. Verify that it is covered by trying (and hopefully failing) to use the remote. If the TV continues to turn itself on and off, then it is the TVs internal circuitry. If the behavior stops, then it is something in the room. One of the more surprising causes for behavior like this is sunlight hitting rotating ceiling fans -- the light reflects off the fan at just the right frequency to fool the TV. I mention this so you don't limit yourself to only thinking that it must be either the TV or the remote.
Apr 05, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
T.V. turns itself off
before any attempt to deep cause of problem, unsolder first all the tack switches in the front panel of tv.then turn on the tv using remote control observe? cuz maybe one of the switches is stock.if not,proceed to eeprom servicing which is u have to look for service mode of ur tv model to unlock it and reset it to factory value.
Sep 12, 2006 | Philips 32RF50S 32" TV
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
