One day my Vostro 1310 was just fine, next day when I turned it on, the screen stayed black with the Caps Lock and Scroll Lock on and the Num Lock blinking. I left the computer alone for a few day. Then I turned on just out of curiosity and she functioned just fine but I had to turn it off. An hour later, the Caps Lock and Scroll Lock were on and the Num Lock blinking with the screen all black again
  • 63 Answers
Due to some internal error and fault in RAM this happens
Posted on Aug 20, 2010
CAPS LOCK STATUS DOES NOT APPEAR ON THE SCREEN OR ON KEY BOARD
I don't know how to make this status appear, however here's a way around it.
Go to Control Panel. Ease of Access Center > Make the keyboard easier to use. Check the box next to "Turn on Toggle Keys. Hear a tone when you press CAPS LOCK, NUM LOCK, or SCROLL LOCK".
From now on, you're going to hear a beep whenever you press CAPS LOCK key on or off, the beep is slightly different depending on whether you press it on or off. Slightly higher pitch when you press the CAPS LOCK to stay on.
Oct 08, 2014 | Logitech Computers & Internet
Dell vostro troubleshooting caps lock on scroll lock on num lock flashing
Desable it finction in the bios promt wen the laptop are promt push del or F2 keyboars go to bios option advanced system and enable the keyboard on wen prompt windows and this is the solution coment please !
Mar 04, 2014 | Dell Vostro 1510 Laptop
I press the power button on my Dell Vostro 1500 and the HDD runs and the num lock light stays on and the scroll lock and caps lock flash and the DVD drive light stays on then the thing just shuts itself...
There are 9 states for LED error codes on this model. The error you're describing indicates that the laptop does not detect any RAM (memory sticks). Since you tried to isolate bad memory stick it looks like your motherboard has a problem and needs to be replaced.
Jul 28, 2011 | Dell Vostro 1500 Notebook
Press power button nothing comes up on screen, however, the num lock icon lights up and flashes, the caps lock icon also lights up. Dell Vostro 1510.
Copy and paste this link into your internet browser for the service manual for your laptop.
http://support.dell.com/support/edocs/systems/vos1510/en/SM/html/trouble.htm#wp1092170
The star icon (*) means flashing LED, the bold circle means on, the circle within a circle means off.
The LED's that they are referring to are the NUM, CAPS and SCROLL.
It appears that you have a problem with your LCD. Try connecting an external monitor to your laptop. If you get a display then your LCD display panel needs to be replaced. If no display then your motherboard needs to be replaced.
Apr 19, 2011 | Dell Vostro 1510 Laptop
My laptops screen will not turn on and the lock with 9 keeps blinking. what is wrong with it??
What you saw regarding the lock with 9 is the num lock key. next to that is the Caps Lock key and next to it is the Scroll Lock key. Those are called Lock LEDs. If the status of the light is Flash-On-On then that represents system board error. Next step is reseating the processor, but requires a certified technician to do it, and if it still fails you need to replace system board or the processor of the computer.
Apr 05, 2010 | Dell Vostro 1510 Laptop
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
CAPs lock key is on al the time
When you start your PC, Num Lock, Scroll Lock, and Caps Lock don’t automatically toggle on. You can automatically turn each of them on or off whenever your PC starts, for all accounts on the PC. As a practical matter, most people probably want to have only Num Lock automatically turned on, but this Registry hack gives you the power to force any combination of keys on or off.
Start>Run then type in "regedit" whithout quotes.
HKEY_USERS.DefaultControl PanelKeyboard.
3eaaaca.jpg Find the String value
InitialKeyboardIndicators. By default, it is set to 0, which means that Num Lock, Scroll Lock, and Caps Lock are all turned off. Set it to any of the following values, depending on the combination of keys you want turned on or off:
0 Turns off Num Lock, Caps Lock, and Scroll Lock
1 Turns on Caps Lock
2 Turns on Num Lock
3 Turns on Caps Lock and Num Lock
4 Turns on Scroll Lock
5 Turns on Caps Lock and Scroll Lock
6 Turns on Num Lock and Scroll Lock
7 Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect.
Note: You have problem with Caps Lock so just modify Caps lock option on Regedit.
And do not forget to run virus scan on your computer once you are done.
Rate always the all answers.
Thank you
Jan 02, 2009 | EzKey EZ8000 Smart Office Keyboard PS2
Computers & Internet Logo
206 people viewed this question
David Payne
David Payne
