Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Full of fuel and gas is on. Code 11 and then shuts off with a few seconds of starting
Definately a gas supply problem. The error code 11 means it is trying to light but no flame is avalible. Replace the gas regulator at the bottle
Posted on Aug 20, 2010
Cant get enought gas
repair - What should I check if my chainsaw fails to start ...
diy.stackexchange.com/.../what-should-i-check-if-my-chainsaw-fails-to-s...
Feb 26, 2013 - Does anybody have any idea what I can do to get my chainsaw started?... Clean carburetor and fuel lines, especially if it may contain old fuel. ... that prevents it from generating enough current to sustain repeated firing of the spark plug as the engine turns. ... Your muffler is pluged up your saw can't exhaust.
Stihl Chainsaw - starts but won't run - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Aug 9, 2006 - Re-chocking (once until it kicks) gets it running again for another 20-30 seconds ... carb body was not letting enough gas through to contunue running the saw at full speed ..... MY STIHL 029 CHAIN SAW BLOWS GAS BACK OUT OF THE .....Can't imagine why shaking the saw around would keep it running. Chain saw won't start
Feb 8, 2012
homelite xl chainsaw
Sep 4, 2009
Husqvarna chainsaw wont start?? HELP
Oct 15, 2006
chainsaw starts then after few cuts shuts down
Mar 30, 2006
More results from forums2.gardenweb.com
chainsaw won't start - any ideas? [Archive] - Straight Dxxe ...
boards.straightdope.com > ... > Main > General Questions
21 posts - ‎11 authors
Jan 31, 2016 | Garden
I have a Toro HXL 16-44. Starts but then shuts right off after initial try, then will not start up again at all. Just turns over, never starts up.
Your fuel needle is not closing , allowing too much fuel... there needs to be a proper fuel air ratio. Have you recently had the unit serviced? Someone mess with the carburetor itself?
The float needs to be adjusted so it closes the needle sooner
Oct 17, 2015 | Toro Garden
Starts up but will not run but for a few seconds
Check the oil. Some engines will shut down if the oil is low. Otherwise you probably have a dirty fuel filter and the carburetor fills up with gas long enough to start but isn't getting enough gas to keep it full.
Feb 13, 2014 | Generac Guardian Ultra Source 15,000 Watt...
2011 tri glide bike starts and three seconds later shut's off and EIP shows for error code
Hi Reggie, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below. Good luck and have nice day. Harley Diagnostic Codes 04 to Present
Apr 02, 2012 | Harley Davidson Motorcycles
Starts with starting fluid runs for a few seconds then shuts down
Good test. Do not keep doing that.
Make a new and accurate gas/oil mixture. Empty and refill. Secure cap. Be sure to flood system during start attempt. Can you smell gas? Oops, too much, better wait 30 seconds for full evaporation.
Two little screws near carb. Both are actually needles and probably have a visible spring which keeps them from vibrating to a new position while in use. One fuel/air mixture at low idle (start). One fuel/air mixture at high RPM.
Try 1 1/2 full turns open from fully closed. Once to get it to idle roughly, adjust to a smooth idle. Do the same at full throttle. You will notice that the more you shut the full throttle down, the higher the RPM will go (assuming that it is near correct). Do not run it to lean. The mechanics of the motor needs the oil from the gas.
Smile always.
Jun 03, 2011 | Garden
I have a 1995 gmc sonoma that doesn't get gas and won't start when it did try to start it was like it wasn't getting gas at all. the gas tank is full, and you can hear the fuel pump kick on when the key is...
Have you tried starting the truck up using Starting Fluid? If it starts and runs for a few seconds, you definitely have a fuel issue, and from the sounds of it you may have faulty injectors or fuel pressure regulator. If the starting fluid doesn't start the engine for a few seconds, you may have a spark, or ignition problem. Let me know what happens when you use Starting Fluid and I will help you out further.
Mar 08, 2011 | 1995 GMC Sonoma
I think i ran my mustang gt out of gas,i just got this car today from a good friend.It was idling in the drive way and then died without warning so i think it ran out of gas according to the guage!I put...
You need to make sure you put in AT LEAST 2 gallons of gas, more if the car is not level. It might take a few cycles of the key to get the fuel line primed again. A full cycle is Off-On-Start. When you turn the key to on, listen for the fuel pump. It should run for a few seconds and then shut off, turn the key to start for a few seconds and then back to off... This will have to be repeated several times. You should be able to hear the fuel pump from the drivers seat. I will be a faint hum or hiss coming from the back seats.
Sep 27, 2010 | 1995 Ford Mustang
Fuel tank shuts off long before tank is full
the vent tube that runs beside the filler hose is crimped shut or clogged
Jun 29, 2009 | 1999 Chevrolet Silverado 1500
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
91 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
