Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Problems after convergance chip replacment
I just replaced the convergance chips and it fixed the flash focus problem BUT the screen is all bleu now.. Any idea what I did wrong???
  • Sony Master
  • 8,617 Answers
Check that none of the IC pins are bridged with solder, Use a strong magnifying glass to check the pins very carefully
Posted on May 03, 2008
When using majic focus the blue doesnt focus right
Simple answer for this question:
Magic focus is for Convergence and attempts to adjust at about 16 points on the screen---if it does not help the two convergence chips this set uses need to be replaced---small chance if either chip shorted you may have a bad resistor near them also.
See attached photos of convergence problems --no two look the same but you will now know if your problem.
I have replaced chips in hundreds of these Hitachi sets--about the only real issue the sets have--life span on the chips is 5-7 years.
If you can solder and are moderately handy this can be a do it yourself repair--Parts (see photo of chips) cost will be under 25 dollars and the fix for a first time person about one hour.
Happy to help and assist you if you decide to fix it yourself.
Chips look like these and may have the stk-392-150 number on them, a stronger version of the one seen in the photo
Apr 05, 2012 | Hitachi 53UWX10B 53" Rear Projection...
Tip
How To Fix A Convergence Problem
Here are some of the most common symptoms and example photos of a convergence problem.
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing or you can call in a pro.
If you want to do the repair yourself check the site www.TvRepairKits.com
Their kits include a step by step photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
on Aug 31, 2009 | Philips 46PP9302 46" Rear Projection...
I have some distored blue color across the screen
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Using your original remote go-to the settings menu then goto the convergence section.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Mar 27, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Lost focus.looks 3d. red double. cant focus on red convergence.
This is a very common failure on Projection TV2_bing.gif sets.
  • Screen looks 3D
47a7bc4.pngSOLUTION
If you want to do the repair yourself check the site www.TvRepairKits.com.
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
724bcba.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant,step by step instructions, etc.
Jan 28, 2010 | Philips Magnavox 51MP392H Rear Projection...
Sony TV losing focus
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
You should be able to move them up, down, left, and right.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 17, 2009 | Sony KP-65WV600 65" Rear Projection...
I have a sony Projection TV KP46WT510 convergence issue. How can I fix it? I see fusy picture with red and bleu double picture. I tried the convergence fix in manual and it shows the issue but could not...
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 13, 2009 | Sony KP-51WS500 51" Rear Projection...
Picture is overlapping with a green and red color
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 06, 2009 | Sony KP-57WS500 57" Rear Projection...
When doing Magic Focus on Hitachi 51SWX20B I get Error 3, and the Process Stops. I have a Hitachi 60SDX88BA that also has a blue semi circle at the top of the screen. I have run magic focus and it stops...
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 02, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I have a Hitachi 53uwx10ba has double colors red and bleu
  • Screen looks 3D
0667c5f.pngSOLUTION
May 24, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Auto focus and manual focus(red+will not move left
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 17, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
