Question about Electrolux 30" Self-Cleaning Slide-In Double Oven Electric Convection Range - White
Control lock 3 I can't open the oven. It's locked. What do I do to open it?
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    Can't open the oven door with an F9 and beeping
    Here's the info from the service manual
    "Fault Code: F9
    Likely Failure Condition/Cause:
    1. Door motor failure / jammed. Latch
    motor switch failure.
    2. Control software failure, or component
    failure (relay stuck).
    3. Wiring Problem.
    Suggested Corrective Action:
    1. Press CLEAR key.
    2. If CLEAR key does not eliminate problem, turn off power for
    30 seconds, then turn on power.
    3. Check wiring of Lock Motor, and Lock Switch A and Door
    Switch circuits.
    4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
    motor does not rotate, replace Lock Motor Assembly. Plug
    P4.
    5. Check Lock Switch A for proper operation (do they open and
    close, check with ohmmeter). The Lock Motor may be
    powered as in above step to open and close Lock Switch. If
    the Lock Switch is defective, replace Motor Lock Assembly.
    6. If all above steps fail to correct situation, replace control."
    Feb 24, 2011 | Frigidaire GLEB27S7A Electric Single Oven
    When I turn on my oven for cleaning it shows a f9 problem...could you help me with that
    An F9 error code on a General Electric oven indicates that the oven's electronic control system has detected a problem with the automatic door lock. The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode. The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
    Things You'll Need:
    • Ohmmeter or multimeter
    • Phillips screwdriver
    #step1
    Disconnect power to the oven.
    Step 2
    Open the oven door. Remove three screws from underneath the oven's control panel. Lift the control panel straight up to disengage the mounting pins on the top corners of the panel, then tip the panel toward you.
    Step 3
    Inspect the door lock mechanism. The mechanism is in the lower left area of the space behind the control panel. Rotate the cam on the door lock mechanism to be certain it moves without binding. Replace the mechanism if its mechanical parts do not function properly.
    Step 4
    Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation. Repair wires as needed if defects are present.
    Step 5
    Locate the six-pin connector on the door lock motor on the right end of the door lock mechanism.
    Step 6
    Rotate the cam on the door lock mechanism to the unlocked position. Test the resistance between Pin 3 and Pin 1 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 2 of the door lock mechanism if the resistance reads other than 0.
    Step 7
    Rotate the cam on the door lock mechanism to the locked position. Test the resistance between Pin 3 and Pin 2 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 1 of the door lock mechanism if the resistance reads other than 0.
    Step 8
    Contact a certified repair facility if the source of the F9 code has not been discovered.
    Troubleshooting the oven with the electric power turned on is a job for a certified technician.
    Do not perform troubleshooting on the oven with the power connected. Personal injury and damage to the oven can result.
    Aug 04, 2010 | Microwave Ovens
    How to start oven in PROPANE STOVE
    Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
    Component Test Procedure Results
    Electronic
    range control
    F1−1 –Upper Oven >650°F with door unlocked.............................
    F1−2 –Lower Oven >650°F with door unlocked.............................
    F1−3 –Upper Oven >950°F with door locked.................................
    F1−4 –Lower Oven >950°F with door locked.................................
    F1−7 –Membrane switch is not responding ...................................
    F3−1 –Upper sensor is shorted at (< 100 ω) or
    open at (>5 K ω) ...............................................................
    F3−2 –Lower sensor is shorted at (< 100 ω) or
    Check actual upper oven temperature,
    if > 650°F check sensor.
    Check actual lower oven temperature,
    if > 950°F check sensor.
    Check membrane switch for connection or damage.
    Check upper sensor, harness, and connections
    Engineering
    Test Mode
    Press BAKE pad.
    Enter 100°F using the number pads.
    Immediately push and hold BAKE pad for appropriate oven
    approximately 3 seconds.
    This mode can also be entered by pressing the hidden pad
    for 3 second located to the left of the lower oven light pad.
    Used to view the actual oven temperature for both ovens at all
    times, even when an oven function is active.
    This mode will also display the current fault code for 5
    seconds in the time digits.
    Fault codes
    accessed
    through
    Engineering
    Test Mode
    F0−0 –No fault .................................................................
    F1−5 –Upper hardware failure within control ....................
    F1−6 –Lower hardware failure within control.....................
    F1−8 –Shorted key in membrane switch ..........................
    F1−9 –Internal communication errors within control .........
    F1−A –Upper latch switches ............................................
    F1−B –Lower latch switches.............................................
    F1−C –Upper door switch.................................................
    F1−D –Lower door switch.................................................
    F1−E –Sensor input not calibrated ...................................
    F1−H –EEPROM error .....................................................
    F1−L –Temp in ovens are the same for long period .........
    F1−N –Internal voltage on control not working .................
    F9−1 –Upper lock switch is not correct.............................
    F9−2 –Upper unlock switch is not correct.........................
    F9−3 –Control does not see upper door lock....................
    F9−4 –Lower lock switch is not correct.............................
    F9−5 –Lower unlock switch is not correct.........................
    F9−6 – Control does not see lower door lock ...................
    EE –Control cannot read E-PROM. Unit will shut down.
    Default from factory
    Replace control
    Replace control
    Check membrane connection
    Replace control
    Check latch wire harness
    Check lock wire harness
    Verify sensor is operating properly
    Replace control
    Replace control
    Check lock wire harness, and lock switch
    Disconnect power for 60 seconds. If EE reappears, replace ERC
    Test Mode This mode must be activated within the first 5 minutes of
    power up.
    Press BROIL and CANCEL pad for approximately 3 seconds.
    If oven temperature is greater than 400°F, the Test Mode
    cannot be activated or will abort if active.
    Press and hold individual pads for 4 seconds to activate.
    Display will have dashes in all segments to indicate the mode is
    active.
    Upper Bake: Energizes upper bake element
    Lower Bake: Energizes lower bake element
    Upper Broil: Energizes upper broil element
    Convection Bake: Energizes convection fan
    Upper Oven Light: Energizes upper oven light
    Lower Oven Light: Energizes lower oven light
    Upper Clean: Energizes upper motorized door lock
    Lower Clean: Energizes lower motorized door lock
    Stop Time: Energizes Beeper
    Cook Time: Displays error codes
    Timer 1: Energizes ROM version
    Timer 2: Energizes EEPROM version
    Keep Warm: Cooling Fan
    Clock: All display segments light
    If functions do not perform as specified, replace ERC
    Oven
    temperature
    adjustment
    Push BAKE pad.
    Enter 550°F using the number pads.
    To decrease or increase oven temperature. Push AUTO SET
    pad until negative or positive numbers appear. Oven can be
    adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
    To avoid over adjusting oven move temperature -5° each time.
    Push OVEN CANCEL button.
    Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
    Frigidaire oven f9 code
    Here's the info from the service manual:
    "Fault Code: F9
    3. Wiring Problem.
    1. Press CLEAR key.
    Switch circuits.
    P4.
    - www.fixyourboard.com
    Jul 25, 2009 | Frigidaire FEB30S5D Electric Single Oven
    I accidently put the lock on my oven.Now the lock will not come off. Please help
    Hi
    The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above.
    To lock the control panel and both oven doors:
    1. Press and release Cancel.
    2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
    To unlock the control panel and both oven doors:
    Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
    Please see this link for more information as how to disengage the lock on your Jenn Air Oven---
    Door Lock On Oven
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    Apr 21, 2009 | Jenn-Air SVE47100 Slide-In Electric...
    GE Double Oven doors locked and circuit not responding
    Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
    Good luck,,,,,,,,,,,,,,,
    Jan 02, 2009 | GE Profile JTP56 Electric Double Oven
    My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
    Control panel and oven door lock
    The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
    1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
    Dec 22, 2008 | Jenn-Air Electric Double Oven
    How do use self clean service?
    CAUTION: SHOULD AN OVEN FIRE OCCUR,
    CLOSE THE OVEN DOOR AND TURN OFF THE
    OVEN. IF THE FIRE CONTINUES, USE A FIRE
    EXTINGUISHER. DO NOT PUT WATER OR FLOUR
    ON THE FIRE. FLOUR MAY BE EXPLOSIVE.
    To set the controls for a self-clean cycle:
    For satisfactory results use a 2 hour self-clean cycle for
    light soils and a 3 hour cycle for average to heavy
    soils.
    1. Be sure the clock shows the correct time of day.
    2. Press Clean. "— — —" appears in the display.
    3. Press the Up Arrow until "3:00" appears in the
    display for a 3 hour cycle, or press the Down Arrow
    until "2:00" appears in the display for a 2 hour cycle.
    4. As soon as the Up Arrow or Down Arrow is
    released, "CLN" appears in the display.
    5. As soon as the controls are set, the motor driven
    lock will begin to close automatically and the "LOCK"
    indicator light will flash. DO NOT open the door while
    the light is flashing (it takes about 15 seconds for the
    oven door to lock).
    6. The "LOCK" light will glow until the cleaning cycle is
    completed or cancelled, and the oven
    temperature has cooled.
    When the self-clean cycle is completed:
    1. The time of day or “END” will appear in the display
    window and the “Clean” and "LOCK" light will continue
    to glow.
    2. Once the oven has cooled down for about 1 HOUR
    and the "LOCK" light has gone out, the oven door can
    be opened.
    3. If “END” is in the display and the “Clean” indicator
    remains on, press Clear/Off. The time of day will
    appear in the display.
    NOTE: When the oven is cool, wipe away any residue
    or powdered ash with a damp cloth or paper towel.
    Stopping or interrupting a self-cleaning cycle:
    If it becomes necessary to stop or interrupt a selfcleaning
    cycle.
    1. Press Clear/Off.
    be opened.
    3. Restart the self-clean cycle once all conditions have
    been corrected.
    How the ES 200 operates:
    CAUTION: NEVER ATTEMPT TO REMOVE EITHER
    THE BAKE OR BROIL ELEMENT WITHOUT DISCONNECTING
    ELECTRICAL POWER FROM THE
    RANGE. ELECTRICAL POWER IS CONNECTED
    TO THE ELEMENTS WHENEVER ELECTRICAL
    POWER IS CONNECTED TO THE RANGE.
    The ES 200 electronic oven control system is made up
    of three parts that control the bake and broil elements,
    and the locking of the door in the self-clean cycle.
    1. Electronic oven control.
    2. Oven temperature sensor.
    3. Oven door lock mechanism.
    Dec 06, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
    Kitchenaid superba stove
    Control Lock
    The Control Lock shuts down the control panel pads to prevent
    unintended use of the oven. The Control Lock is preset off;
    however, it can be enabled.
    When the control is locked, only the TIMER SET/START and
    TIMER CANCEL pads will function.
    The Control Lock is preset unlocked, but can be locked.
    Before locking, make sure the oven, the Timer and Timed Cooking
    are off.
    To Lock:
    1.
    Open the oven door.
    2. Press and hold the number pad 3 CONTROL LOCK for 5
    seconds.
    A single tone will sound and “START?” will appear on the
    display.
    3. Press START. “CONTROL LOCK” and a picture of a lock will
    appear on the display.
    To Unlock:
    1.
    Open the oven door.
    seconds.
    A single tone will sound and “CONTROL LOCK” and a picture
    of a lock will disappear from the display.
    Sep 29, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
    Electrolux 30" Self-Cleaning Slide-In Double Oven Electric Convection Range - White Logo
    148 people viewed this question
    Top Electrolux Kitchen Ranges Experts
    Rommel Balcita
    Mike Henne
    Level 1 Expert
    Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
