Question about kawasaki Garden
Carb repair A picture so I can make sure I put it to gether right
  • 333 Answers
this is basic diagram
Posted on Aug 20, 2010
I want to put back my wires to grill element how on AEG E4100 1 OVEN
Unfortunately, this isn't a wiring diagram but can also serve.
See the pictures below:
Dado
Apr 24, 2015 | AEG Ovens
How do I clean the carburetor on Briggs & Stratton engine model 20066
its pretty simple take float bowl off remove pin from float take off the main thing you need is compress air to blow all the passages in carb out 150 psi compressed air then put it back to gether
Sep 13, 2014 | Briggs & Stratton Garden
Repairing a Briggs and Stratton Quantum 35 mower engine. How do you replace the metal starter pawls in an older Briggs & Stratton mower engine
take cap off drive the pin out the bottom from the top replace starter pawls and springs put back to gether drive the pin back in checking making sure not to thight if it is drive pin back some until it spins freely
Aug 22, 2014 | Garden
Latitude 620 system #G3CPPB1-595B master bios password
if you forgot your bios password open up your laptop and remove the cmos battery from the mobo for like 30 seconds and put it back in.
this will reset your bios password.
make sure the computer is unplugged and no battery is in it when you do this and take pictures of everything you do with the laptop and screws so you know how to put it back to gether also watch youtube tutorials on how to do it as well...
IE "how to remove cmos battery from latitude 620 system"
Jul 23, 2014 | Dell Computers & Internet
Bad boy mower
sounds like dirty carb get a rekit clean and boil the carb what i mean by boil go to auto store buy strong carb cleaner put the strip carb in it for two days take it out using compressed air we use 300 lbs blow every hole out in that carb if yu see tiny holes take a wire and poke the blow them out again put back to gether with other parts you boiled like the jet and down spout turn adjust ment screw out 4 turns that should get it started the run and adjust from there should run fine main thing dirty carb problem
Jul 10, 2013 | Garden
Not starting
need to clean carb, sounds like its gummed up with old gas, take off and take apart to clean put back to gether put back on , check fuel lines for cracks also
May 16, 2012 | Garden
I just bought a 650 seca that sat for a long time it wont start, the starter is working fine and it turns over but it will not fire off, carbs maybe? and is there anything special I have to do to reinstall...
I would drain the gas tank and refill it with supreme gas for starters. If you have the tank drained, remove the carbs and at the very least, spray carb cleaner through them. I recommend a complete rebuild and soaking them in carb cleaner over night. Check for spark, the module may have died on it. Put the unit back to gether and it should run. Change the oil also. I hope tis helps.
Jul 10, 2011 | 1982 Yamaha XJ 650
Husqvarna 455 chain saw will not start
Check to see if you have a spark pull the plug out plug the cap back on it hold it to the head and pull the cord see if it sparks It likely will most of the time with small engines its the carburator and what it needs is to be cleaned they sit around and get used once every couple of years especlly two stroke engines tund to get gumed up If you can take the carb apart clean it with carb or brake cleaner blow out the passages and clean the neddle valve you don;t to mess with the adjustments and put it back to gether it will work like new
Nov 22, 2010 | Husqvarna Chain Saw 20" Bar
Honda crf 125 boggs out when twisting throttle but when choke is put half way, bike has excellent response. whats going on? how do i fix it?
hi m8,, your carb is blocked ,undo the circlips from the air box,and cylinder , pull carb out,,unscrew or undo the screws to the throttle on the carb,, turn carb upside down, undo the 4 screw at the bottom,u might a rusty lookin colour in the carb ,that needs to be cleaned, undo the brass lookin jet screw ,and blow down it,, then put all back to gether, ,if u still have a prob come back in and il take u threw next step,,
Apr 19, 2009 | 1983 Honda XL 125 R
Garden Logo
281 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
