Question about Cameras
I bought an HV20 Cannon camcorder and I have inserted the battery however I don't know how to insert the lithium button. The directions aren't clear.
    Problem Solver:
  • 5 Answers
I bought an HV20 Cannon - 2777262.jpg Please
Posted on May 03, 2008
Two brand new Hitachi BSL1815X Lithium Batteries won't recharge (UC18YGSL charger and DS 18DSAL drill)
These batteries have big problems that Hitachi doesn't address very well. Unlike NiCad batteries, Lith-Ion ones must be periodically used and recharged to retain their battery functions, i.e. if they have been sitting on the shelf at a store for an extended period of time, chances are they will be dead when bought and will not accept a charge. If they go dead i.e. no little red light on the charger when you plug the battery unit in...it's basically junk.
If you can return them or exercise the warranty do so. If / when you get new ones DO NOT completely discharge them like you would NiCads. Lith-Ion batteries do not have the "battery memory" issues that NiCads have which means you don't lose running time if you don't fully discharge the battery unit prior to recharge. Completely discharging before recharge will ultimately kill them. Use the 1815X till almost dead and then charge it. It is also recommended Lith-Ion batteries not be stored fully charged i.e. charge the 1815X fully, drive a couple bolts or screws, remove the battery unit and then put it away. Do not leave battery unit plugged into the tool when you put the tool away. This will discharge and kill the battery unit.
There are non-Hitachi substitute batteries now on the market. I'm guessing the same precautions apply but I don't own one of the replacements so I don't truly know.
The actual batteries in the Hitachi BSL 1815X are Sanyo UR18650SAX lithium ion batteries. Lithium Ion cells aren't all that easy to get commercially because of handling & safety requirements. Not certain if you can take apart the 1815X and swap out the bad Sanyo cells.
Jan 07, 2011 | Hitachi Koki Usa WH18DL Lithium Ion...
Problem for Canon HV20 HDV Digital Camcorder Camcorder not loading cassette
This is usually caused by a defective component in the tape detection circuitry and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
Aug 12, 2010 | Canon HV20 HDV Digital Camcorder
SIR/MAM. WHEN EVER I USE MY CAMCORDER GR-DVX9
There is often a small battery inside the unit or accessed from outside that holds the memory that the device was last set. Yours is defaulting to maximum zoom. And in fact it does.
Built-in Clock's Rechargeable Lithium Battery
To store the date/time in memory, the clock's rechargeable
lithium battery is integrated in the camcorder. While the
camcorder is connected to an AC outlet using the AC
Power Adapter/Charger, or while the battery pack attached
to the camcorder continues to supply power, the clock's
rechargeable lithium battery is always charged. However,
if the camcorder is not used for approx. 3 months, the
clock's lithium battery will become discharged and the
date/time stored in memory will be lost. When this occurs,
first connect the camcorder to an AC outlet using the AC
Power Adapter/Charger for over 24 hours to charge the
clock's rechargeable lithium battery. Then perform the
date/time setting before using the camcorder.
Note that the camcorder can be used without setting the
date/time.
Your manual in English. You can use a smartphone with Google translate and the camera feature to read what is shown on the camera in Japanese and change the operating language to English.
http://www.videocamera-manual.com/manuals/jvc/JVC_GR-DVX9_MiniDV.pdf
Nov 03, 2017 | JVC GR-DVX9 Mini DV Digital Camcorder
Canon HV20 or HV30 Service Manual? Does it exist?
Hello, you can find the official service manuals for the canon in the below links, i had bought hv30 and the manual is great
HV30 Service manual:
http://goo.gl/WibRy
HV20 Service manual:
http://goo.gl/4kkHS
and if you need other service manuals you can search for them here
http://ebookswizard.tradebit.com
Hope it helps.
Aug 21, 2009 | Canon VIXIA HV30 DV Camcorder
How to charge a EFORCE FH50 Compatible Battery
Its appealing simple; Probably you will be accepting sony handcam charger accepting a cable thats declared to fit into ur camcorder and again allegation the battery. For charging the EFORCE FH50 battery, you just allegation to admit that the of the aforementioned cable anon into the battery(DC-IN slot) and bung ur charger into the bank socket. It commonly takes 135 mins to absolutely allegation the battery. Once answerable the LED at tthe DC-IN aperture will about-face off. (During charging its yellow)3_27_2012_9_39_48_am.gif
Apr 05, 2009 | Sony Handycam HDR-CX12 Flash Media...
Batttery icon shows low battery even though new batteries are ins
I am not sure if this will address your problem but it is worth trying.
Make sure the record/playback mode switch is not in an intermediate position. Push it firmly all the way up. Also ensure that the mode button is not between clickstops. Then try to operate the camera
If that does not help, try the following. Take all the batteries out, including the lithium battery which keeps the clock going. Also take the SD memory card out. Leave the camera sit overnight.
Obtain new batteries - conventional alkaline AAs and a lithium type CR1220.
Next day, clean all the contacts for the AA batteries with a cotton-bud and contact cleaner or isopropyl alcohol. Let dry. Then insert the new lithium battery. Next insert the new AAs and try to turn the camera on.
If it works, insert the SD card. If it does not work then there is probably an internal problem and it should be serviced.
Feb 06, 2009 | Canon PowerShot A720 IS Digital Camera
Charge Indicator light on HV20 never lights
The battery was shipped dead. I charged it over night and the light started working.
Sep 11, 2008 | Canon HV20 HDV Digital Camcorder
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Mar 15, 2007 | Canon ZR60 Mini DV Digital Camcorder
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
