Question about EliteGroup ECS Desknote A-901 Notebook
Ecs desknote a928, 2ghz cpu, 1 gig ram, 60 gig 7200 rpm, win xp sp2, question: computer starts, fans run, hard drive runs, no monitor, tried external monitor and it does not work either...motherboard bad? cpu bad? memorybad????
  • 1 more comment
  • rgadkisson Aug 20, 2010
    have a ecs desknote a928, 2ghz cpu, 1 gig ram, 60 gig hard drive, computer comes on fans are running....screen does not light up..connected to external monitor and it did not light up...could this not be a cpu problem? other than the motherboard as a previous expert said to change out motherboard? memory? thanks what do you think
    why would it not boot to bios with Ram removed?
    ecs desknote a928, 2ghz cpu, 1 gig ram, 60 gig 7200 rpm, win xp sp2, question: computer starts, fans run, hard drive runs, no monitor, tried external monitor and it does not work either...motherboard bad? cpu bad? memorybad????
    why would this notebook not boot to bios with the memory stick out? then the solution would come down to cpu or motherboard, and I probably got another cpu around here that works I can stick in it to see if it will work..thanks
    BearWeb
    · Rank: Guru
    · Rating: 92.97%, 622 votes
    There could be multiple different reasons for this.
    Possible Problems and Troubleshooting
    1) The RAM (Random Access Memory) may have gone faulty.
    2) The Motherboard may have been damaged.
    3) The CPU is faulty
    4) The Hard Disk is damaged - But then the laptop would still boot to the BIOS and tell you that no Hard Disk is detected so this is not your problem.
    5) The ribbon cable from the Motherboard to the screen is damaged - But you said that an external screen doesn't work as well so this is not your problem.
    This only leaves the RAM, CPU and Motherboard as possible problems.
    Solution
    You can buy a chip of RAM from a computer store and open the laptop and replace the RAM and test if it is working. This would be the cheapest way of finding out the problem. If it doesn't work, you will need to take your laptop to a specialist to get them to test if the problem is the CPU or the Motherboard, then you will just need to buy the part that needs to be replaced.
    Thank you for using FixYa! Have a great day and please remember to rate this solution.
    Best regards,
    BearWeb
    Brigadier General:
  • 5,158 Answers
You have to toggle the outboard video feed to on. it's two keys on the keyboard so look them over. likely a control key and one of the keys at the top near the numbers. hook up another outboard monitor then try it. if it works the backlights have failed. what you can also try is shining a flashlight sideways to the screen to see if there is an image there.
Posted on Aug 20, 2010
    President:
  • 357 Answers
Solution
Best regards,
BearWeb
  • Dustin Ellse
    Dustin Ellse Aug 20, 2010
    A laptop will not boot without RAM in it. You can try put a different CPU in the laptop yourself but it must be the same as the one you take out. Or you can check on Google the types of CPU's that your computer can take. If you post your motherboard make and model i can search for you and find out which CPU's will work.
    Best regards,
    BearWeb
    Genius:
  • 1,478 Answers
The problem is from the motherboard on you laptop, the motherboard on the laptop is bad and will need to be replace.
Take care.
1 GB increase
hi
not every motherboard or on board video is compatible with windows 8
what windows was it running previously
windows 8 was designed for 64 bit platforms which requires 4 gig of ram but you have to also take into account the other hardware components and there maximum configuration
i have run win 8 on 2 gig of ram but it struggles with you tube downloads
i upgraded the ram to 4 gig and run win xp win 7 and win 8.1 on the hard drive
cheers
Apr 05, 2014 | E-Machines eMachines Desktop PC
Computer will reboot on Virus/Spyware scan at random. I have: 1. Installed clean XP SP2 parallel system and booted that one. Same problem. 2. Memory Test at boot time is OK. 3. Air circulation from Power...
The weak airflow from the power supply unit (PSU) is suspect. Virus / Malware scanning is a disk and processor intensive operation - resulting in greater load on both. Increased load translates to heat. Check to be sure that the processor (CPU) fan is running, too. An overheating PSU and CPU can cause all types of problems.
Are you using a genuine XP install disk/image or a disk of questionable origin? Use of bogus OS disks is "asking for trouble".
If your system BIOS or set up (accessed during boot) allows, try to located the page that displays component temperatures and fan speeds. Check this immediately after rebooting from a an unplanned shut down - if unable to locate this set up page, download HWMonitor at:
http://www.cpuid.com/hwmonitor.php
It is a free program - choose the 32 or 64 bit version. Note fan RPM and CPU core temps to help determine where heat is coming from - or which fans aren't operating correctly.
Sep 18, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Cpu lead lights on but no display in monitor
check the RAM condition, For that remove the RAM from mother board and clean the two side of RAM contact terminals wiping with the eraser and insert it again into the mother board.
if you have using more than one ram just remove both the RAMs reinsert one by one after cleaning the RAMs one by one .
Jul 07, 2009 | EliteGroup ECS 755-A2 Motherboard
Install Win XP SP 2
Yes you can, Do I recomend it, no, Why?
Windows easily uses up to 756MB of RAM to run the O/S alone but can run at a minimum of 512MB.
I have personally seen it run on as low as a 900Mhz processor, 256MB of RAM and on a 10 gig hard drive.
If you decide to install windows XP on the specs you describe above please note the following.
1. System will be very slow and have lengthy start up times.
2. Applications may crash or take a long time to open.
3. With all the updates for WinXP you will easily use 8 gigs for installing XP and its updates. Not to mention whatever software you will use/install.
4. On a system with those low specs, you probably have a low end video card whcih may result in: A. chooppy windows, screen freezing, system crashes and lock ups, low video graphics all around.
I would probably go with windows 2000 instead. If your bent on having XP, at least upgrade the RAM to as much as possible. Then install windows and only install the programs you really need, remove any other junk.
Hope this is of some help to you, good luck
Feb 17, 2009 | Dell Inspiron 4000 Notebook
Dual boot problem
first install win98(dont re boot for xp installtion),  while running 98, insert cd of xp and install xp from there.
Nov 18, 2008 | Biostar P4M80-M4 Motherboard
CPU upgrade problem
Hi there
what are your pc specs , like ram ect. So we can find out what is wrong. please check your cpu settings and reset the pc bios to see if that hasnt solved the problem
thanks
roger
Nov 12, 2008 | AOpen AK77-8XN Motherboard
I have a compaq with a 90 gig hard drive, at presenr I am running 384 bytes of RAM. How much will this PC safely handle?
Depends! The amount of RAM has nothing to do with capacity of the hard drive. If your motherboard is a P3, it probably has to memory slots that will handle 256mb each (512 total). It sounds like you have a 128mm chip and a 256mb chip installed now. I won't even attempt to run XP with less than 256mb of RAM. You can run XP with 128mb, but not very well. With Windows XP SP2, you will have to have at least 256MB. Most P4 or newer computers use DDR RAM wich can be bought at larger capacity (ie 1000MB).
Apr 18, 2008 | Computers & Internet
I can't get the full capacity of 320 gig drive
the hard drive you bought is not compatible with your motherboard. I am pretty sure that your board is only compatible with IDE ATA hard drive. you can still use it as external hard drive though.
Feb 09, 2008 | Gateway M305CRV Notebook
Lanparty kt400a
yeep likely motherboard. test cpu in good system?
Nov 02, 2007 | DFI LanParty KT400A Motherboard
EliteGroup ECS Desknote A-901 Notebook Logo
272 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
