Question about HP Deskjet 2460 InkJet Printer
Print spooler service is not running - HP Deskjet 2460 InkJet Printer
    Guru:
  • 731 Answers
  1. Click Start ---> Run
  2. In the run window type "services.msc" click OK.
  3. Look for print spooler service and right click on it.
  4. Select Start from drop down.
Posted on Aug 21, 2010
My printer spoler is not working
Hi g k,
Have you tried restarting the print spooler from services?
Start the Print Spooler service from the Services console
  1. Click Start, click Run, type services.msc, and then click OK.
  2. Right-click the Print Spooler service, and then click Stop.
  3. Right-click the Print Spooler service, and then click Start.
Start the Print Spooler service at command prompt
  1. Click Start, click Run, type cmd, and then click OK.
  2. Type the following commands at the command prompt: net stop spooler
    net start spooler
    exit
    Note Press ENTER after each command line.
Hope this helps, and please rate:)
Gary
Aug 01, 2013 | Samsung Office Equipment & Supplies
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
Where i could see the printer spooler?
I open the run command you can type: net start spooler
(You will get a message that says the print spooler service has started)
If you still have issues open the run command and type: services.msc
it will display a list, where you can find print spooler.
From there you can right-click on it and set it so it is started and runs automatically.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 25, 2013 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
Print spooler is not running
Please try these steps:
  1. Browse to Start -> Run... and type NET STOP SPOOLER (this will stop the print spooler service)
  2. Type NET START SPOOLER (this will restart the print spooler service)
Try to print again to verify that the problem is fixed.
Feb 24, 2012 | Lexmark X1150 All-In-One InkJet Printer
Spooler
Try the steps below to re-enable your print spooler:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Dec 17, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Z615 Error message,Printing Failure,current print job canceled,print status 15% completed,shows cartridge info.Power light blinks on-off,have reinstalled driver,rebooted windows. Widows XP
It could be the Print Spooler service on your computer. Make sure the service is running. - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
May 24, 2011 | Lexmark Z615 InkJet Printer
Operation could not br completed. The print spooler service is not running
Hi There,
If your print spooler service is not running, then follow the below steps to get it working :
Step 1 :
* Start > run > services.msc > ok
* Select the service name called print spooler from the list.
* Check the status on the print spooler service, if it is stopped, then right click and select start or restart.
* Then the spooler service will start working....
Step 2 : ( NOTE :USE THIS STEP ONLY WHEN YOUR STEP 1 DOESN'T WORK )
In this case, we assume that the print spooler service is gone bad and we would have to recreate the spooler service.
* Start > run > cmd > ok
* Type: sc delete spoolsv (this will delete the corrupted spooler for us to create a new print spooler)
* Reboot the system and after rebooting the computer back.
* Type: sc create spoolsv (this will create a new print spooler service)
* Reboot the system and this time the print spooler service is a new and fresh spooler and it should work normal and perfectly.
Enjoy printing !!
Oct 22, 2010 | Office Equipment & Supplies
What does it mean when i get the error message print spooler services not running
you need to turn it on, Go, . START>>RUN>>services.msc enter. When the services screen comes up, scroll down until you find the "Print Spooler" Enable it, Start it, and set to Automatic, reboot, ya good to go.
Mar 15, 2010 | Brother HL 2140 Laser Printer
My print spooler is not running
If you are getting a message that your print spooler service is not running, possibly you have the print spooler service turned off.
To start the print spooler service in XP:
Click on Start
Click on Run
Type "services.msc" and hit Enter or press OK
In the services window look for "print spooler service"
Click on the Print spooler and on the top left corner Click on "Start"
Reboot the computer. You should be able to print now.
Please get back for any further assistance.
If you find this resolution helpful, please do not find to leave your comments and ratings.
Thank you for choosing Fixya.
Feb 26, 2010 | Canon PIXMA iP1600 Printer
Microsoft said spooler subsystem app not working
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer with your spooler services enable now.
YBC (/\)
Nov 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
HP Deskjet 2460 InkJet Printer Logo
Seeker5211
Seeker5211
