Question about Raymarine A65 Combo GPS Chartplotter/Fishfinder
I have a raymarine rl70 plus radar/chart plotter. The backlight does not work. Is this an easy fix? Where can I buy the parts. Thanks for any help or suggestions.
A replacement backlight is available from a company called Being Seen Technologies,
I believe their toll free phone number is 888 457-0117
good luck
Posted on Jul 04, 2009
I have one of these same units brand new for sale real cheap
Posted on Jul 10, 2008
Raymarine dsm300 Circuit breaker keeps tripping g when connected to chartplotter
either the cord to the chart plotter is faulty or the chart plotter itself is dead short
have an electrician do an insulation test and circuit test on the cord and plotter unit
Jan 08, 2017 | Raymarine Boating
My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Apr 13, 2010 | Raymarine C80 GPS Receiver
Connect Ratheon RL 70 to Raymarine E80
The two devices can share Nav data only. No radar, Sonar or Chart will be shared.
Hook the RL70 and the E80 together on SeaTalk and all data will be shared both ways. Alternatively, it could be done with NMEA 0183, which is directional, or you could also translate the RL70 data to NMEA 2000 and share it that way. As long as you have all Raymarine equipment, you are home free using a three wire Seatalk connection, with only two hooked up, Yellow and Bare, color to color.
Remember, this will share Nav Data only.
Nov 14, 2009 | Raymarine C80 GPS Receiver
The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Sep 27, 2009 | Raymarine A65 Combo GPS...
C120 displays NO DATA SOURCE in the radar section of the screen. ohns resistance test checked out. what else can it be?
1. you must have the latest software 4.29 the new scanner dont work with the old Software.
2. Be shure that you have really put in the connector of the cable inside the plotter its not so easy.
3.
try the plotter on an nother boat with an working system than you will know if its a problem with the antena or Plotter
Aug 06, 2009 | Raymarine C80 GPS Receiver
I Have a Raymarine Radar RL70CRC HSB2 the
If both plotter works but they have no comunikation
RESET the RL 70 AND L760
This is how it works
press the powerbutton when you have picture press the menu bottom
than systemsetup and than four seconds the menu bottom.
Do this on both plotter normaly after this it works again
Jun 11, 2009 | Raymarine RL70CRC GPS Receiver
Rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
Jul 12, 2008 | Raymarine RL70CRC GPS Receiver
Raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
May 05, 2008 | Raymarine RL70CRC GPS Receiver
Replacing an RL-70 with an RL 70-CRC
I did exactly what you wish to do a couple of years ago. It was a 5 minute job, cut out the same except the new unit needs a little more space behind and it was a plug for plug swap. Works great and swaps data between the matching chart plotter to give chart overlay on the radar
Richard
Jan 03, 2008 | Raymarine RL70CRC GPS Receiver
Raymarine RL70CRC GPSRadar
Hi Matt,
There is a feature in these chartplotters called "Plotter Mode" that is often misunderstood and causes the exact problem you describe.
Press menu.....chart setup.....and scroll to the bottom until you see Plotter Mode in the list of options. It should be set in the OFF position.
If you have more than one display networked onboard check the setting in each one invividually.
What Plotter Mode does is allows the chartplotter system to access range scales not supported on the chart. It is not normally used for map-based navigation but more so for chartless electronic plotting (it can display routes, waypoints and track-recorder breadcrumbs.) open-ocean cruising, or for ultra-precise GPS operations (like a precision anchor drop, finding a very specific location etc. When plotter mode is on you can zoom in to a very, very small working area. The indicator it is enable is the cross-hatch background on the screen, the lack of map information, and the NO CHART DATA watermark on the screen.
Jul 30, 2007 | Raymarine RL70CRC GPS Receiver
Raymarine A65 Combo GPS Chartplotter/Fishfinder Logo
755 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
