Question about HP PSC 2210 All-In-One InkJet Printer
Printer keeps displaying paper jam but there is no paper present in any part of the mechanism.
  • 245 Answers
Hi
Quite a few HP printers use the same error message for paper jams and ink cartridges not being seated properly.The link below is to your User's manual,it should help you find where even a small torn corner of paper can jam your printer as well as how to check your ink cartridges.
Post back with any questions,and if this helps would you please rate my post?
Thanks
Bob
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=79499
Posted on Aug 20, 2010
My ip100 printer keeps displaying paper jam when there is no paper in the printer
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 10, 2009 | Canon iP100 Portable Printer
Displays paper is jammed message when there is no
There must be a bit of paper torn off and stuck in the sensor for the paper jam on the Output side of the printer. Look for a tiny bit of paper where one ought not to be.
Sep 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Paper jam error, but no jam present
mabey its the wrong paper youre putting in it:O?
Jan 03, 2009 | Office Equipment & Supplies
Paper jam report displayed but none present
Here are directions with video on solving the paper jam error:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00860153&dlc=en&product=3192753
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 08, 2008 | HP Photosmart C4280 Aio Printer
MP160 Error E3
I work in a shop repairing these printers and have had a large number with the same fault - displaying E-3 with no jam in the paper path. This is caused by a broken part in the paper feed mechanism that pevents the printer from taking the paper. The part located right at the bottom of the printer looks like two white gears connected together with a central spring. At present I am trying to find a supplier of the spare parts - will check back.
May 19, 2008 | Canon PIXMA MP160 All-In-One InkJet...
202 paper jam error, but no jam present
I cleared that error on one by replacing the fuser. It had a small piece of paper stuck in the roller.
Oct 30, 2007 | Dell W5300N Laser Printer
HP PSC 2210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
