Pioneer PL-300 Turntable plays records too slow
No, I have a PL-300 and its directly driven by a DC motor. I have taken mine apart to clean once before and noticed some potentiometers on the bottom. (There are holes on the bottom of the plastic casing for easy access using a small flathead screwdriver) Those might be to adjust speed. They could also be for tone though... It might also be that the electronic quartz-based speed controller is broken. With these old things its never easy to tell whats wrong.
Posted on Jun 27, 2008
    Novelist:
    Champion:
  • 236 Answers
I think it is a belt driver table. you can find a replacement belt maybe. but if it is servo controlled motor driven then adjustments to sped setting has to be done.
Posted on May 03, 2008
Pioneer Pl990 turntable sounds awful.... I have a pioneer pl 990 record player connected to a pioneer amplifier and a sony CD player. when I play an LP, the sound is bass heavy and I can hardly hear t
When the turntable plays, do you get a howling bass heavy sound? Have you tried turning down the volume and bass? If that corrects the problem, you have what's known as Acoustic Feedback. Check to make sure the tonearm is properly set up first. If it is, please visit my website at Audioserviceclinic.com. You may contact me there. Thank you.
Dec 13, 2014 | Pioneer PL-990 Turntable
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
Hello i have a pioneer pl-300 turntable. i bought it used and it's been working fine until today. now the needle skips ahead on the record. i am VERY inept with technical knowledge of turntables i just...
if its skipping ahead Almost like the needle is just gliding across the Record. It means your needle is bent, dirty or broken, Take it off and look at it closely.
May 30, 2011 | Pioneer Audio Players & Recorders
Re. pioneer pl 990 turntable can the lid be closed
No you cannot play while lid is closed and YES you need an amp/receiver amp
Feb 28, 2011 | Pioneer PL-990 Turntable
Converting a turntable from automatic to manual
I suppose the only way to do it would be to stop it functioning completely. The only way would be to dissasemble the auto function. What you would need to do is work out which parts are essential for the turntable operation and which only activate the return. So you need to whatch the mechanism working. You will need to remove the base and look at from underneath, just like going underneath a car!
I can't say for certain if you can do it, only you will be able to determine it can be removed without affecting the operation of the entire turntable.
May 21, 2010 | Pioneer PL-990 Turntable
Turntable tonearm returns but starts playing record over again.
http://www.vinylengine.com/library/pioneer/pl-570.shtml
on page 8 of the above service manual for your model it shows 4 electrical switches that tell the computer what 'state' the mechanism is in at any given time. Either one or more of the switches are intermittant or the mechanism has dried up grease that is slowing down the operation and basically gumming up the works. the old grease would have to be removed and replaced when it is causing binding. The switch just to the right of where is says "microswitch ksf-023" is an 'open air' type and so would be the most likely suspect. it simply needs to be cleaned with a super fine file designed only for cleaning switch contacts. THIS SERVICE SHOULD ONLY BE PERFORMED BY QUALIFIED PERSONNEL ONLY!!!!!
Jan 21, 2009 | Audio Players & Recorders
Pioneer PL-670 record rejects continually
Are the record size tabs sticking up through the turntable platter cover? They sense the size of the record being played and adjust the run out distance for either 45 or 33 rpm records.
Jan 04, 2009 | Audio Players & Recorders
Pioneer PL-570 turntable (c.1973)
Yes first check is that the Gnd wire from your turntable is connected to the Gnd (ground) post at the back of your amplifier with a good clean tight connection.
If the problem persists, check ALL your hi-fi components mains plugs for earth connections including your turntable, then remove the earth connections on all but one component so that you are left with only item earthed.
What does sometimes cause problems is if 2 or more hi-fi separates are earthed and connected to each other the earth cables along with the hi-fi interconnects form an inductive loop that picks up interferance such as mains hum etc.
Regards John
Sep 16, 2008 | Pioneer PL-990 Turntable
My turntable is playing a tad slow...it makes every record sound warped!
Hi CGS8021
Sounds like the belt is failing. You can get one from here
Where in the world are you? I will link you to the closest source.:)
regards
Robotek
Apr 12, 2008 | Pioneer PL-990 Turntable
623 people viewed this question
 Grubhead
Grubhead
