Question about Primera Technology Primera BravoPro printer
The CD pickup arm has just begun to push down too hard on a completed disc after it's been printed. It makes a growling noise and then tells my computer an unrecoverable error has occured. Any ideas?
  • stringed16 Aug 20, 2010
    Thanks for the quick reply!
    I've had a good look in and around the machine, but I can't see anything obstructing.
    The problem is just that the robotic arm is picking the blank disc up fine, but when it goes to collect the printed disc, it pushes down too far without coming back up, causing a terrible growling noise, until the error message comes up on the computer. Any other suggestions? Or is it time to get a new machine??
    Thanks.
  • stringed16 Aug 27, 2010
    Is there anywhere I can just purchase the robotic arm component, instead of forking out thousands of dollars for a new machine?
  • Primera Tech... Master
  • 11,800 Answers
This is caused by either the deformation of the arm - try to realign it, if necessary by force, or by the loss of the control of the motor by the processor of the printer - it moves beyond its limits because the motor isn't shut down quick enough.This cannot be fixed.
Unless you are willing to experiment with different methods of fixing it this printer has died. Time for a new one.
Posted on Aug 20, 2010
  • 3,083 Answers
Here is a blog about a similar sounding problem from churchproduction.com:
Many disc manufacturers put a clear plastic pseudo-disc on the top of the stack when they package their product, which I know to look for and discard. Memorex, however, also puts a black pseudo-disc on the bottom of their stack, which I've never run into before, and unknowingly loaded into the middle of the input bin. The robot arm picked up this black disc. Since it's a different thickness and also may have a slightly different hole diameter than a real disc, the disc fell off the robot arm while it was moving to load it into the burner, dropped on its side between the burner and the input bin, and promptly created an obstacle to the robot arm. When the arm tried to traverse back to the input bin, it smashed against the disc, knocking the input bin askew (now I know why the input bins aren't securely fastened to the publisher!), made a horrendous noise, and stopped.
Much to Primera's credit, once I cleared out the problem disc and set things right, the publisher functioned perfectly normal with no damage. And this user made a mental note to look more carefully at what I'm loading into the input bin.
I guess something in the loading mechanism could be making the sound, but my guess would be the gears that drive the laser lens are at the root of the problem, since the disc is spun and finalized at the end of a recording. Not an easy problem to figure out, or fix. Check to make sure no foreign objects have gotten inside, and are obstructing the mechanism. Aside from that, the unit will have to be disassembled to determine what's going on.
Maybe you're having a similar problem as first described, and can fix it easily. Good luck, and hope this helps.
CD Changer won't finish loading a CD
I had the same problem and found the cure for it. The drive belt was streched and when it started to close on the disc, the belt would slip and eventually show loading error..The two belts cost $4.50 at belts plus. Hope this helps you
Feb 21, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
97 ford in console cd changer
Please provide the model and the make to assist you better
Apr 18, 2008 | Car Audio & Video
After 4 years our washer has begun growling and grinding when water fills atbthe beginning of a new cycle. It lasts for 10 or 15 seconds and then goes away. The machine then completes the job. Is some part...
If it is making the noise just as it is filling then you need to replace the "water inlet valve". If you can post your model number I can direct you to the part you need.
Aug 03, 2011 | Kenmore Washing Machines
My whirlpool ice maker makes a noise like its growling or like a
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
May 15, 2009 | Whirlpool Freezers
Growling noises from computer and is very slow at times.
Is the growl coming from the speakers? If not, I only know of three other things that have moving parts that could make such a noise. Fans, hard drives or optical drives (CDrom,DVDrom, etc). I've had hard drives make make a screeching noise when they start to go bad. I would back it up ASAP.
Dec 20, 2008 | Computers & Internet
Makes growling noise when first started, quits once warm.
suspect noise from motor repair cost may exceed value but may want to ck rear drum bearing also this will mean pulling tub out bearing is on rear drum shaft not a hard fix but will need some mechanical know how ..good luck
Nov 13, 2008 | GE Dryers
I works mechanically, but doesn't play the CD
try cleaning the lens first use a lint free swab and GENTLY clean the lens. don't use any liquid on this. if that doesn't work then load a disc and gently spin the disc when it lifts into load posistion. if begins to spin on it's own then replace the spindel motor. if it still does not spin, replace the optical pickup, the EF sensors inside the pickup no longer have the ability to read (see) the disc.
Feb 03, 2008 | Teac PD-D2380 5-Disc CD Changer
Noisy dishwasher
This is a known issue for GE dishwashers and may be similar for other models too.  The fix is simple.  The noise is due to vibration of the arm for the middle sprayer.  Just secure it with a tie wrap or wire and the noise should be gone.
Refer to the following link for my earlier response to a similar issue which fixed the problem.
http://www.fixya.com/support/t204050-ge_adorda_dishwasher
Oct 26, 2007 | Dishwashers
Disc changer
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Oct 20, 2007 | Alpine CHA-S624 6-Disc CD Changer
Primera Technology Primera BravoPro printer Logo
104 people viewed this question
Top Primera Technology Office Equipment & Supplies Experts
Josh Whitehead
Josh Whitehead
Guy Loeffler
Guy Loeffler
Level 1 Expert
Are you a Primera Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
