If there is a port for an iPod cable then you just pull head unit and connect it. Most people run it out and through the glove box. If there is no port for it then you have to buy a kit.
Crutchfield .com has all that stuff and if not, go to your local car audio shop and ask them to rip you off for the parts and installation.
you need a 2.5mm jack lead connect 1 end to your IPOD/MP3 player and the other end to the AUX IN on the front of the head unit then select AUX on the head unit and play on the IPOD/MP3 player and it should work
This radio has no IP-Bus (Pioneer's peripheral plug in) plug on the back of the unit or any connection for USB or 1/8" stereo headphone jack on it. You will not be able to conect an iPod to this unit. Visit the website at www.pioneerelectronics.com to see their current iPod solutions. They have multiple head units that allow for you to charge iPod and iPhones as well and give you control through the head unit or through the iPod itself.
There are many ways to do so. Each of which is progressively more expensive.
All of these plug into the Ip bus plug in the rear of the unit.
Most of these can be found on Ebay or Amazon
1: An IP bus to RCA plug then you need a RCA to 3.5mm plug wire. (note this is a lower quality) $10-$30
2: An ip bus to Ipod connect plug. (Better sound quality, charges Ipod, does not allow Ipod control from the Head unit, only from the Ipod) around $15-$30
3: An ip bus to Ipod Connectivity unit (same quality as #2 but allows for Ipod control from Head unit)
$100+
Add Alpine's optional "Full Speed" connection cable and you'll be able to use the CDE-9872 to control your iPod. -Crutchfields website
This is compatible with first and second generation iPods touch. fyi- if you have a mini-stereo aux in jack on the deck you can connect a ipod touch compatible mini stereo cable to the earphone jack of your ipod.
The ipod is supplied with a USB out cable and the head unit is USB compatible.It has a USB out.Connect the ipod "out "cable to the USB of the HU and switch over to USB mode on head unit. Switch on the ipod & play .
As for erahs problem ,these pioneer head units have "switchable"AUX modes.
with the power "off"(the HU power off)press the multicontrol at the centre for 3/4 seconds.options like "language etc will b displayed .AUX will be one of the options .select it ":on".now u can play your ipod through your head unit .
As far as iPod connections - they will work with a regular iPod and an iPod Nano. You have two options depending on how much you want to spend and how much convenience you want.
Option 1 - Use a Pioneer CD-IB100 adapter. This will plug into the docking port on the bottom of the IPod, charge it, offer control and song information on the head unit. You need to use this one and not the newer CD-I200 cable because your head unit is not compatible with the newer piece.
Option 2 - Use a Pioneer CD-RB10 adapter and a 3.5mm to RCA cable that will plug into the headphone jack of the iPod. You will only get audio input to the head unit but this option is somewhat cheaper.
As far as the clock settings - hold the 'source' button to shut the unit off(key still has to be on). Push the 'function' button until options appear - you can switch between options by repeatedly pushing the 'function' button and adjust settings by using the up/down/left/right arrows.
allpioneer products need power and ground to operate. check the fuse on the yellow wire. if ipod is not plugged in, it will not show as a source on the pioneer head unit
