How do i reprogram a 2wire 2071-A - Computers & Internet
  • nonne73 Dec 16, 2008
    hi.. i have just start to use pc.and now i wanted to download movies i have the latest utorrent 1.8.1.. i can download but i cant get green light,i have checked my firewall but im not sure what to do.. sometimes it gets green light for couple of minutes then back to yellow. plz can someone tell me wht i should do,,, remember im a novice at this so get plz step by step..regards merca
First, get the modem/router's setup and user manual from http://www.2Wire.com/pages/driversanddocumentationsupport.php?did=6
After studying those, read the instructions at
http://support.2Wire.com/index.php?page=view&article=21
After having done your homework, do the following:
1.) Port Configuration
BitTorrent clients listen (wait for) incoming connections on one of the 65535 ports of a PC, the listening port. The typical port range for the BitTorrent protocol is 6881 - 6999, which means that you should choose a port from this range as the listening port, because many other people configure their firewalls to only accept incoming connections on these ports and might consider exotic values as suspicious. Yes, many ISPs throttle the throughput for file sharing applications, but if they are serious about hindering P2P activities, there are many more sophisticated ways to identify BTs, for instance by means of analyzing traffic, packets, connection and usage statistics, etc., instead of relying on the port number only. Consequently, as long as your ISP does not interfere too much with your file sharing and/or if changing a non-standard port doesn't remedy the problems, stick with the standard port range of 6881 - 6999.
If you do choose a different value, make sure that it isn't the standard port for other Internet activities (FTP, HTTP, SMTP, etc) or even worse, known as the port used by some malware. As a rule of thumb, steer clear of the lower numbers and rather choose a higher number, because the lower ranges are often occupied by other applications. In case you are using a hardware firewall (router) and/or a software firewall, do not activate the 'randomize Ports' function but stick with the same port all the time.
In Opera, the best of all web browsers that comes equipped with an internal BitTorrent client, you can find/modify the port number by entering 'about:config' into the address bar and expanding the BitTorrent section.
2.) Software Firewall Settings
People using the MS Windows XP/Vista firewall go to Options -> Preferences -> Connection and check 'Add µTorrent to Windows Firewall'. People using other firewalls will need to refer to the respective software's documentation.
You will have to allow incoming TCP connections on the port that you chose as the listening port in your BitTorrent software. BitTorrent does not use UDP, so creating a rule for TCP only should do fine.
3.) Router Username and Password
In case your PC is protected by (connecting to the Internet through) a router, a few additional steps need to be taken in order to enable software to establish outgoing connections. Some people who do not have a separate router may find that their modem serves both as a modem and as a router, and this procedure will also apply. This is the case  with the 2Wire HomePortal Gateway 2071.
In your web browser, enter http://192.168.1.254 as the address (study the manual or your old notes for a different address) and have your username and password for the Gateway ready. If you can't find them and were given the modem by your ISP, you will have to call them because if you only change the password on your end, you won't be able to connect to the Internet any more. In case you need to change the password,  see the user manual for the respective hints.
4.) Router Firewall Configuration
Enter the Gateway 2071's address in your web browser's address bar, go to Firewall -> Firewall Setings and select the computer for which you want to enable port mapping.  Since 2Wire Gateways offer a maximum of four LAN ports, identifying which of the four computers is the one in question shouldn't be too hard a task.
Now click on the 'Add a new user-defined application' link  beneath the list of pre-defined applications. Define an Application name like "BitTorrent Client" and enter the listening port into both port range fields, for instance from 6885 to 6885 for the TCP protocol. For BitTorrent, everything else can remain blank/none and you click on 'Add Definition'.
The page reloads and after you went 'back', select the freshly added profile from the list of applications and click on 'Add', then on 'Done'.
It's not really that difficult, but router manufacturers somehow always **** at describing the steps properly because they never provide examples for the three typical 'problem cases' online gaming, VoIP and file sharing. Three examples in each category and millions of users wouldn't have to hunt the Internet for clues.
Good luck,
KARSTEN KEESE
Posted on Mar 25, 2009
    Problem Solver:
  • 5 Answers
Am a total novice re all the utorrent setup and having lota probs gettin things working not sure if i need to forward a port for a 2wire gateway 2071-A modem from telstra, and or anything else can someone please help me this is driving me nuts some of the computer jargon is way beyond me can anyone help me sort things out would be forever greatful can email me at nocecil@hotmail.com. I know this is a real ******* for some of you but have read many manuals posts and guides and am not getting too far. I can download but can never pass the open port test and get a green light, at wits end using bullguard and have opened ports one for out one for in. if you cant help step by step then at least tell me where to go to solve my probs please please please
Posted on Sep 07, 2008
  • 667 Answers
Do you have your instructions? I can tell you but it would be easier for you if you can just look at the guide and take your time. You can do a reset and then reprogram. If that's all you want to know I can do that. Would you want me to get you athe manual or tell you specifically how to do something?
Posted on May 03, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton May 03, 2008
    Sorry - I meant to post that as a clarification request. Let me know and I'll help you out. Thanks dustin.
2 Suggested Answers
sriramoju
  • 171 Answers
SOURCE: 2wire moden
check the modem diagnostics it is ok try to reinstalling the modem drivers and create a new dail-up connection
Posted on Mar 24, 2008
Please tell me is my internet modem 2wire 2071 A wireless, can I connect a laptop with it
Yes you can provided you laptop has a wireless card and it is configured with the router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Dec 30, 2010 | 2wire (1000-000057-000) Modem
I want code activation adobe photoshop cs 8.0, with serial number 1045-1756-2071-0999-3438-3575, please help me,,,#
Giving product key is considered to be illegal here . Any expert who gives product key is banned from service here . So i do not think any expert will give the product key.
Oct 25, 2010 | Adobe Photoshop CS for PC
2-wire modem won,t come up in connections,and don,t know how to configure modem dsl light solid green and can,t find lan settings,it,s a 2071-a
If you know your local network address side address then just log into the 2Wire with "http.XXX.XXX.XXX."
Example my 2Wire: "http.192.168.1.254." I'm not sure but I think the 192.XXX.XXX address is default.
The box has a little web server that will allow you to reconfigure to default but if your provider programmed it you may need info from them.
Sounds like the DSL side is working.
Oh, if you have the info from your provider to set it up, you might have to push the reset button on the box to reset it to factory default.
Then it gets a little complicated.
Nov 18, 2009 | 2wire Computers & Internet
I have a 2wire 2071 - A modem and it wont read my ethernet cable
First check device manager to see if the copmuter recognizes the card, if it dont use the add hareware app, and have windows plug &play try to locate it. then open the case and remove the card with windows running and replace it in the slot , P&P may then locate it if windows doesnt, then the ethernet card may of had a voltage spike go thru it and fried the card.
Jul 12, 2009 | Computers & Internet
I need manual installation instructions (dont have cd)& key code for Gateway 2wire modem model 2071-A
It appears to be a DSL modem. You don't need a driver, but a username and password for your internet provider. Here is how you install.
connect to phone line then usb or network port (drivers should be built in xp) open your internet browser and type 192.168.1.1 to open the internal web page. It should step you through the username (email address) password. Must ask your internet provider for those.
Apr 29, 2009 | Computers & Internet
2wire modem keeps on disconnecting
looks ur internet setting is not right on ur new laptop for the modem u are using....call ur internet provider and ask them for technical advise and help
Apr 19, 2009 | HP Compaq Presario CQ60Z Notebook
Configure D-Link Wireless N Router DIR-615 for 2wire 2071-A modem
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
login ADMIN and pass is blamk
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Apr 04, 2009 | D-Link 802.11g 54Mbs Cable/DSL...
No wireless connection
Child got into the wires behind computer and disconnected the wireless and I no longer have the directions can you help me?
Jan 15, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire moden
Mar 24, 2008 | Computers & Internet
Computers & Internet Logo
402 people viewed this question
David Payne
David Payne
