Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Sony Convergance chips
I replaced the convergance chips and the guns now line up BUT the screen is now all blue??? Any idea what happened?????
  • Freddy35 May 06, 2008
    It turns out that it was an input problem and has been corrected....
    THANKS!!!! The picture is GREAT!!
  • 121 Answers
Can you still see the picture? and if so you need to adjust the G2 adjustment on the blue tube
Posted on May 06, 2008
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
May 02, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Pt47wx42 convergence
Yes, I have and idea, and it has nothing to do with the aspect ratio. One of the convergence output IC's has failed. This is a very common failure with all projection sets. Average repair cost by a reputable repair shop is around $200 to $300 depending on where you live. BTW that set is well worth the repair cost.
Jun 16, 2009 | Panasonic PT-53WX42 53" Rear Projection...
WS55511Mitsubishi TV convergance problem
Your TV most likely has a problem in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 22, 2009 | Mitsubishi WS-55511 55" Rear Projection...
The convergance is out on ny sony kp65ws500 how do ifix this problem
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 19, 2009 | Sony KP-65WS500 65" Rear Projection...
Red and blue gun not lined up
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 05, 2009 | Sony KP-41T65 41" Rear Projection...
Major problem with sony kp-57ws500
BTW if you appreciate the help I have given you, please rate me! Thanks!
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Problems after convergance chip replacment
Check that none of the IC pins are bridged with solder, Use a strong magnifying glass to check the pins very carefully
May 03, 2008 | Sony KP-51WS510 51" Rear Projection...
Color bending
Go into the menu and look for Screen Convergence. It may also have an auto convergance option try that first. If it gives a suto error or you cant adjust it manually the convergance IC's may be bad or a component on the convergance board.
Sep 15, 2007 | Sony KP-51WS500 51" Rear Projection...
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Aug 10, 2007 | JVC AV-56WP74 56" Rear Projection...
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Aug 09, 2007 | JVC AV-27720 27" TV
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
