I need a replacement base for the tv. I do not want to mount it on the wall.
  • 11,361 Answers
Need plastic base for AOC LCD TV
Try searching eBay first. You might be able to purchase a generic replacement stand that uses the wall mounting screw holes.
Jun 24, 2012 | AOC L19W898 19 in. LCD TV
Hi, we have just bought a second hand Hitachi Hi Plasma TV Model PD1, 42PMA400A. We have a wall bracket but what we'd eally like is a stand ... the base plate and two stems that go into the bottom of...
If you search on Ebay for your TV's exact model number, sometimes you can find a replacement stand for it there from someone who has their TV mounted to the wall and is no longer using it. These are normally fairly heavy and bulky items, so Ebay purchase prices and shipping costs can vary widely.
I did not see any for your exact model of TV available there when I looked, but the online selection changes daily, so you can always keep checking back. Just search on Ebay for 'HITACHI TV STAND' or 'HITACHI TV BASE' and you will see a wide variety of them available for different Hitachi TV models as well as what the average price for them is.
Otherwise you can just buy a generic wall mount floor stand for around $100 which bolts to the TV like a wall mount, but actually sits on the floor instead of being bolted to the wall.
Here are some links to a few different models currently available on Ebay which include pictures so you can see what I mean:
http://cgi.ebay.com/PLASMA-LCD-FLAT-PANEL-MOUNT-TV-STAND-WALL-SHELF-STAND-/390330001764?pt=LH_DefaultDomain_0&hash=item5ae17b2964
http://cgi.ebay.com/Plasma-LCD-Flat-Panel-Console-Shelf-Wall-Mount-TV-Stand-/270797719452?pt=LH_DefaultDomain_0&hash=item3f0ccd479c
I hope that was helpful to you, good luck and take care.
Joe.
Aug 30, 2011 | Hitachi Televison & Video
I purchased an element electronics 32" Full HD digital LCD from Walmart with a Ready Set Mount LCD/Plasma Wall Mount, however the mount does not attach to the tv at the base. Do you know if this is...
The wall mount is not made to be fit into the base, it is attached to the back the TV, TV uses what they call VESA mounting which had different pattern for each TV. Look at your TV user manual to find out the VESA mounting number.
If you want TV wall mount that can swivel you can try looking here: http://www.mountsdirect.com//index.php?cPath=1_4&osCsid=b3fd26fc27f668e207c3741b09abfe51&gclid=CJrL-5Dx1acCFYrs7QodUiUq9Q
http://www.toptvmounts.com/collections/swivel-tv-mounts?gclid=CK7kzPrx1acCFYXu7QodlFc4-A
Or Google "swivel wall mount"
I got my from COSTCO.
Mar 17, 2011 | Element Electronics FLX-3211B 32 in. LCD...
How do i remove the stand/base off a panasonic viera TX37LZD70 37" flat screen tv so I can wall mount it?
Place the TV on a flat bed preferably your mattress and look for the base mountings. The lock and base mount can be slid off and you can use a good wall mount that will support the weight to be fitted.
Please find the link below for help:
Wall mounting flat TV
Jan 07, 2011 | Panasonic Televison & Video
Remove base to wall mount
Place the TV face down on cushioning. There are four short hex head screws that hold the TV to the stand. There are two on each side of the mounting point (close to the bottom of the TV). (Turn counter-clockwise to loosen.) Next slide the base down from the bottom of the TV. The appropriate sized hex key was supplied with the TV (and the base was installed). If you want to, you can unscrew the support post from the base - it has 4 long hex head screws. This will let you put the base parts into an appropriate container for storage.
For a clear picture, see the manual for installing the base and work the steps in reverse. See here for a copy of the manual: http://www.managemylife.com/mmh/owner_manuals/search?query=LC46SB54U+ .
To put on the wall mount, you will need to remove the covers from the 4 mounting locations on the back of the TV and use the screws from the wall mount bracket kit.
I hope this helps.
Sep 16, 2010 | Sharp LC46SB54U 46 in. LCD TV
How do I take the stand off of the TV? (For wall mounting)
There will be clips or screws on the back of the TV which will need to be removed and the base stand will slide out of the bottom of the TV. Do NOT start taking screws out of the back of the TV without the wall mount with instructions. Sometimes there are spacers that need to be used with the wall mount and generally only four screws need to be removed from the TV. The TV should have instructions on how to prepare the TV for a wall mount as well. All are different, but very similar to do. If you lay the TV face down on a soft surface (do not slide it around) you probably can see what screws need to be removed to remove the TV base. Keep the screws with the stand for later use if desired because you will need them to re-install the case later. Here are two examples;
I hope this helps and good luck!
Nov 12, 2009 | Televison & Video
Removing the base of flat panel tv
You don't have to mess around with the screws on the bottom of the base.
There are 4 screws on the back of the Toshiba that are in line with the wall mounting screw holes.
Remove the 4 screws and the base falls off.
Nov 23, 2008 | Toshiba Televison & Video
Akai PDP42Z5TA 42 in. Plasma base removal
If you ever get the base off, I'd like to buy one.
Apr 13, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
