Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
I need to find the defrost timer on my old Kenmore fridge
    President:
  • 1,218 Answers
Good day,
If it is a side by side, it could be behind the grille on the front of the machine, or in the same Box as the thermostat in the upper right side in the rear of the fresh food compartment, or lastly, if it has an ice maker with a plastic tray, it has none. It is an integral part of the ice maker.
Posted on Aug 20, 2010
Testimonial: "Hey thanks, I was told that it definitely was not in any cooled area yet there it was on the upper right side of the refrigerated area. Thanks again. "
  • John Hall Aug 20, 2010
    Bad advice. They were moved into cooling areas of the machine to keep out dirt, and extend the life of the timer motor by being allowed to run cooler.
  • 33 Answers
SOURCE: Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Posted on Jan 01, 2008
SOURCE: Kenmore Fridge #596
i found the defrost timer for my Kenmore 596.62239200 / freezer on bottom. it was in the top of the refrigerator compartment behind the light bulb console. had to remove the light bulb cover and then there are two visible screws that hold the defrost timer to the light console. the timer is up on top of the console and is not easily seen. ordered parts on www.repairclinic.com.
Posted on Jun 13, 2008
dididsaythat
  • 291 Answers
SOURCE: Freezer freezes but fridge does not get cool
DO u have frost build up in the freezer ? If so you have a defrost problem.. defrost thermostat, timmer or heaters. You can by-pass the thermostat cut it and tape the wire together and put it into defrost with the timmer by clicking it to the right until it clicks the heater you need to ohm out .. the defrost timmer will be good most of the time if it comes out of defrost ... ref. will start running again when u test the defrost thermostat here is a diagram that may help
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?diagramPageId=00011&componentDescription=AIR%20FLOW%20AND%20CONTROL%20PARTS&documentId=00016472&modelNumber=1068562782&productCategoryId=0160000&brandId=0582&modelName=REFRIGERATOR&backToLink=Return%20to%20Sub%20Components
Posted on Aug 24, 2008
  • 195 Answers
SOURCE: Kenmore fridge Model# 106.56542400
Open the fridge side, look up.
Posted on Dec 07, 2008
  • 531 Answers
SOURCE: defrost timer location on Kenmore model 106.56542400
carry control board part#2149705
Posted on Apr 06, 2009
Fridge is not keeping the food cold, water at the bottom of fridge, freezer is not as cold, still freezes things but takes a long time. This is a Kenmore 20 fridge, my guess is 15 years old.
unplug the fridge and leave the doors open for 48 hours, then see if your problem is gone 24 hours later after you plug it back in, if it is, your fridge needs to have a repair to the defrost side of things, most likely the defrost termination therm or the defrost timer, also make sure the drain under the evaporator is not plugged up
Jul 22, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore coldspot, freezer frosted up then auto defrost and both freezer and fridge stopped cooling. unplugged and defrosted and now freezer works but not fridge. vacummed coils already. 3 yrs old.
Check the freezer fan motor.
Is it working>
If not,replace it.
Also you must replace the defective defrost parts.
Timer......heater.....thermostat.
May 08, 2011 | Refrigerators
Kenmore fridge leaks water on floor and then stops cooling. Tech said it needed heater/defroster and would cost $500. Does this sound right.
Ah no. If the fridge was not defrosting then water would not be leaking out.
It sounds like the defrost timer is not completing it's cycle. You may need a new defrost timer.
The cost of a new timer, call out, fitting and testing could be around $375
Mar 31, 2011 | Kenmore Side by Side Refrigerator
Two door side by side fridge middle wall is hot ,fridge not working very well ,5 year old kenmore ,any soloution ?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 14, 2010 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot freezer too warm
Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
Hope this helpout......
Jul 28, 2010 | Kenmore Refrigerators
Fridge is 14 yrs old but in good condition. Several new timers have been installed and the defrost term. unit checks out ok, but the timers will not operate consistently. Model #970-450020.
I would say the new defrost timers are just made too cheaply. The old ones would seem to run for years on end. Maybe whoever installed the timers are just buying the "generic" cheapos?
Dec 30, 2009 | Kenmore Refrigerators
1 yr old Kenmore fridge (18 cu ft top freezer mdl 970-41924) has very long defrost cycle - freezer contents partially melt, fridge warms to 50-55 F. (Normally runs at 38-40 F.) We keep several litres of...
Either the defrost timer is going out or it could be your defrost bimetal thermostat that is located behind the back wall in your freezer. Both parts are cheap and easy to install. I would replace both.
Sep 09, 2009 | Kenmore Refrigerators
Kenmore Fridge Defrost fan wont stop running
Hi, The defrost timer is located in the control panel. There should be 2-4 screws holding the control panel. Remove the screws and lower the panel to see the defrost timer. There are 2 screws holding the defrost timer in the control panel.
Please let me know if this helps you at all or if I can assist yyou further.
Vic
Jul 21, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
I have a 7 year old Kenmore Upright Refrigerator/Freezer on top. I am losing the temp in the fridge part only. The back up the freezer gets a thick layer of ice buildup and when i remove the back panel the...
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Jul 13, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
235 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
