Question about Intel D945GCZ Motherboard
I have upgraded my bios of intel D945 DCR and now i have the cpu fan noise problem, when i open a video site like youtube the fan sound increase. Also this motherboard has the sound card problem which is not working and i used and add in sound card now.
  • Intel Master
  • 3,799 Answers
Clean the fans. when a fan is rotating it impacts on dust particles at high speed this causes build up and an imballance which causes airflow disruption (noise). As long as you can get sound out of it I don't see the problem, Most stand alone cards give a better sound quality than inbuilt audio chips anyway. Also, they give more control over the sound output.
Posted on Jan 29, 2012
4 Suggested Answers
map9966
  • 2351 Answers
SOURCE: ASUS P5VD2-MX SE Motherboard CPU compatibility
Hello itsme99, click on this link I have posted. This link shows what CPU you're Asus P5VD2-MX SE motherboard can run.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5VD2-MX%20SE
You're board does not support Quad core CPU's!
This next link is the main page (Drivers, FAQ's ect.) for the Asus P5VD2-MX SE motherboard. (Look to the left of the page under Related Link). http://support.asus.com/download/download.aspx?modelname=P5VD2-MX%20SE&SLanguage=en-us
Here is a list of Asus Quad core motherboards.
http://event.asus.com/mb/quad_core/
Have a nice day.
Enjoy!
M
Posted on Jun 06, 2008
  • 11 Answers
SOURCE: Upgrading CPU on Asus PSBW-LA motherboard
Dealing with OEM PC's can be rather difficult. Most of the specifications on those chips are the same, except the FSB (Front System Bus). The E6300 is 1066MHz and the E6550 is 1333MHz. I don't believe that this is set by jumpers (i'm 95% sure). I would look into BIOS to see if it is an available option to change (though most of the time this setting is set on AUTO). There is a chance that you will need to provide a BIOS update. If you chose to do this be very careful as this is dangerous. Should something interupt this (power outage or something like that) your computer could become useless. Definitely make sure to do a lot of research and preparation before performing an update.
Posted on Mar 25, 2009
SOURCE: i want intel p 4 d945-gccr drivers
i want intel motherboard d945 driver for free download pls make a way
Posted on Mar 31, 2009
Dell optiplex 760 tower fan noise problem
Its important to try and distinguish where exactly the noise is coming from the most typical example of this is the PSU fan (Power Supply Fan). The above also is very correct but its better to eliminate each point of failure.
May 08, 2014 | Dell OptiPlex 760 PC Desktop
Asus f3j bios mod for upgraded ram
Not sure what you are asking about. Asus site says the motherboard will take DDR2 533/667MHz SDRAM, 2x SO-DIMM socket expandable to 2GB
Which means DDR2 533mhz 1 gig per slot total 2gig
or DDR2 667mhz 1 gig per slot total 2 gig
To enter BIOs press F2 at boot up, but no setting should need to be changed.
They do not have a BIOs update for increasing the memory limits.
BIOs upgrades from first to current are.
BIOS 304
Update new CPU Microcode
System plays wave file and causes garbage sound.
BIOS 305
To fix system cannot do battery pre-charge process when an unknown/failure battery insert.
Support Intel Extend ID CPU:Merom Celeron 530 CPU.
BIOS 306
BIOS 307
Fix System hang at ASUS LOGO on SATA HDD with factory recovery image
Last upgrade date is 2008 7 14
Mar 14, 2014 | ASUS F3Jc Notebook
How to recover my intel pentium D 2.8ghz processor its over heating of 70 degrees.
If your system is five years old or older it is possible that the thermal grease/tape has dried and will need replaced. There is no need to remove the CPU for this. If you can enter your bios you can also check the fan speed of your CPU heatsink fan rpm. It should run between 2800rpm and as high as 3500rpm. If its not than replace your heatsink assembly.
Replacement heatsink assemble;
http://www.thefind.com/computers/browse-install-intel-cpu-heatsink
Thermal tape: http://www.crazypc.com/products/PQ5-5025.html
Thermal grease: http://www.newegg.com/Product/Product.aspx?Item=N82E16835100302&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-CPU%20Thermal%20Paste%20/%20Grease-_-MASSCOOL-_-35100302&AID=10440897&PID=1609763&SID=tfc_-_4_104_100921_e4d0767819e4422998638af41543c991:0000
Video how to remove heatsink assembly video how to replace heatsink assembly: http://www.youtube.com/watch?v=G3k9Ube9BBs
There are more videos listed on the right side of YouTube.
Good luck.
Mike
Sep 22, 2010 | Computers & Internet
D865 Intel Motherboard overheating
The 50% useage of the CPU is the problem not a fan issue. You have a memory glitch or IRQ setting causing this. Go back to basics look for a Video problem or shared memeory - does this board have onboard video, does it have onboard audio, have you installed a add in video/audio card? Check your bios settings, look at shadow memeory useage.
Jul 24, 2009 | Intel D865PERL Motherboard
Fan rpm prob
First you say it shuts down before Bios, than you say in Bios it shows fan rpms are 0000?
get on the internet and search for computer beep codes, but it sounds like the fan for the processor has quit working. One way to find out is to open the computer case, start it up, and see if the fans are working. If it is just a bad fan, than that is an easy and cheap fix.
Jun 12, 2009 | Intel D945GCZ Motherboard
Changed motherboard
when you boot your computer open up the bios menu, i forget which tab it is under but there should be an option called S.M.A.R.T fan or SCSI if it is disabled enable it this should fix it, if you do not have this option or if it doesnt work this is a link to a fan control program called speedfan http://www.almico.com/sfdownload.php
May 28, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
Cpu fan noise problem
You should check and make sure the inside of your computer isn't dusty. Dust will wreak havok on fans and shorten their life. Plus it likes to build up between the fan and heatsink which will overheat your processor. Take the fan off and spin it with your fingers. I like to open the little sticker on the bottom and put some 3 in 1 oil to lubricate it. A smooth spinning fan is a happy computer. It also reduces noise that a dirty fan makes. Hope this helps you.
Jan 09, 2009 | Intel D945GPM 945G Ewith Windows XPress...
Processor upgrade from 1.6 to 2.4
Hi zmoonz,
you must be missing something. Please go over this Intel link:
http://www.intel.com/support/motherboards/desktop/d850mv/sb/CS-009910.htm
Double check your board revision. Instruction / location for this is on the site above. Even though you have the correct revision no# the Pent 4, 2.4GHz CPU can only run with the correct revision (AA numbers) listed.
There are no jumpers on the Intel D850MV MB to help increase the CPU speed nor bios menu to help. Enter the bios. Open Main. This bios does not allow any CPU options.
Mike
Aug 20, 2008 | Intel D850MV Motherboard
Motherboard D945GCL Problem
Your OS Might have corupted, you can try reinstalling the OS.
Jan 02, 2008 | Intel D945GCL Motherboard
Intel D945GCZ Motherboard Logo
94 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
